rodgorT
  • BimmerTim
    • Oct 2007
    • 613
    rodgorT
    So, there I was standing in the backyard of an older gentleman, looking at the shell of a Bronzitbeige E30. It was sad really. Neglected like that. Just sitting in the grass, awaiting the plumes of inevitable rust. Until now. This was it. The one.
    The engine, trans and diff had been removed already, along with some of the more valuable items. You know the ones, ellipsoids, glovebox, center console. It didn’t matter. It had a slight bit of rust on the rear panel around the license plate lights, and the passenger front floor had a 3” hole in it. The engine bay had random bits of rust scattered about it’s entirety. Other than that, a totally clean roller. It even came with full black leather interior, which I swapped into my Lachsilber E30 without haste.
    $250 later it was mine and sitting in my garage. Since at that time I didn’t have electricity or heat in the garage, it sat through winter chilled to the core. Come February, that all changed. I moved into my new place. 6 stalls of heated and insulated glory. TO WORK!
    I quickly dismantled the entire car. Front to back, top to bottom. I erected a sandblasting booth around it and went to town. Rust? Yeah right.
    I patched up the floor and cut off the rear body panel. Seeing as how I worked for BMW at the time, parts were cheap and readily available. So, a brand new rear body panel I welded on. Next, I removed all unattractive bracketry from the engine bay itself. Then laid down some primer and painted the crap out of it. White was going to be it’s new shade.
    Next was the rear suspension. I had problems with my old E30 and having terrible rear end issues. So, to make sure I never had to deal with that again, out came the rear subframe. Of course being from MN the inner bushing sleeves broke off in the chassis. That was a fun few hours getting that out. Every bushing in the rear was replaced with shore 75D polyurethane from AKG. Even the diff bushing on the new 3.73LSD I found for $100.
    Stainless lines, new e-brake cables, and Bilsteins also found there way into the mix.
    The front subframe was next. It was removed, cleaned and painted. It also got new inner and outer tie-rods, new control arms, and Treehouse Green CABs.
    Now, what you weren’t aware of yet, is that I have a full 95 M3 drivetrain in my garage. Radiator to diff cover. I received this jewel for performing a Euro S50B32 swap in my friend’s M3. Complete with 6-speed and Euro polished gear race diff. That car was insane for more reasons than just that. But, I digress.
    So, I purchased mounts, booster, oil pan, electric fan, and a few other misc bits and pieces. Driveshaft! Sh1t. Well, I had a perfectly good E36 M3 driveshaft and diff. I know! My friend with a 98 328is would love him some limited-slip goodness. So, I did the install, and scavenged his old parts and bought a new CSB.
    The engine went in pretty painlessly. But, that’s all I did for quite some time. I was lucky enough to become one of the unemployed. So there that car sat with an S50 completely assembled and ready to go….mechanically. Wiring was left. I did research upon research to make sure I would only have to do this once.
    1988 Bronzitbeige Metallic 325e 2-door S50 turbo (OO=( )=OO)
    2008 VW Rabbit
    1991 Audi 200 20vtq Wagon
  • BimmerTim
    • Oct 2007
    • 613
    Alas! A job opportunity. Totally nailed it and we are back in business.
    Picked up the E30 M3 wiring covers and proceeded to test my research. It proved fruitful, with only one minor glitch. At first it wouldn’t start. I checked and re-checked my wiring. Finally! R3V has come through. Apparently on 88 and older, you do not hook up #7 small green wire E36 side. Snipped it and fired right up. Idled great with NO Check Engine. I could not believe that. So, I pulled the plug on the MAF and the CE came on, so it does work. I just didn’t have any codes being thrown. H311 yeah.
    Since my employment had been restored, I ordered up some coilovers from GC, some wheel spacers from H&R, and one of those cheap Rieger look-alike fiberglass lips. I only got it because I needed it for the car show in a few weeks and that shortly thereafter it would be sacrificed to the lower-than-thou gods.
    Some body and paint work was in the future. Well, not so near as I quickly found out. I got really sick and was in and out of the hospital trying to find a diagnosis. Weeks later, it came. Autoimmune Liver Disease. Great, whatever. Give me pills and make me feel better.
    The day before the show. It runs, it drives, and it sure as h311 has character, but it’s not finished.
    These are some pics from the show. Can you believe I won an award with this thing? Yeah, so what if it was the “Cop Magnet Award”
    This is a shoot that a friend wanted to do. Unfortunately, the lowered gods claimed my lip 5 minutes into it.
    At least the engine bay is clean, Right?
    Honestly, I love this car so damn much. It wouldn’t even be if it weren’t for the priceless and sometimes useless info/crap I find on R3V. Thanks a ton guys.
    I will update this as I do more.
    Thanks for reading.
    2008 VW Rabbit
    • newman
      • Mar 2007
      • 1159
      This car is fucking cool.
      1987 325is: 495whp/400ft-lb
      UPDATED 03/12/10!: RB26DETT Swapped E30
      • DEV0 E30
        • Oct 2004
        • 8892
        The burniator!
        HAR HAR HAR.
        Seriously sick, I love it.
        • oldskool3
          • Mar 2005
          • 401
          Originally posted by newman
          this car is fucking cool.
          x1000
          Photoshop by O 16581 72452 5
          • BimmerTim
            • Oct 2007
            • 613
            Originally posted by DEV0 E30
            The burniator!
            HAR HAR HAR.
            Wasn't sure if people would catch that or not.
            Thanks for the kind words guys.
            2008 VW Rabbit
            • iamsam
              • Jun 2008
              • 174
              Awesome!
              • Spiff325iS
                • Jun 2004
                • 1263
                The burniator!
                HAR HAR HAR.
                BURNINATING THE VILLAGE!
                Clean engine bays rule my life. Your car looks like a blasty blast to drive.
                The Red Dragon V.5 1991 318iS / 2013 F800GT
                "You gotta fix the nut behind the wheel before you fix the bolts on the car"
                • BimmerTim
                  • Oct 2007
                  • 613
                  Traction? Who needs it?
                  It is most definitely a blast. I get out of the car with the shakes everytime I drive it.
                  With the 3.73 rear, it tops out at 130, but it gets there very very quickly. Not that I've tried that or anything.
                  2008 VW Rabbit
                  • N2MYE30
                    • Oct 2007
                    • 5536
                    Its like the engine bay doesn't fit the car. I would never think that the last pic is in the same car as the second to the last pic. Nice progress.
                    COTM
                    • AlarmedBread
                      • Sep 2006
                      • 1510
                      Nice swap!
                      • aaronmjr
                        • Nov 2005
                        • 82
                        Great Job.
                        Seriously, it's been awesome to see this thing come to life. Ugliest cool car ever.
                        1990 M3 / 1998 M3
                        • BimmerTim
                          • Oct 2007
                          • 613
                          I heart you Aaron.
                          2008 VW Rabbit
                          • 87e30
                            • Jul 2008
                            • 5676
                            Love it.
                            I just hate everyone.
                            No need for discretion.
                            • T3rd Ferguson
                              • Aug 2005
                              • 3076
                              coolest car on the forum right now
                              1989 Bronzit 325ia- Sold
                              1988 Delphin 327i- Sold
                              1995 Cosmos M3- Current
