Sr20det E30
  • E30RedtopSR
    • 202
    #46
    Originally posted by Killacortes
    i wish i had a stock turbo like the sr20det..instead of the nv m50 :(
    I hear ya. M50 is a good motor for sure, but I needed a lighter and more responsive powerplant.
    M50 swap was a little too common/simple for what I wanted to do.
    • ill roller
      • 191
      #47
      Originally posted by E30RedtopSR
      Rad is from the junkyard. From a Volvo 740 turbo. Aluminum 3 row. Compact, and was only 35 bucks. I have a slimline puller fan.
      Ahh, good stuff... I was looking into getting a mishimoto for an e36, but that sounds like a great budget option.
      • Dhohn
        • 111
        #48
        This is amazing, how bad was the wiring and what did you use for engine mounts?
        • E30RedtopSR
          • 202
          #49
          Wiring wasnt bad really, just lots of soldering. There is tons of harness diagrams/wire color breakdowns on the internet. If your not into it you can buy a standalone nissan harness from McKinney Motorsports. Its all labeled, trimmed and ready to go.
          Im a DIY guy, so I just sat down with it for a few days and took out all the stuff that isnt necessary for my application. It uses four wires to run. Positive Constant, positive switched, start signal, and temp input.
          Engine mounts and trans mounts are solid.
          • dball4
            • 560
            #50
            Already done suspension. Under hood is functional. not for show. its as clean as its gonna get, :)
            This man knows what he is talking about.
            1989 M3
            2008 135i 6sp
            • meano_lover
              • 55
              #51
              nice looking setup. i dig the a-w intercooler, mine is a-a.
              1984 318i
              sr20det swapped
              • E30RedtopSR
                • 202
                #52
                Liquid to air is bit more work, but it works so well, it's worth extra effort.
                • E30RedtopSR
                  • 202
                  #53
                  Just bought a new Borg Warner EFR 6258, top mount manifold and went to 264 cams. MOAR PoWeR!
                  • SimplyDope
                    • 1335
                    #54
                    I'm in love with your car. Good to see another insane swap in an e30.
                    • manjambles
                      • 125
                      #55
                      how far off were the sr's motor mounts from the stock e30's? did you build the mounts if not who did and for how much?
                      did you have to move the brake booster or move to manual brakes or was the stock one ok and fit?
                      are you using the e30 gauge cluster?
                      did you have to bang out the firewall at all?
                      • FunfGan
                        • Jan 2011
                        • 4958
                        #56
                        Sick build man! Im planning an rb26 swap, twin Borg Warner s600 turbos and so on. We'll see how it goes when Im not broke. But again, props on the build.
                        Go here be happy!
                        Ratchet Garage e30 V8 build.
                        • Pantless Spency
                          It's McRib time!!!
                          • Feb 2011
                          • 7283
                          #57
                          thats pretty nuts man!
                          but get that car bra off of there.... looks poopy.
                          • E30RedtopSR
                            • 202
                            #58
                            It keeps all the insects out of my heat exchanger,;)
                            • E30RedtopSR
                              • 202
                              #59
                              all depends where you want the motor to sit. Got the mounts already made, and no he wont make more.
                              I used the booster from a 2002ti. The e30 master fit. Had to extend the pushrod and modify the pedal arm.
                              Fuel gauge and speedo are all I am using.
                              Firewall was fine, tons of room
                              • twism
                                • Sep 2006
                                • 359
                                #60
                                Post videos already! And not cell phone ones please!
                                Looks good :)
