Just got some ebay springs
  • Wh33lhop
    • 11705
    Some stupid eibach springs
    Stock 325i motor
    Stupid ricer hot air cone filter intake
    Edit: after
    I tried going lower, but I didn't like how it looked, and it bottomed out a bit too much. I like where it's at now. I have yet to get an alignment, I'm going to match the front camber to the rear (probably about 2 degrees), max out the passenger's side caster and set the driver's side to .3 degrees less than the passenger's side, and run zero toe or very slight toe in.
    paint sucks
  • ubernasty
    • Jan 2009
    • 2749
    You threw 5 dead bodies in your trunk don't lie.
    • Wh33lhop
      • 11705
      Holy crap you're fast.
      paint sucks
      • Danny
        • 14217
        Cut a coil or two dude.
        • Kershaw
          • 11822
          that front needs to be lower.
          AWD > RWD
          • Wh33lhop
            • 11705
            Front will come down a little, honestly I wish I could raise the rear a bit.
            paint sucks
            • OBEY
              • 716
              add spring pads in the rear :)
              What's Crackiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiin?
              http://www.youtube.com/watch?v=ZnaiAh9hbzs
              http://www.youtube.com/watch?v=5SSh9an26Ac
              http://www.youtube.com/watch?v=vLgBCQUMOdo
              http://www.youtube.com/watch?v=BeasDMXRfGM
              http://www.youtube.com/watch?v=lhFVxnNmiIY
              • HarryPotter
                • Jan 2010
                • 3642
                Rears perfect, front needs to come down about 3 inches. Get out the blade.
                John F. Kennedy
                • Mossman
                  • Apr 2006
                  • 1961
                  If the wheels on the car behind you are made by enkei and he has 2 center caps buy/haggle/steal them for me I'll pay $25 each.
                  • Wh33lhop
                    • 11705
                    Spring pads present. Guess I could see if I could get some aftermarket ones somehow.
                    I probably should have held off posting a thread, but I'm going to adjust it tonight, when it's dark, and I was excited.
                    paint sucks
                    • StereoInstaller1
                      GAS
                      • 22679
                      That car be throwing leaves on the lawn, yo!
                      Closing SOON!
                      Thanks for 10 years of fun!
                      • xwill112x
                        • Jan 2009
                        • 4237
                        damn dude, reverse rake! mine is lowerr than that. cut a coil and a half up front and i think youll be set.
                        • Wh33lhop
                          • 11705
                          Updated with better pics.
                          Oh, and here are the Eibach springs. ;)
                          Rates are 450/600, UUC swaybars, 22/19mm with the rear set on soft. I'm looking for a way to use the current UUC endlinks with the M3 endlink tabs on the new struts.
                          paint sucks
                          • ak-
                            • 12422
                            You devil.
                            1991 325iS turbo
                            • Stephen
                              Шлем ишака
                              • 10774
                              not amused
                              amused.
