The 15 Y/O Turbo M42 Build Thread (Now Holley EFI Terminator X Controlled)
  • trackjunkie21
    • Jan 2010
    • 3962
    #121
    Originally posted by Dj Buttchug
    checkin that soon. gonna have a few fittings made hopefully by the end of next week
    Sounds good, I'll definately be picking some up ;)
    Originally posted by Wh33lhop
    VANOS: sometimes you just need to go full retard.
    • SpoolnDaapex
      • Jan 2010
      • 150
      #122
      What spark plugs are you running?
      M42: Because 110 feels like 140 :finger:
      • Dj Buttchug
        • Jun 2010
        • 7636
        #123
        1 step colder than stock ngk
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • Dj Buttchug
          • Jun 2010
          • 7636
          #124
          spent some time diagnosing. tps resistance is 1300 ohm @ WOT Spec says no more than 1200... may have an issue here. also, i think my timing is off.
          Ig:ryno_pzk
          • Danny
            • 14216
            #125
            What are you doing for tuning?
            • Dj Buttchug
              • Jun 2010
              • 7636
              #126
              electromotive stand alone. 85lb injectors
              Im still on stock motronic right now tho.
              Ig:ryno_pzk
              • Danny
                • 14216
                #127
                Okay reading your thread, M50 injectors are 17lbs, not 19lbs that the m42 requires. You are DEFINITELY short on fuel on top of that you should be running at LEAST 24lb injectors, I'd say some 29/30lbs from a volvo would be better.
                If you want to run on stock motronic for a while it will work, but not well. Get some 24lb injectors with an RRFPR and run low boost.
                Also one of your coil packs could be bad.
                • Dj Buttchug
                  • Jun 2010
                  • 7636
                  #128
                  damn i thought m50s were 19... hmmm maybe i should put my stock injectors back in.
                  Im not worried about leaning out. Im running maybe 5psi if that. I want to get broken in at first but the car falls on its face after 2.5 3k rev.
                  checked the coils they are all good.
                  Ig:ryno_pzk
                  • Danny
                    • 14216
                    #129
                    CPS then maybe. But yes you should be very worried about leaning out. M42s run their injectors on the peak of over working, you add even as little as 5 psi and you'll be lean. WAY LEAN.
                    Believe me, I've done all of this.
                    • Dj Buttchug
                      • Jun 2010
                      • 7636
                      #130
                      yee ive seen your thread . Fuck. I have 940 turbo injectors. ill try them tomorrow.
                      what you mean peak of overworking? close to max duty cycle? rite?
                      Ig:ryno_pzk
                      • Danny
                        • 14216
                        #131
                        Yes, I just couldn't find the right words to describe it.
                        Also, are you just running straight up Motronic with no FMU at all?
                        • Dj Buttchug
                          • Jun 2010
                          • 7636
                          #132
                          Maybe thats my issue then. I swear its like theres no fuel as soon as WOT. fuel pressure is good to a 43psi
                          Ig:ryno_pzk
                          • Danny
                            • 14216
                            #133
                            • Dj Buttchug
                              • Jun 2010
                              • 7636
                              #134
                              ive driven almost 100 miles just around town under nothing but vacuum with nothing but stock motronic... RISkaay i kno but im not buyin shit im just gonna throw away when standalone comes aside from a fully adjustable FPR which i have not purchased yet
                              Ig:ryno_pzk
                              • Danny
                                • 14216
                                #135
                                Just get some fatty injectors and run hella rich then
