e30 m30 + OEM ITB test fit
  • Jb325is
    • 2137
    I haven't posted much since I finished my swap/ms conversion, but the car is finally running pretty smoothly. It has a couple issues like inconsistent idle (speed density + 290 cam, not easy) and it breaks up over 5k rpm a bit, but overall it is much faster and easier to drive than on motronic. Anyways, got these throttle body adapters through a friend of a friend, just about to start messing with them to see what it's going to take to get them to work.
    Quick mock up with the adapters-
    The thermostat housing outlet will definitely need to be modified, and the intake ports will need to be machined. I need to order all of the linkage/fuel rail parts to see what needs to be done there but it all looks fairly manageable from the research I've done. I think I'll probably run velocity stacks and filters at first, and look into building a plenum as a long term goal.
    The car still looks about to same
    A couple auto-x pics (taken by Shawn D)
    Here's dad losing it
    I'll keep this thread updated with progess on the itb's for those who are interested
    - '88 m54 coupe
    <3
  • Anguz
    • Jun 2010
    • 1394
    very very nice
    • kronus
      • Apr 2008
      • 13032
      S38 ITBs?
      cars beep boop
      • Jb325is
        • 2137
        Yep, I think they're off an e28 but I'm not 100% positive..
        - '88 m54 coupe
        <3
        • Good & Tight
          • Apr 2004
          • 2057
          That adapter looks top notch! That engine is going to rev so much faster.
          Not sure if you read up on MS w/itb's but you should make a vacuum canister to connect all of them to get a clean MAP signal. Had to do this on my M10 w/itb's.
          Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
          ____________________________
          E-mail Panayiotisx2@gmail.com
          Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
          • Jb325is
            • 2137
            Yeah I've read up on it a bit, I was thinking about changing to alpha numeric, but I guess you're talking about blended alpha N/speed density? The adapter is pretty nice, cost me $150 which I thought was pretty reasonable
            - '88 m54 coupe
            <3
            • Good & Tight
              • Apr 2004
              • 2057
              Mine was blended tps/map on boost though. Your na so alpha N should do the trick.
              Once you get it dialed in throttle response is going to be so crisp. These are going on the big bore you put together right?
              • Jb325is
                • 2137
                Yep, sure are. That's mainly what I'm after. I just had these throttle bodies laying around and stumbled upon the adapters, so I figured I'd see what happens
                - '88 m54 coupe
                <3
                • dannyyisntt
                  • 3141
                  Subscribed. I like this idea and want to see where this goes...
                  • e30m3s54turbo
                    • Jun 2010
                    • 3296
                    Nice! I seen those on a e9 at a bmw shop. They to have to mod. the thermostat an run ms.
                    • Massive Lee
                      • Sep 2006
                      • 6785
                      M10, M30, S14 and S38 share the same 100mm bore spacing. Great for swapping parts. Keep in mind that the M30 is a low end torque motor, unless you start swapping cam (like the Hartge motors, per exemple). The ITBs now have a much shorter intake path than the original manifold. Great for high revs, but very detrimental to the low end torque. Keep in mind the Helmholtz resonance effect. The shorter valve-to-butterfly distance will raise the resonance frequency (RPM). You can help fill the intake with much longer airhorns. Trying adapting the S14 trumpets...
                      massivebrakes.com
                      • Jb325is
                        • 2137
                        Yeah I've looked into resonance tuning a bit.. I know that I have a lot of work to do determining proper length for the air horns. I've found a few companies that make them and the dimensions for the throttle bodies seem to be pretty standard so there are lots of options. This engine is 10.5:1 with a 290 cam, it's already pretty peaky as far as m30's go
                        - '88 m54 coupe
                        <3
                        • dsobering47
                          • Oct 2007
                          • 697
                          thats hot. what suspension setup are you running?
                          • Jb325is
                            • 2137
                            550/750 Ground Controls
                            - '88 m54 coupe
                            <3
                            • JTDay
                              • Dec 2009
                              • 521
                              Awesome! Subscribed.
                              Past: 1987 325iS, Bilsteins - HR Sports
                              Present: 1999 M3, Koni Yellows - HR Sports - GC Camber Plates - UUC Swaybars - UUC SSK - AFE Intake - Stromung Catback
                              2009 Mazdaspeed3, Short Ram Intake - Turbo Inlet Pipe - 2nd cat Delete - Catback - Fuel Pump Internals - Cobb Accessport - Stratified E30 tune - 294/342 - SPC Camber Arms - CPE Rear Motor Mount
