^ thats AWESOME
Bay Area E30S52: No More Slush Box + More Horsepower
thanks, dom.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
89 E30 S52
Transaction Feedback.Comment
thats funking cool.
1983 Peugeot 505 STI
1992 Volvo 240 Wagon
2009 Toyota 4Runner SR5 Sport 4WDComment
thanks, man. now go out and do it.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
89 E30 S52
Got a pair of euro grills.
Sent from my HERO200 using TapatalkYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
89 E30 S52
but i'll keep on dreaming.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
89 E30 S52
Sound System Set Up
After hearing some great tunes on other rides, I got jealous and I am almost convince to bite the bullet on this.
So right now, i've retrofitted my 89 325i with premium speakers and it has an old Sony Xplod Cd/mp3 player.
Was thinking of chucking that old stereo and go with a more stock looking HU like the Nakamichi CD Player, my premium speakers and add
Earthquake SWS-8X under the seats.
What do you guys think? Should I replace the front component speakers with Boston Acoustics S50?Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
89 E30 S52
Maplight Rear View Mirror Retrofit
Take the Check Panel off
Take the current rear view mirror off by taking a screw driver on one side and pry it off.
Then run the wire behind the head trim panel and down the A Pillar, all the way down behind the speaker in the kick panel. Take the speakers off to access it and find the plug with the same colored wire.
NOTE: When prying off the A Pillar, make sure just pry off the top clip and then pull it upward so you don't break the bottom clip. I made it easier on me by removing the header trim panel.
NOTE: I took my header trim panel off so I can make it easier fishing the wire underneath it. It was a lot of work. If you don't know where the screws are, you could potentially ruin your headliner.
I took the sun visors off, then pulled the door weatherstrip off. Then open the sunroof and pried these off gently.
Then proceeded on taking all the screws holding the sunroof fairing.
Then take the 2 screws holding the header trim panel off.
I also took the door harness off so i could take the wire harness out from inside the speaker crevice. You can see it on my next 2 photos.
I straightened a paper clip and taped it on the wires so it won't curl up as I fish it down the A Pillar.
Here is the plug that I was referring to, plug the wire harness that you fish down and connect the two together.
Voila! Let there be light!
Then put everything back together.
There is an easier way to do this where you don't have to fish the line down the A Pillar. The map lights only needed 2 wires, the power and the ground so you can easily tap into another power line and ground.
I had the wire so I decided to just fish it down to make it look more stock.
Hope this help someone else.
89 E30 S52
Yeay, new tires, new tie rods, new control arms, new bushings, alignment... need camber plates.... uugghh, it never ends.
Next, rear subframe bushing, adjustable camber kit, trail arm bushings, diff bushing, then finally---new brakes.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
89 E30 S52
Had a nice time at Norcal meetYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
89 E30 S52
It's a US Plate filler.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
89 E30 S52
No More License Plate Ticket For Me
Last edited by bernzpeed; 12-17-2011, 10:19 AM.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
89 E30 S52
