Mike's Cosmos Black 1998 M3 Sedan (M3/4/5) - Project Concord
  • iXBeater
    • Apr 2007
    • 353
    #91
    Those really are pretty wheels...
    1985 E30 S52 - Daily Driver
    1986 M635Csi - For the best days
    • mike.bmw
      • Dec 2015
      • 1777
      #92
      Earlier this week I replaced the idler pulley and tensioner pulley assemblies. The tensioner pulley shock actually broke during removal, preventing me from removing the pulley while it was still on the car. Fortunately, I was able to get a socket behind the pulley to remove the blocked bolt and remove/replace the entire assembly. It's much smoother/quieter with the new pulleys installed.
      Here's a short YouTube video of the process: https://youtube.com/shorts/MF-mPHhQQ...pWry2IzYQyBOSs
      PXL_20251015_010101710 by mike.bevels, on Flickr
      PXL_20251015_104935009~2 by mike.bevels, on Flickr
      PXL_20251015_010144468~2 by mike.bevels, on Flickr
      • mike.bmw
        • Dec 2015
        • 1777
        #93
        It's never ending with this car...
        After some odd clutch pedal/engagement behavior, I decided to inspect and bleed the clutch slave cylinder. I've found that removing it from the transmission and pushing the rod into the clutch slave while opening the bleed screw (pointed upward) works well. However, when I removed the clutch slave cylinder from the transmission, the rod fell out and onto the floor. I've seen people make the mistake of applying pressure or pumping the clutch pedal with the clutch slave removed, which will force the rod out, but that wasn't the case here. It just fell out!
        Given the odd clutch engagement behavior and the fact the rod fell out (which can be reinserted easily, but I didn't trust it), I decided to order a new FTE unit as it was only $54 shipped. I left the car on jack stands for the better part of the week and installed the new clutch slave cylinder when it arrived in the mail yesterday. The clutch pedal/engagement feels much better/smoother now.
        PXL_20251022_164423538~2 by mike.bevels, on Flickr
        PXL_20251022_164405281~2 by mike.bevels, on Flickr
        PXL_20251022_165011672~2 by mike.bevels, on Flickr
        PXL_20251022_164728359~2 by mike.bevels, on Flickr
        PXL_20251022_182125645~2 by mike.bevels, on Flickr
        • mike.bmw
          • Dec 2015
          • 1777
          #94
          The saga continues!
          Last month I thought I had finally resolved an intermittent issue with air entering my cooling system. How wrong I was!
          PXL_20251028_002316057~2 by mike.bevels, on Flickr
          I had done this before, multiple times, but I went over EVERY SINGLE HOSE AND CLAMP. I also checked the expansion tank for cracks. That's when I saw this, a tiny amount of liquid around the hose that connects to the expansion tank bleeder.
          PXL_20251027_211304154 by mike.bevels, on Flickr
          Well, the PEX clamp was quite loose. There was a small amount of coolant leaking out (and air getting in), but because it leaked between the expansion tank and fan shroud intermittently, never leaving a visible trace or puddle, it was very had to track down.
          PXL_20251028_000321656~2 by mike.bevels, on Flickr
          I removed the PEX clamp and installed a proper BMW 12-15mm hose clamp, which I had leftover from replacing all the fuel hoses/clamps on my E30.
          PXL_20251028_001103507~2 by mike.bevels, on Flickr
          PXL_20251028_001551505~2 by mike.bevels, on Flickr
          And then I re-bled the system. All good for the last few days! I know I've said I fixed this before, but this time I'm more confident. There hasn't been any coolant loss, and I haven't felt or heard any air in the upper radiator hose when squeezing it.
          PXL_20251028_010836232~2 by mike.bevels, on Flickr
          • mike.bmw
            • Dec 2015
            • 1777
            #95
            After a 40-minute drive with the blower motor squeaking at every fan speed yesterday, it was finally time to replace it. I've had the part sitting on a shelf for a year, but couldn't motivate myself to tackle this job as access and space are terrible, and there's a lot of fragile plastic that needs to be moved or removed.
            The job was just as terrible as I imagined, and 6 hours later I have the cuts on my arms, hands, and fingers to prove it. There were times I questioned my sanity, but I worked through problems as they came up and eventually got everything back together. Having a quiet blower motor is going to make driving this E36 M3 so much nicer.
            For the sake of comparison, I've swapped two complete E30 dashboards, which are long and tedious jobs with many parts and fasteners, and those were much easier (and enjoyable) jobs due to space and design.
            E36 life?
            PXL_20251105_002406616 by mike.bevels, on Flickr
            PXL_20251104_161624863 by mike.bevels, on Flickr
            PXL_20251104_190239034 by mike.bevels, on Flickr
            PXL_20251104_190337347 by mike.bevels, on Flickr
            PXL_20251104_193747578 by mike.bevels, on Flickr
            PXL_20251104_213502358 by mike.bevels, on Flickr
            PXL_20251105_002345664 by mike.bevels, on Flickr
            • iXBeater
              • Apr 2007
              • 353
              #96
              That's good work - it's amazing how quiet everything feels once you've buttoned up something like that.
              This is excellent news - I'll let you know when I'm ready to swap the dashboard in my E30 so you can come help...
              • mike.bmw
                • Dec 2015
                • 1777
                #97
                My less-than-three-year-old Mahle/Behr expansion tank developed a hairline crack, where the black plastic top meets the translucent body, which was fun to track down. Replaced with a new one!
                PXL_20251118_014701705 by mike.bevels, on Flickr
                We rolled over 260,000 miles last week.
                PXL_20251121_173713893 by mike.bevels, on Flickr
                I stopped by the side of the road for some sunrise photos.
                20251123-DSC_9961 by mike.bevels, on Flickr
                20251123-DSC_0023 by mike.bevels, on Flickr
                20251123-DSC_9976 by mike.bevels, on Flickr
                20251123-DSC_0020 by mike.bevels, on Flickr
                20251123-DSC_9991 by mike.bevels, on Flickr
                20251123-DSC_9969 by mike.bevels, on Flickr
                • mike.bmw
                  • Dec 2015
                  • 1777
                  #98
                  I finally got around to addressing my valve cover gasket weeping oil. I wasn't looking forward to this job because while replacing the head gasket job 2.5 years ago, my friend and I decided to put RTV around most of the sealing surface, which would now be a chore to remove.
                  End to end, with nearly two hours of scraping with a plastic razor blade, the job took about 3 hours. Given the mating surface was blemish free, I only put RTV in the prescribed areas: where the VANOS meets the head and in the corners of the half moons. I even let it cure for 24 hours before starting!
                  While I was in there, I realized the rear ground strap was missing (since I bought the car 3 years ago). I had a generic braided one on hand, and ordered extra M5-0.8 8mm nuts to secure it to the stud.
                  After all that, IT STILL LEAKS! But now that everything is cleaned up, I can see it leaks between the valve cover and valve cover gasket. There are no leaks between the head and valve cover gasket, meaning that surface sealed correctly. I'm assuming this means the original plastic valve cover is warped or has a small crack, letting oil penetrate the channel with the VCG sits, and then run down the outside of the channel. The leaks are only on the "low" side of the valve cover, that overhangs the exhaust manifolds.
                  I'll run it like this for a bit to see if it gets any better or worse, and then decided whether to purchase a new valve cover.
                  If anyone else has experienced this before, please let me know!
                  PXL_20251218_121849677.RAW-02.ORIGINAL by mike.bevels, on Flickr
                  PXL_20251218_122007269.RAW-02.ORIGINAL by mike.bevels, on Flickr
                  PXL_20251217_181714806.RAW-02.ORIGINAL by mike.bevels, on Flickr
                  PXL_20251217_181942008.RAW-02.ORIGINAL by mike.bevels, on Flickr
                  PXL_20251217_170722083.RAW-02.ORIGINAL by mike.bevels, on Flickr
                  PXL_20251217_181704166.RAW-02.ORIGINAL by mike.bevels, on Flickr
                  It still weeps oil...
                  PXL_20251218_194349733.RAW-01 by mike.bevels, on Flickr
                  • pipeuy
                    • Jun 2014
                    • 110
                    #99
                    A while back I replaced the valve cover gasket on my S54 (I know different engine with metal valve cover) with a Victor Reinz one and it started immediately leaking again. I found some posts online mentioning that the only valve cover gasket that should be used is the OEM BMW one, so I ordered a OEM one and voila, that fixed the issue for me.
                    By the way, beautiful looking E36, compliments the E30 nicely.
                    1990 Bmw 316i 2 door Alpine Weiß 2
                    1990 Bmw 535iA Alpine Weiß 2 (soon to be manual)
                    • mike.bmw
                      • Dec 2015
                      • 1777
                      #100
                      Thanks!
                      Surprisingly, the leak seems to have dissipated A LOT. Barely a hint of oil on the paper towel when I press it against the valve cover/gasket/head seam. At the risk of jinxing it, maybe there was some residual oil left in the valve cover gasket channel that worked its way out after a few heat cycles. I'll keep an eye on it for a week or two and see what's what.
                      I opted for the Elring valve cover gasket because I thought it was an OE/OEM replacement, but that may not be the case (it is for other parts). In the past, I've ordered the 2.5-times-the-price BMW parts, only to get the "OE" manufacturer part with a BMW stickler on the bag, so I've tried to be a bit more concious about what I'm paying for and what I'll actually receive. Having said that, if this gasket doesn't work out and the valve cover isn't cracked or warped, I'll try the $75 BMW gasket.
                      • mike.bmw
                        • Dec 2015
                        • 1777
                        #101
                        In the event that I do redo this with a new valve cover, gasket, and grommets, at least the vast majority of the mating surfaces will not need to be cleaned of RTV, which was the most time consuming part of the job last time.
                        Some random shots from the past week:
                        20251221-DSC_1225 by mike.bevels, on Flickr
                        20251221-DSC_1238 by mike.bevels, on Flickr
                        20251220-DSC_0981 by mike.bevels, on Flickr
                        20251220-DSC_0925 by mike.bevels, on Flickr
                        20251220-DSC_0909 by mike.bevels, on Flickr
                        20251220-DSC_0897 by mike.bevels, on Flickr
                        20251220-DSC_1163 by mike.bevels, on Flickr
                        • e30m3s54turbo
                          • Jun 2010
                          • 3292
                          #102
                          Great e36 m3. I m always ready up on your saga. I use to have 97 e36 m3 coup. I do miss it. I’m looking for a e36 m3 sudan in silver or blue.
                          Keep posting on the blk beauty and your e30.
                          • mike.bmw
                            • Dec 2015
                            • 1777
                            #103
                            I got a nice surprise on Monday. The oil filter housing was leaking profuse amounts of oil. I had just been under the car a week prior and everything was dry, so this was a recent development.
                            I ordered a new oil filter housing gasket, crush washers for the VANOS oil line, new hardware (just in case, and it was cheap), and an oil pressure sensor. It arrived yesterday and I got to work replacing the gasket.
                            I took the airbox and alternator out. The lower alternator bolt was a challenge, but it eventually came out after working it back and forth and apply PB Blaster.
                            I was planning to unmount the power steering pump, but one of the bolts appeared to be previously cross threaded. I worked at it for a while, but feared snapping the bolt off in the housing, so I left the PS pump attached and worked around it.
                            Other than that, it went smoothly. It appears that it's not leaking now, but I'll continue to check for leaks over the next few weeks. The mating surfaces looked good and I torqued everything to spec, so I'm hopeful I won't have to do this job again in the near future. We'll see!
                            PXL_20260108_204444026.RAW-02.ORIGINAL by mike.bevels, on Flickr
                            PXL_20260108_203934780.RAW-02.ORIGINAL by mike.bevels, on Flickr
                            PXL_20260108_203214138.RAW-02.ORIGINAL by mike.bevels, on Flickr
                            PXL_20260108_182854163.RAW-02.ORIGINAL by mike.bevels, on Flickr
                            PXL_20260108_192503694.RAW-02.ORIGINAL by mike.bevels, on Flickr
                            PXL_20260108_181123008.RAW-02.ORIGINAL by mike.bevels, on Flickr
                            PXL_20260108_195053317.RAW-02.ORIGINAL by mike.bevels, on Flickr
                            • mike.bmw
                              • Dec 2015
                              • 1777
                              #104
                              Two weeks ago my daughter and I were rear-ended at a red light in our E36 M3. It was a hit and run, too, which made it extra special. Aside from being shaken up, my daughter and I were fine, which is the most important thing. The M3 only suffered splintered paint and gouges in the rear bumper, so it could've been much worse. I called the police and filed a report from the scene of the accident, with a few photos of the other car driving away. That's another story...
                              I took the M3 to Manassas European Auto Body to get fixed. A friend of mine, Dro, and his father own the shop. Dro also has an E36 M3 that I featured on BimmerLife a couple of years ago: https://bimmerlife.com/2024/02/17/st...e-e36-edition/ . Their shop did a full glass-out repaint on Dro's car, and the results were fantastic.
                              While my M3 was at the body shop, I also had the passenger front door repainted. I had attempted to repaint this with color matched rattle cans and clear a couple of years ago, and my work was certainly better than failing clear coat, but the color match wasn't so great and it bothered me.
                              After just a week at their shop, I got the car back today and I'm very pleased with the results! The bumper looks brand new, and the passenger door blends and matches so well with the rest of the paint.
                              Damage:
                              PXL_20260112_180451070.RAW-02.ORIGINAL by mike.bevels, on Flickr
                              PXL_20260112_180617839.RAW-02.ORIGINAL by mike.bevels, on Flickr
                              PXL_20260112_180606961.RAW-02.ORIGINAL by mike.bevels, on Flickr
                              At the shop:
                              IMG_20260120_124640_238 by mike.bevels, on Flickr
                              All fixed up:
                              PXL_20260123_143005249.RAW-02.ORIGINAL by mike.bevels, on Flickr
                              PXL_20260123_142757526.RAW-02.ORIGINAL by mike.bevels, on Flickr
                              • Lovespeed
                                • Jan 2026
                                • 41
                                #105
                                Cars looking great! Regarding your original post, I'm addicted to binge watching Sreten and satisfying my ocd! Would be cool to see him restore an E36 M3.
