My temp drift car
  • shiboujin
    • Feb 2006
    • 2791
    My temp drift car
    Long story short, I'm rebuilding an S52 for the boosted real drift car. Since I don't want to miss any drift days, I bought back a car I had years ago.
    I originally bought this car years ago for $900 negotiated down to $600 due to what the PO thought was a bad oil pump. I dropped the pan, checked the pump, resealed everything and fixed the wiring on the oil pressure sensor. So I drove around this 1989 325i auto for a few months.
    Eventually I did a manual swap and sold it for a good profit. Then, a year later, the new owner decided he couldn't keep it and sold it back to me for $500. Can't get much better than that right? Chassis currently has 165k or so on the clock.
    The point of the car is to give me something to slide for this season for as cheap as possible. The wife is currently unemployed so money is tight. Meaning, I swapped over all the parts from the turbo drift car.
    Mods:
    Koni yellows front
    Mustang koni yellows rear
    12k front springs, 18k rear springs.
    E46 control arms
    E30 M3 front sway links w stock sway bar
    no rear sway bar
    3.73 lsd
    Kmac camber/caster plates
    17x8 xxr 006 w direzza star specs 215/45/17 front
    in the pictures below 17x9 006s with feddies 235/45/17
    When drifting I run 15x8 xxr 002 or 513s w 195/60/15 random tires
    25mm spacers all around
    5mm tie rod spacers (hence the spacers)
    THR lollipops
    solid bushings in the rear
    75d trailing arm bushings
    No engine/drive train mods
    I had to raise the car more than I wanted to since this chassis doesn't have the flares and such and the spacers make it look a bit mexi poke but it drifts like butter. So far I've done a couple drift days and an NCCA autox with no issues.
    Exterior shots
    Greasy underside lol
    OMG an interior!
    Stockity stock stock engine bay.
    Not Janderson pretty/clean obviously. At least it gets my track day on.
  • LuckyHenriksen
    • Jun 2010
    • 4244
    What seat is that? I like it
    Bahama Beige E23 Project
    Bluebird Bus Conversion
    New Oregon Trail
    • LJ851
      • 7919
      Not Janderson clean, but it does run, and on the first page of the thread no less! Well done it looks like fun.
      Lorin
      The M30 is God's engine.
      • shiboujin
        • Feb 2006
        • 2791
        Sparco fighter seat. I'm not sure they sell it anymore. I've got a wide ass so it doesn't fit skinny people.
        • ck_taft325is
          • Sep 2007
          • 6880
          It's fitting.
          Need a part? PM me.
          • Mikhail Bakunin
            • May 2011
            • 126
            Dude. You drift? For real? Man - that's awesome. I know not anyone can do that. It's not like just anyone can go out and drift. You should be proud. That shit is tight.
            • shiboujin
              • Feb 2006
              • 2791
              http://www.youtube.com/watch?v=03oMyV4YbEU vid FYI.
              • Jalves619
                • 596
                What's the story on the e46 CAs? Is the geometry similar to stock, 96+ M3, or entirely different?
                • shiboujin
                  • Feb 2006
                  • 2791
                  Here is the write up I did a long while ago on the control arm swap http://e30performance.info/viewtopic.php?f=34&t=1006
                  It's a 90 degree angle unlike the stock >90. I'm not sure what the 98 M3 control arm angles are. I'm not sure if this works as a sub for the 98 m3 ones for the 5 lug swap. It also adds about an inch and some change of width in the front. Without spacers for the rear, it'll look funny.
                  • Mullet Bullet
                    • May 2011
                    • 904
                    nice work, one question. on the stock engine are you kicking the clutch to break traction?
                    Originally posted by nwvb bmw
                    That guy is going to lock you in his basement and make you ware a little pirate costume.
                    • CleanAzzE30z
                      • Jan 2004
                      • 11794
                      I remember when drifting was seen as a second rate automotive-figure-skating on this forum. How things have changed. Not necessarily for the better or worse, just different. ;) I like seeing how things evolve.
                      • shiboujin
                        • Feb 2006
                        • 2791
                        Yep mostly clutch kicking. The stock M20 doesn't have enough power to keep the tires spinning that well so I have to persuade it most of the time. If I drive fast enough, I can get it to slide naturally but most of the time if I have enough space.
                        There still is plenty of hate and people that have no idea what it is. *shrugs* I have fun at it.
                        • Court M3
                          • Jan 2004
                          • 6713
                          Yoshi and his dirty cars!! Purpose built, but needs some clean every once in awhile.
                          Continuous For Sale Thread
                          323i s50
                          • AE_m20
                            • 548
                            Good shit man, I'm a big fan of your craft
                            88 325iS(Cam'ed m20)
                            P2 S60 Daily
                            IG: @ratherbefisting
                            • Dj Buttchug
                              • Jun 2010
                              • 7680
                              welp im sub'ed
                              Turbo M42 Build Thread :Here
                              Ig:ryno_pzk
                              I like the tuna here.
                              Originally posted by lambo
