Good things come to those who wait...
  • e30polak
    • 6136
    That's right boys and girls, I finally got an e30 m3!!!!! 8-)
    INSTAGRAM: @UNDR8D_EMPIRE
  • trackjunkie21
    • Jan 2010
    • 3962
    Kurwa you lucky huj ;)
    Originally posted by Wh33lhop
    VANOS: sometimes you just need to go full retard.
    • e30polak
      • 6136
      Jestem bardzo szczesliwy huy! :p
      • xwill112x
        • Jan 2009
        • 4237
        nice score. i vote s54 turbo swap :-)
        • rj1790
          • Jan 2010
          • 108
          How much?
          • JZM3
            • Jan 2007
            • 557
            Congrats man!
            fail
            • Bimmerista
              • Nov 2005
              • 5425
              Did you steal it (as in get a bargain)?
              • Holland
                • Nov 2008
                • 7176
                nice score. i vote super outrageous engine that no one can afford with 2 superchargers and 5 turbos, swap :-)
                Fixed.
                Originally posted by DEV0 E30
                • Garageaholic
                  Freestyle Fabricator
                  • Dec 2005
                  • 5204
                  Sweet car. I want an M3 so bad. How much did you pick it up for? Post more pics!!
                  Recent Rebranding!!
                  E30 SM62/S62
                  E30 M60 V8
                  E30 M30 Big 6!
                  Instagram.com/garageaholic
                  Youtube.com/garageaholic
                  • e30polak
                    • 6136
                    Big plans for this beauty, here is the list:
                    1. Rebuild the current disassembled s14 in the car, and get it running like a champ.
                    2. Source an aluminum block m52 out of a z3, and build it into an s50/s52. The aluminum motor is 60 lbs lighter then the cast block, I will be running no AC, aluminum control arms, and a fiberglass hood to help negate any added weight up front.
                    Plans for the motor:
                    Schrick Cams
                    Euro s50b32 headers
                    Port and Polished Schrick intake manifold (out performs the low-end torque of the obd2 manifold, and outflows the m50 manifold up top)
                    Some mild head work to well with the cams, intake manifold and headers
                    68mm big bore throttle body
                    Samco 3" > 3.5" silicone intake boot
                    3.5" hfm
                    2-piece custom fiberglass airbox
                    Turner Motorsport underdrive pullies
                    RMS custom dyno tune
                    Stewart high-flow water pump
                    Driveline:
                    Either ZF320 5 speed, or a 6psd from an e46 M3
                    UUC 8.5lb Lightweight flywheel
                    Sachs race clutch
                    3.46 lsd, and a 2.93 lsd - each will serve it's own purpose
                    Suspension:
                    Already has brand new H&R race springs, and brand new Koni top adjustable shocks
                    Vorschlag camber plates and perches (already acquired)
                    Tree house racing lollipops (already acquired)
                    Aluminum control arms (already acquired)
                    Polyurethane: steering coupler, subframe bushings and rear trailing arm bushings
                    Reinforced rear shock mounts
                    Sparco front strut brace
                    Custom rear strut brace
                    22mm front/ 19mm rear sways
                    Wheels:
                    17x8.5 et13 BBS RZs
                    245/40/17 HANKOOK VENTUS V12 EVO K110
                    OR
                    18x8 front 18x9 rear Real Alpinas!
                    Brakes:
                    E36 M3 front brake conversion, with UUC slotted rotors, and EBC red stuff pads
                    Stainless steel brake lines all around
                    UUC slotted rotors and EBC red stuff pads in the rear
                    Ate Super Blue brake fluid
                    Exterior:
                    Properly sanding down and repainting the entire car Carbon Black (the super dark blue on the e46 M3 and the e39 M5)
                    Evo front lip, with splitter
                    Eurostop adjustable CF gurney flap and spoiler
                    Hopefully some AC Achnitzer mirrors
                    Plus much more!
                    • ZM Blue Devil
                      • Dec 2006
                      • 13836
                      Love it!!! What's even better is your plan. Going to be awesome!!! Congrats.
                      Levent
                      %20levent@gutenparts.com
                      Ladies:
                      • theox69
                        • May 2008
                        • 1732
                        Wow, congrats on the buy!
                        It's going to look even better when you're done with it!
                        you can have the keys to my hunk of 20+ year old West German steel when you pry them from my cold dead fingers.
                        • Dozyproductions
                          • Jan 2007
                          • 4682
                          ojezu! Masz piekne samachod
                          • JJe30
                            • 2044
                            Nice
                            • Chabs
                              • Jan 2010
                              • 538
                              I am Polish as well haha
                              And I agree, it's pretty nice..
                              Josh
                              http://www.r3vlimited.com/board/showthread.php?t=159843
