Rescue Dog
    Where in Vancouver are you? You should stop by sometime.
      needs SOME type of rear valance. got that mustache look- like a lot.
      good work with fab'n up the aluminum mounts. plenty of people will be PM'ing you like crazy for sets.
      but other than the above, looking good man
      -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
      -The Beauty in the Tragedy-
      MECHANIC SMASH!!- (you all know you do it)
      Got Drop?? ;-)
      But of course
      E30s are know to be notoriously really really really ridiculously good looking
        Progress report
        Let's do it.
        Lift
        I recently replaced the drive shaft for the auto so I'll use the front half from the manual with back half from the auto. Hope it doesn't vibrate.
        Lining up the parts for the install. A couple of R3V members really came through, wodcutr hooked me up with the single mass flywheel and clutch and E30darkknight had the clutch return spring I needed for the pedal box. I just started the swap last Saturday and I have the parts in hand. Thanks.
        This is a beautiful sight, the messy auto is gone. At on point during the removal I had a 3 x 4 foot puddle of ATF on the ground.
        The top bolt also proved problematic, the first application of torque resulted in the socket slipping off the bolt, I was frightened at that moment. I followed up with a thorough investigation involving flashlights and mirrors. I reapplied the socket and Franken-extension with a big hammer to make sure it was firmly seated on the bolt shoulder and was rewarded with a satisfying crack as it broke loose. Needless to say that bolt will not used for the install.
        Got Pedals?
        I did the pedals first because I thought that was going to be the hardest part. It was hard, remove drivers seat and plant your feet on the rear window, be patient. I practiced the move on a car at the pull yard before I did mine. Recommended, I did a lot of damage on the first one.
        Notice the kick down button under the accelerator, that's got to go.
        Tomorrow is more prep work, main seal replacement, cleaning, wiring and lining up some help for the install. Maybe 280z Bob is watching and will come over on Friday.
        I still have the parts car and plenty of parts plus the 2.7 block if anyone is thinking about building a stroker.
          Where are you ?
            Originally posted by F34R View Post
            Everything looks great! Just dislike the lip on the es valance. But that is just me
            Same, just lower it to achieve more low. The es valence may look good with the lower section painted black.
              Not an ES valence;)
              OP you are my hero. One of the only peole on here who is doing an early model car/ valence right. Plus, bending that aluminum is genuis!
              Yours truly,
              Rich
              you kids get off my lawn.....
                Thanks, I haven't done anything except return to stock condition. The only non-stock parts on the car are the Eibach lowering springs and KYB shocks. I got lucky and the engine runs great with just normal maintenance.
                Two weeks ago when I was buying the parts car I was cruising south on I-5 and moved to the left lane to pass some traffic, thumb and forefinger on the wheel. I glanced down at the speedo....90 MPH!
                Oops, better back off a little, I love this car.
                  for sure. I love how the e30s just cruise.
                  2014 Alpine White 335i MSport
                  (Daily Driver)
                  Full Mperformance Aero
                  KW V2 Coilovers
                  VRSF Catless Downpipes
                    Done
                      That is awesome.
                      Originally posted by DEV0 E30
                        Originally posted by Farwest92 View Post
                        Where are you ?
                        West side. Felida area.
                          Wow. Awesome work, and it looks like you're doing everything right. Huge props, man.
                            Thanks. The swap was pretty straightforward. There is plenty of information out there.
                            Having a parts car in the driveway was a big plus. The donor car had a 173,000 on the clock but the transmission felt tight and the fluid was clean so I am optimistic.
                            After I put it back on the ground I took a test drive around the block which ended up being about 50 miles. The car drove and shifted perfectly, the transmission is smooth and quiet. Now I have to learn how to drive it, I only killed it once and missed two shifts.
                              East side. Sifton area.
                              Vantucky FTW
                                Update
                                It's been awhile since my last post, I've been busy driving it like I stole it. The cars a blast to drive since the 5 speed swap. I did notice a little movement in rear axle and have replaced the subframe and control arm bushings and followed up with motor mounts. Now the car is tight and chirping gears, breaks loose on command in first or second and is frankly, a better car than I am driver. The only areas for improvement are a rumbly idle and a slight hesitation on the throttle.
                                With that in mind I went through with the normal routine of vacuum leak elimination and yada,yada,yada let's check the injectors.
                                Shouldn't be too difficult, relieve fuel pressure, disconnect fuel lines, unbolt fuel rail and slide it out. Yeah, got three of the injectors and a bunch of dirt.
                                The intake runners had at least a 1/16 inch of crud, residue build up from crankcase.
                                Downstream of the injectors was clean.
                                How she sits, until tomorrow.
                                Time to attack, notice my weapon of choice, a toilet scrubber cut off on one side.
                                I was able to achieve full penetration using Simple Green, various de-greasers and finally a hot detergent bath. It's a dirty job, I should have called Mike Rowe.
                                I did an Ohm check on the injectors and replaced the o-rings, used some air to blow out the filters and am optimistic that it will run better than before.
                                I hope this cures the idle and response and maybe a little more power.
