While changing valve cover gasket....
  • Jean
    • 18228
    Did an oil change and replaced the valve cover gasket as it was leaking a bit, and what did I find?
    so far so good... oh wait
    These hoses are only about 6 months or so old.... no wonder I could never get my idle to stay rock solid as it would sometimes fluctuate about 50-100rpms randomly.
    This is the icv to intake manifold hose, I could actually see it collapse while the engine running and noticed a crack in it.
    WTFBBQ...I got these from autohausaz, but this time around picked up a set from dealer. We'll see how long they'll last.
    So...check your hoses, they might LOOK ok but that's about it.
    Picked up a set of new ones, installed and idle is solid now!
  • N2MYE30
    • Oct 2007
    • 5536
    hmmmm....something else to look into.
    COTM
    • McGyver
      • 4636
      i broke that hose were it comes into the VC when i did mine. now it leaks a bit of oil and i'll fix it later.
      • 325ix
        • Aug 2009
        • 7783
        I need to check these as my idle has been off a little lately.
        • euroshark
          • Apr 2006
          • 3491
          I've had iffy luck with some of the hoses I've been getting lately too... I get everything from AutohausAZ but I'm sure they carry what everyone else does.
          • mikeedler
            • 6707
            looks like your "new" hose is already about 2 years old too. and seems it was made in the u.s.-- kinda odd to me.
            • Jean
              • 18228
              That's a picture of the 6 months old hose actually from autohausaz that failed.
              • Huff
                • 2488
                Funny, just did my valves and the same issue is happening to me. Hoses look fine and did the ol' carb cleaner spray trick, but it still seems like a small vacuum leak.
                Thanks for the justification to check those out again.
