window regulator plastic slider p/n - '91 318is
  • jdt10768
    • Feb 2013
    • 484
    I'm about to tear into my window regulator, and want to order the square plastic slider pieces (with clips) but need a part number. I looked on realoem, but they are not pictured/listed in the diagram
    Anyone? Beuller?
  • 2mAn
    SeƱior Mod
    • 21062
    Post the picture from realoem and maybe we can help
    You can also email sales@bluntech.com and they could probably find you what you're looking for based on your description
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
    • jdt10768
      • Feb 2013
      • 484
      https://www.realoem.com/bmw/enUS/sho...diagId=51_0330
      I assumed it would be on this diagram, but don't see it
      Wound up calling dealer, and they had (part number 51-32-1-938-884) from https://www.pelicanparts.com/bmw/tec...er-Windows.htm
      I hope those are right, but only a few $$ with CCA discount
      • roguetoaster
        Biggus Tippus
        • 7830
        The part you linked is for E36s & other later chassis, and those shouldn't fit E30s since they use a riveted on plastic roller. Undoubtedly you could remove the roller and replace it with something, but I doubt you can find an actual P/N for one since they are likely considered part of the E30 regulator assembly.
        That all assumes that you do mean the end bits on the regulator that slide in the "tracks" of the system, and if so, I've never seen one break on an E30.
        • jdt10768
          • Feb 2013
          • 484
          10-4, that makes sense. The link indicated e30 and e36 at top of page.
          So, my driver's side window is slow as hell up and down. I'll just open it up and try to find the weak link.
          Is it easy to swap out the motor without removing the regulator? Prob not, but trying to gather info before digging into it
          • roguetoaster
            Biggus Tippus
            • 7830
            I believe you can swap the motor in place, but I've not had to do that.
