Made a little more progress on Sunday.
We fixed the issue with the motor mounts, since I had the TMS reinforcment kit welded in, the thicker back of the subframe would not allow a nut to go on the stud. So we rotated the engine mounts 180° and ground out the hole a bit on the driver side and PRESTO we were able to easily get a nut on and a socket to tighten it down.
Also got the new front hubs and studs installed (didn't get to install my Massie 280mm kit due to being sent the wrong brake pads), so I should get that done later in the week when the correct pads get here.
Also got the rebuilt calipers, UUC rotors and Porterfield pads, Vorshalg studs on the rear. Got the diff filled with fluid and bolted in as well.
Now it's mainly just finish the wiring/vacuum hoses and see if it will start up!
