Its. Alive.
  • Joe G
    • 2945
    Its. Alive.
    Some of you may remember this fiasco: http://r3vlimited.com/board/showthread.php?t=187883
    So after receiving the car in November and having no place to really work on it (small garage and freezing cold temps) winter really yielded no progress. A week and a half ago i brought the car to a friends heated/well equipped shop and i began work on completing the swap, and there was a hell of a lot that needed to be done.
    Since Mike (guy who quit the swap halfway through) did a half-ass and didn't label any wires, hoses, clips, etc labeled i spent a ton of time guessing and searching. I also found many things missing all together or on just finger tight. There were bolts missing from the throttle body, oil pan, drive-shaft, fuel rail, fuse box, wire clips, intake mani nuts etc... There was also a mess of things that were done wrong all together some wiring was botched causing my harness adapter to burn up, along with the oil pan level wire.
    So hours of searching, PM'ing, and reading wire diagrams I got the harness adapter right. Then I went trough EVERYTHING with a fine tooth comb checking every oil pan nut, intake mani nut, coolant hoses, fuel lines, vacuum lines, etc... If i had to estimate I'd say i spent a good two full days going through every little thing making sure it was tight and right.
    Then when it was time to start the car i had no fuel, and no spark. So after some investigating it was determined that the fuel pump wasnt kicking on. I checked and re-checked the relays, grounds, etc... Danny suggested that maybe the DME chip was in backwards...and after all the crap I'd seen done wrong already i really wasnt all that suprised to see that the chip was infact backwards. After flipping it around the injectors were still not firing and there was still nno spark. So after checking EVERYTHING electrical again, I borrowed a known good DME and just like that the car fired up! Wohooo! The DME I borrowed has been rained on and is tuned for an M50 so the car is running like crap, but its running. I ordered a good DME from a member on here so as of tomorrow my car should be running right.
    I'm super stoked, all i need to do is get exhaust set up and clean her up and ill be good to go. Thanks R3v for all your help.
    Without further ado i give you my running open header S50.
    [IMG][/IMG]
    (Click for video, i suck at embedding)
    Current Car: 2011 BMW 135i, M-Sport, 6 speed
    Originally posted by lambo
    Sounds like you need a massage.
    Originally posted by kpeng
    Who the hell is Vlad?
  • Dj Buttchug
    • Jun 2010
    • 7688
    nice
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    • Reckless_Havoc
      • 156
      Congrats man! It's a great feeling when it finally fires up.
      • ck_taft325is
        • Sep 2007
        • 6880
        Damn nice.
        Need a part? PM me.
        • brutus87
          • 6280
          Glad to hear it worked out!
          • george graves
            • 20003
            Backwards - wow....
            Good job tracking that down. Right on man.
            Originally posted by Matt-B
            • E30AWDAZ
              • 399
              Sounds angry
              good work!
              • OhioriderAaron
                • 111
                Congrats, and hopefully there's a break in the weather this weekend so you can take it out
                Ohioriders.com
                OhioBimmers.com
                • DREWHALL
                  • Feb 2006
                  • 1207
                  Sweet. Good feeling isn't it?
                  • downernsp
                    • Mar 2008
                    • 1932
                    Looks good
                    • Wh33lhop
                      • 11705
                      Eeeeexcellent. Good work. :up:
                      paint sucks
                      • Joe G
                        • 2945
                        Only issue now is the Bad DME i just bought....ugh. Its always something going wrong.
                        • CabbE30
                          • Aug 2009
                          • 2358
                          Finally! Been following this since the beginning. Good job man!
