My first e30: 1990 325is bronzit
  • mammoth_e30
    • Nov 2009
    • 818
    With that said, hello all! I’ve been on here a bit and read enough posts to know being a noob on here can be dangerous when it comes to making stupid comments and asking those types of questions, but sometime the most obvious things are harder to figure out.
    Anyways many of you have already helped me with a few things on my car and you have my thanks. When I purchased the car the guy had a lot of verbal info but some of it was hard to confirm before he flew off to his new job in Singapore.
    Anyways here’s my story et cetera, et cetera….
    Bought the car in September ’09 thru craigslist. I had read a lot about the bronzit color being hated on but when I saw the car something just told me it was a good place to start. At the time I didn’t need it as a DD and I knew it needed work but it was the best local one available at the time and was basically an impulse purchase. The car came with:
    226k estimated at 240k because odometer stopped
    5 speed conversion with 4.10 LSD (late model tranny)
    Vogtland sport springs
    Bilstein sport shocks
    Euro HID smileys
    Clarion headunit with 10" sub
    Momo steering wheel
    MarkD performance chip
    14” refurbished BBS basket weaves & 10mm rear spacers
    Pics are old, but the only exterior changes are my paint getting worse, fogs (no more racing mesh) and tires. Notice I have no pics looking down from above where all the clear coat is peeling away.
    The list of work it needed quickly grew once I took it to get it smoged. Bam! Exhaust leak, needed new catalytic converter, and more oil leaks than I had originally anticipated. At first I took it to a local BMW mechanic because I had very few contacts but have since started doing a lot of the basic work on my own or doing it with a friend. Here is what I have accomplished so far:
    Engine / Drivetrain:
    • New catalytic converter
    • Fixed exhaust leak at manifold
    • Oil filter housing reseal
    • Oil pan gasket
    • Oil Pressure sensor
    • Timing belt, water pump, front engine seals & drive belts
    • Alternator (after the new battery doh!)
    • Fuel filter
    • Clutch slave cylinder
    • Swapped for lower mileage 4.10 LSD (100k)
    • New spark plugs (NKG), distributor cap, rotor and coil (all Bosch) and Ireland Engineering wires
    • Replaced damaged AMF
    • K&N air filter
    Suspension / Wheels etc:
    • Pagid Red front and rear break pads
    • BavAuto Polyurethane Front control arm bushings
    • Replaced front passenger wheel hub
    • Falken RT-615 Tires
    • Replaced damaged basket weave
    Electrical:
    • New battery
    • Fixed odometer
    • Fog lights
    • Temp sensor
    • Misc switches replaced
    • 3 way Eclipse kick panel speakers
    • Went back to stock rear deck speakers (from clunky 6x9 boxes)
    • Replaced check light panel
    Interior:
    • Carpet cleaned (previous owner was a smoker)
    • Leatherette Sport Seats
    • Glove box latch fixed
    • E-brake center console replaced
    And the to-do list:
    Suspension:
    • Ireland Engineering (or comparable) sway bars & reinforcement kit
    • Ireland Engineering Front strut brace and possibly rear at some point.
    • Replace bushing as needed
    Engine:
    • Clean out the engine bay (looks like it may have never of been done)
    • Possible problem with power steering pump but still working
    • AC is acting up, need to address
    Electrical:
    • Fog light bulbs
    • Repair service indicator board
    Interior / Exterior:
    • Non-cracked dashboard
    • Euro grills
    • Replace pitted windshield
    • Clear coat from a previous paint job is quickly peeling away. When the car gets painted this summer I will do the following:
    • New IS lip (already in my possession)
    • Take the bumper trim and moldings back to black
    • Install and paint lower front valence (bent from curb before purchased, hence no lip either)
    • Repaint blacked out chrome due to half assed job by previous owner
    I am leaving many of the cosmetic items till this summer when I have got all anticipated mechanical deficiencies out of the way and have it prepped to be a DD/trackable car.
    I’ve really enjoyed working on the car and have become nothing short of obsessed compared with many of the other cars I have owned in the past, even sold my 2008 Acura TL type-S to give me more cash flow.
    Cheers!
    Brett k
  • Kershaw
    • 11822
    now thats dedication. quite a bit of work, good job.
    if you want to keep your speedo working semi correctly, use this for tire sizes.
    http://www.miata.net/garage/tirecalc.html
    AWD > RWD
    • Bimmerista
      • Nov 2005
      • 5425
      Looks like a very good platform to start on. As soon as you have maintenance completely aside, definitely consider painting your side & rear lower rocker panels.
      It'll freshen up the look of your car.
      • kronus
        • Apr 2008
        • 13028
        the fonts in this thread are trippin' me out. Congrats on having a bronzit with the shiny side still up :)
        cars beep boop
        • mammoth_e30
          • Nov 2009
          • 818
          Thanks, i like how that tire size calculator shows the width change as well.
          Yeah the more I look at things the more i want to paint the whole car, we will see.
          That font is a bit different as almost every post uses Veranda, I've always liked the arial narrow font. you ever hit up any of the socal meets? I was working with robmespeedy on saturday and somehow your name came up.
          • ak-
            • 12422
            A+ Brett.
            Looking forward to see the end result :up:
            & let me know if you want some fog light standard bulbs on the cheap.
            I have a brand new extra pair that I don't need, and my used ones that I won't be needing soon.
            1991 325iS turbo
            • Stephen
              Шлем ишака
              • 10774
              Looks good, good sir
              • kronus
                • Apr 2008
                • 13028
                I come out for some of the drives and Dockweiler meets... I'm kind of out of the way, but close to various San Bernadino Mountain Range-based activities if you head out that way at all :)
                cars beep boop
                • mammoth_e30
                  • Nov 2009
                  • 818
                  Originally posted by ak-
                  A+ Brett.
                  Thanks Abby, not sure if i need the bulbs just yet till i get the lower valence squared up as one of the lights is pointing straight down at the road at the moment. I will however be looking to hit you up on some euro grills when you get the next batch in!
                  Thanks Stephen. I've seen pics of your ride around, i'm definitely a fan of car.
                  lol that even further out than Riverside damn! I'm still new to these parts myself but if I make it out that way for a scenic drive i'll hit you up. if you end up by the beach, that's where you'll find me :o
                  • mammoth_e30
                    • Nov 2009
                    • 818
                    Update time
                    Kind of funning looking at what i wrote back in March and to see where things have gone. Here is a quick update as it has been a busy summer:
                    While my roommates were out of town one week i got my run of the garage and replaced the intake manifold gasket etc. as well as cleaned things up a bit with the power washer. Also deleted the cruise control, performed a valve adjustment, replaced a fuel line and other misc maintenance and gaskets.
                    Next I did a dash swap almost entirely on my own. ugh.
                    But it was worth it.
                    And my biggest project to date was a, e30 M3 5 lug swap. Lets just say i learned alot from this.
                    List of upgrades:
                    25mm master cylinder from an e32 735iL
                    Steel braided brake lines
                    ATE Super blue fluid
                    Yokohama Parada Spec-2's on BBS RC090 aka style 5's
                    M3 Control arm bushing
                    IE adjustable sway bar links
                    Vorshlag camber plates on existing Bilstein sprts and Vogtland springs
                    AKG reinforced front and rear swaybar link tabs
                    Reinforced trailing arm and differential tabs
                    BMP urethane trailing arm bushings (or whoever they buy them from)
                    Powerflex urethane subframe bushings (purple)
                    Z3 finned differential cover
                    New rear wheel bearings
                    I performed the better part of the removal and installation with my buddy Mo while Robert coordinated getting the welds done, installed the bearings, flanges and some other misc items.
                    I still need to finish up the brakes, bleed them and adjust the camber plates. Better pisc will be posted soon.
                    • einstein57
                      • Jun 2007
                      • 10780
                      I'm so jealous right now. So when are we gonnah start your turbo build?
                      www.gecoils.com
                      • ///M-TRD3
                        • Jan 2006
                        • 179
                        ^ Ditto.
                        Great Work Mammoth E30.
                        Einige Autos dürfen nicht runter gehen... einfach weil sie so spezial sind. - Wenn man von BMW's der '70 und '80 Jahre redet.
                        • dvck
                          • Nov 2009
                          • 3394
                          Nice NIce NIce NIce NIce NIce NIce.
                          i like it alot Brett, please say youre bringing this and not the ///M to Dockweiler.
                          • ThisGuy310
                            • Jun 2010
                            • 433
                            that diff cover looks so bad ass.
                            car is gonna look even better once the moldings are all fixed up.
                            also it looks like the camber plates installed fine so does that mean your front end is good, or will you not know until you get it aligned?
                            • mammoth_e30
                              • Nov 2009
                              • 818
                              Thanks guys.
                              Nigel i would love to do a turbo, def before an m-tech kit. i was thinking IS side skirts at least though. And yes this car is definately coming to Dockweiler. i may attempt to find a second driver for the M3 but who knows.
                              Moldings will happen before Dockweiler for sure. Camber plates are in good, but I have some serious camber as they are adjusted opposite of what i need. it needed an alignment before this swap and considering I just changed out all the bushings I'm going to get a 4 wheel done just to check things out.
