from slowwww to gooooo! my first e30 project
  • e30_3I8I
    • Sep 2009
    • 305
    i got this car for free.. it was given to me by my dad's friend....
    it was a beat up m10 that had seem better days..
    the start:
    the interior =] its in good shape
    good bye m10
    new motor =]]]
    new motor in=]
    radiator
    rear strut bar
    finished product... (half ass if only the cons were done with)
    Thats most of the pictures I took.. Most of the time i saw working on it and didn't really have the chance to take pics.
    I installed a z4 short shifter.... i needed an adapter which i got from gregslow318i (great guy.. awesome work)..
    pros: -I've learned a ton for my first time working on a bimmer.
    -the m42 was bored to a 2.0 and cammed, and has the m20 flywheel conversion....
    with dinan chip from TNG's.
    -the car is fasstter than my m10.
    cons: z4 shifter hits the drive shaft:hitler: The only gears it doesnt hit is 2nd and 4th. FIXED!
    the idle goes up to 1000 normally and the goes up and down from 900 to 1200 rpm :hitler:FIXED
    my whole car has the "shakes" i dont know why it does that.... LIVE WITH..=]
    future: ie3's billies or koni yellows, speakers , and the list never ends=]
    my project
    http://r3vlimited.com/board/showthread.php?t=164374
  • HarryPotter
    • Jan 2010
    • 3642
    I do not understand why you swapped to an m42? Why not m50?
    John F. Kennedy
    • jintermont
      • 601
      nice man good luck how is the body??? any cancer?
        • 37832
        Oh my god, TNG's!!!
        Did you buy that motor from Danny?
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
          • 37832
          Very nice, cool swap to do! A big improvement over the M10.
          Grover Beach, CA
          www.BimmerHeads.com
          • BoostinEuros
            • 363
            That's really cool that you stuck with the 4 cylinder.
            Nice work!
            '91 "318is" slick top M50 turbo
            '97 Dodge 3500 12v Cummins
            '12 Mini Cooper S
            '89 318i Chump Car Project
            • BUDNUNTA
              • Apr 2005
              • 996
              Ive always wanted to build one of those.
              Trash my shitty 318is shell and put everything in a clean early model
              Good luck with it
              What do you mean my the shakes?
              Hunter
              We're out there in here.
              • thepoloplaya
                • 81
                for the shaking and erradic idle check ure vacuum lines, bet u got a vacuum leak somewhere.
                • kikkoman
                  • 197
                  What's up neighbor? :) My car does the same thing when I first start the car in the morning before settling down. I've been trying to find the source of the vacuum leak somewhere but so far no luck. Nice project.
                  • e30_3I8I
                    • Sep 2009
                    • 305
                    Sum More improvements That i was lazy to post... tehehe
                    Beeefffoooreeeeeeeeeee
                    Afterrrrrrrrrr
                    BEforee
                    Afterrrr
                    My Timing chain looks cleannn
                    CAMMSS
                    my project
                    • e30_3I8I
                      • Sep 2009
                      • 305
                      CAR PICSSSSS ... with the Bottle Capss,...... sooon to be changed when i gett the funds=]
                      THIS is one of MY FAVORITES at my Friends Shop
                      Bimmer Festt!!!!
                      my project
                      • Butler
                        • Nov 2009
                        • 1613
                        2.0 liter huh!? Sounds badass. Nice work with the swap.
                        -Nick
                        Originally posted by 87e30
                        First of all: calm the fuck down; second of all; cool story bro.
                        • truekid
                          • Jan 2010
                          • 91
                          wow man, good work. really keeps me going on with my project.
                          • dsobering47
                            • Oct 2007
                            • 697
                            Grab a can of carb cleaner and spray over your vacuum lines. When your idle bumps up, inspect where you were spraying...should be pretty close to finding your leak. I had one where a hose was torn underneath a hose clamp, so wiggle and prod around a bit.
                            • daniel
                              • 6703
                              have you driven an m42 car before?
                              http://instagram.com/dslovn.drives
