Cloudbase's E30 - '89 325i, BBS RGRs, E21 Recaros
  • Cloudbase
    • 1795
    I've been bringing my E30 back to life for the past 10 months, figured it's time to share it with the community. Rather than post a big build thread I thought I would finally post some pics of my E30 as it stands now with a list of what's been done and what's not. I'll update my Fixed and Not Fixed lists as I go.
    There is an abbreviated build w/ 100+ pics on my blog HERE. Plus two previous threads showing my rear end body work HERE and front end body work HERE.
    My plan for this car is a clean DD w/ a few light mods. I already have an M Coupe for the track, higher performance, etc. I have to say I love the E30 just as much as the M Coupe. It brings a smile to my face every time I get to drive it.
    Condition When Purchased:
    The Good:
    1989 325i
    Alpine White / Tan Interior
    195,000 Miles
    Manual
    Rebuild Head
    Motorman Injectors
    Bav Autosport Ignition Wires & Coil
    New Thermostat
    New Drive Belts
    New Water Pump
    New Cooling Rubber
    The Bad:
    Erratic Idle / Random Stalling / Hesitation
    Soft Brake Pedal
    Missing Front Lip
    Black Marks on Front Bumper
    Crack Fog Light
    Foggy High Beam Lens
    Peeling Clear Coat on the Roof
    Faded Roundels
    Faded Black Trim and Mirrors
    Cracked Rear Bumper Trim
    Whinny Diff
    Excessive Drive Line Vibration
    Bad Wheel Bearing
    A/C Doesn't Work
    Multiple Lights in Overhead Check Panel
    Check Engine Light
    Brake Lining Light
    Blown Stereo Speakers
    Tape Deck Does Not Work
    Cracked Driver's Seat
    Bad CV Axle
    Dry Rotted and Cracked Bushings and Rubber throughout the Car
    Leaky Transmission
    Coolant Leak
    Power Steering Hose Seepage
    Sagging Jammed Sunroof
    Fixed:
    Engine:
    New Fuel Filter and Rubber Lines
    All New Vacuum Lines
    New Throttle Body Gaskets
    New Throttle Position Switch
    Repositioned AFM Wiper Arm
    Replaced ECU
    New Ground Strap
    New ECU Coolant Temp Sensor / Cluster Temp Sensor and Connectors - Erratic idle / hesitation finally fixed!
    Replaced Crank Position Sensor - drive belt sawed through the old wire
    Cleaned Oil Level Sensor
    Replaced Coolant Level Sensor
    Replaced Washer Fluid Level Sensor - finally a dark check panel
    Transmission and Driveline:
    All New Shifter Bushings - shifter felt like a spoon in a bowl of spagettie
    Z3 1.9 Short Shifter
    New Transmission Output Shaft Seal
    New Shift Selector Seal
    Rebuilt Drive Shaft
    New Flex Disc
    New Center Bearing Carrier
    New Centering Sleeve
    Replaced Whinny 3:73 Open Diff w/ Quiet 3:73 LSD
    New CV Axles
    4 New Wheel Bearings (see brakes)
    Brakes:
    Multiple Pressure and Manual Bleedings before and after ABS activation
    SS Brake Lines
    2 Used Known Working Replacement Master Cylinders
    New Pads and Rotors
    Rebuilt Calipers
    BRAKE PEDAL IS STILL SOFT - SLOWLY GOES TO FLOOR WITH LIGHT APPLICATION. NO FLUID LEAKS. WTF!?
    Suspension and Steering:
    H&R Sport Springs
    New Spring Pads
    15mm Drop Hats
    Bilstein Sport Shocks
    New Front and Rear Shock Mounts
    New Control Arms (first FCP then Lemfoerder)
    M3 Offset Control Arm Bushings
    New Front and Rear Sway Bar Links
    New Front and Rear Sway Bar Bushings
    New Subframe Bushings
    New Trailing Arm Bushings
    Z3 2.7 Lock to Lock Rack
    New E36 Tie Rod Ends
    Wheels and Tires:
    17" BBS RGR Diamond Black Finish
    New Dunlop SP 2000 Tires - bought from sketchy dude behind Safeway for $300
    Exterior:
    Repainted Front Valence, Bumper, and Bumper Trim
    New IS Lip
    Ryan G Splitter
    Euro Washer Smiley Projectors (just need a control unit and the kit will be complete)
    Repainted Euro Grills
    Replaced Cracked Fog Light
    Yellow Laminx High Beams and Fogs
    New Roundels
    Replaced Cracked Rear Bumper Trim
    Repainted Black IS Trunk Spoiler
    Blacked Out Kidneys
    Color Matched Tinted Side Mirrors
    "I'm the stig" sticker - my wife got if for me
    Interior:
    Cloth E21 Recaros (driver's side is being recovered, using passenger for now)
    Suede Dash Cover
    M Tech I Steering Wheel
    M Coupe Lighted Shift Knob
    ///M Stitched Suede Shift and E-Brake Boots
    Leather E-Brake Handle
    Naturel Ski Pass Rear Seat
    Map Light Mirror
    Home Made Cup Holder - made from PVC pipe couplings
    Escort 9500i Radar Detector
    iPhone Holder
    Not Fixed / Future Plans:
    Soft Brake Pedal
    Jammed Sunroof
    Glazed Windshield
    No A/C
    Cracked Dash
    Blown Speakers
    Poor Stereo
    Peeling Clear Coat on Roof
    Alpine iDA-305 Stereo
    New Speakers
    Light Tint
    Black Door Pulls and Map Pocket
    Finish Headlight Washer System
    Bike Rack w/ Red Rocky Mount Trays
    Winter Wheels and Tires
    JOY IS AN E30...
  • Simon S
    • Oct 2004
    • 3758
    I love what you've done with the place.
    -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
    • leegf
      • Dec 2010
      • 1168
      looks great. nice job!
      E46t
      • Ramgoat
        • Jun 2010
        • 832
        Love, Love....LOVE IT!
        try you brake booster for "soft" fix.
        send directions on pvc pipe cup holder mod. ......please?
        feedback?!
        4x100 32mm Wheel Spacers $70 Shipped
        • Cloudbase
          • 1795
          Thanks Guys.
          The brake booster along with a brand new master cylinder is the next step on the soft pedal problem.
          The cup holder is pretty ghetto. It's the Walmart one that has a long fin on the bottom to squeeze between the seat and the console. I cut the bottom of it off so it's flush and screwed it to my console (my console was pretty beat up so I didn't care about screwing into it). Then I used the PVC pipe couplings as cup extenders. They fit really well.
          JOY IS AN E30...
          • brutus87
            • 6280
            Lookin good!
            • gverelli
              • Dec 2008
              • 772
              Good work! I like the Stig sticker lol
              G.Verelli
              • 1mz
                • Jan 2009
                • 641
                diggin the cup holder made of PVC couplers - do you have pictures of assembly?
                http://l0st0n3.mybrute.com
                http://l0st-0n3.mybrute.com
                Work in progress: 1991 318i m50 swap
                Feedback thread :up:
                I prefer having a female in the car at all times. They generally smell good, but you do have to put up with that hole in their face.
                • CHIF8008
                  • 3447
                  lookin fresh. Mmmmmmm its so clean haha
                  -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
                  -The Beauty in the Tragedy-
                  MECHANIC SMASH!!- (you all know you do it)
                  Got Drop?? ;-)
                  But of course
                  E30s are know to be notoriously really really really ridiculously good looking
                  • AE_m20
                    • 548
                    Cars like yours make me consider color matching my lip. Well done sir
                    88 325iS(Cam'ed m20)
                    P2 S60 Daily
                    IG: @ratherbefisting
                    • cabin
                      • Dec 2006
                      • 552
                      Car looks great! Only thing I would change is getting rid of either the yellow fogs/highs or the amber turn signals. Both the yellow and amber make the front end too busy IMO.
                      -Justin
                      Current: BMWless for now... '15 Grand Cherokee & '03 Mach 1
                      • Cloudbase
                        • 1795
                        My plan is to do smoked indicators, euro trim, and smoked low beams, but that's a ways off.
                        I'll do a mini write up of the cup holder here in a bit.
                        JOY IS AN E30...
