'87 327is
  • EtaSport
    • 2853
    '87 327is
    Engine bay is extremly dirty, havent had the will to clean anything yet. Motor runs but I need new injectors, 6 m50 units on the way.
    Engine is 87 eta (short block) eta head with porting, 274 cam, dual valve springs, but still have eta valves. 9.0:1 compression, Motronic 1.1 153 ecu. 2.93 rear.
    You can see the wires I spliced from the c104 to c101. The white wire is going to injectors 135. For some reason they weren't working through the harness so I hard wired them. Ive got to tie up all the loose ends before its road worthy though. I've got b25 valve cover going on soon as well.
    Sorry for large pics didnt feel like resizing. Big thanks to ely for all his help.
    Old and improved:
    • 37834
    Nice work man, glad to ehar you got it all sorted out.
    How high do you figure you can rev that motor?
    Grover Beach, California
    BimmerHeads.com
    • EtaSport
      • 2853
      Thanks, I am too.
      I would feel better running it to a max of 6k probably, although I'm sure it would be okay to 6700. The botton end has a lot of miles on it.
      Old and improved:
      • DEV0 E30
        • Oct 2004
        • 8904
        You sure were battling her every step from what it sounded like.
        Great work.
        • M42Technik
          • 9781
          Dammit now you can keep up with me.
          :P
          I gotta see it now!
          Reminiscing...
          • EtaSport
            • 2853
            :P
            I gotta see it now!
            haha.. yea man. We'll have to have a mini meet here sometime soon. I've got to get my car all cleaned up again, it looks like crap.
            Dont know if mikey is going e30 or not, the civic's transmission is on its last leg!
            Old and improved:
            • reelizmpro
              • 9559
              Now you just have to get rid of that 2.93 to really reap the benefits. A 3.46 or even 3.73 would be sweet.
              88 M3 - LACHSSILBER
              89 M3 - ALPINEWEISS II
              • thejimlab
                • Oct 2004
                • 588
                I think maybe you need to take a peek under the hood of my car for a clearer definition of "dirty"
                • etajohn
                  • May 2005
                  • 79
                  How did you achieve the 9 to 1 compression?
                  Thanks.
                  • EtaSport
                    • 2853
                    Thanks.
                    eta head with eta pistons, eta crank, stock 9.0:1 Just a tad over the b25s 8.8:1
                    The port work on the head is very close to an i, so the only major difference is the size of the valves. Someday I may swap a 731 head from a 323i and see how that works out.
                    Took the injectors and rail off today and cleaned them real good. No improvement. I think 1 and 6 arent working at all, I cant hear a click with a screw driver to my ear on those 2. I really hope I can get these injectors soon, ebay guy didnt respond to my email... yikes
                    Old and improved:
                    • EtaSport
                      • 2853
                      Another update, went to the yard on friday and found me an 89i, so I pulled 4 injectors off and swapped out 1 and 6. I still dont think im 100 percent there yet, but wow. Power from idle all the way up. No torque loss, plently of hp. I dont know how high I've reved it yet, but there really is no need to wind out the gears, it just goes.
                      Throttle response isnt to great, I think the injectors I have on it are a little far gone, or could be leaking. All this should be fixed when I put the m50 injectors in. My mpg gauge isnt working so I'm not sure how fuel milage is effected yet. Seems like I dont have to be on the gas near as much to get it moving, but I know its using a good bit more.
                      If you own an eta you MUST do this. Cost effective if you are mechanically skilled, and very beneficial. I've got around 700 dollars in parts, and I didnt have to use that 274 cam, could have went with a 325i or a 323i.
                      Old and improved:
                      • T.Dot E30
                        • Mar 2004
                        • 536
                        Why do you call it an 'is?
                        • The Fast One!
                          • Jul 2005
                          • 856
                          car looks awesome man. you have to take some new pics with the new valve cover on it it looks soooo much better then that current one. p.s. was tring to get a hold of you today. might have found an e30 in virginia. look in the general discussion thread for the car. but i'll call you about it when i get off work.
                          Mike Fritz
                          • EtaSport
                            • 2853
                            for fun. 6600 rpm redline, motronic 1.1, I cant really call it an e anymore, so ill call it a hybrid.
                            Bosch 17.5lb 4 pintles went in today, took care of the throttle response.
                            Old and improved:
                            • PeaveyBassist
                              • Sep 2004
                              • 3511
                              So basically an eta with dual valve springs, a 274 cam, and porting identical to the 'i' head right?
                              Will
                              RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
                              Welcome e30 (brilliantrot '90 325is) 12/23/06
                              DaveCN = Old Man
                              My signature picture was taken by ME! Not by anyone else!
                              If people keep quoting me in their sig, I'm going to burn this motherfucker down.
