DD 318i project build
  • FunfGan
    • Jan 2011
    • 4958
    #46
    Lookin good man! I agree you also need some subtle pink effect somewhere... And a chip ;)
    Go here be happy!
    Ratchet Garage e30 V8 build.
    • Dj Buttchug
      • Jun 2010
      • 7683
      #47
      for those interested in some JOM pics.
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • Massimo
        • Jan 2008
        • 3207
        #48
        Decent
        Adjective: 1. Conforming with generally accepted standards of respectable or moral behavior.
        • Dj Buttchug
          • Jun 2010
          • 7683
          #49
          Originally posted by Massimo
          Decent
          precisely
          Ig:ryno_pzk
          • bmwstudent
            • Sep 2011
            • 1364
            #50
            does it flood near your house a lot? YOur neighbors house has a dirt ring around the bottom.
            • Dj Buttchug
              • Jun 2010
              • 7683
              #51
              ^ sprinklers...
              Ig:ryno_pzk
              • camip
                • Nov 2011
                • 1253
                #52
                You should work for the CIA you don't miss a thing lol.
                • Dj Buttchug
                  • Jun 2010
                  • 7683
                  #53
                  So if you have JOM and you want to get rid of the rear rake heres what you do.
                  cut exactly this much off the springs, install with both upper and lower spring pads, no adjuster. sketchy but it works.
                  Ig:ryno_pzk
                  • ak-
                    • 12422
                    #54
                    I think you put the front adjusters on incorrectly. I remember when we put them on my friends car, we did it like that too then fixed it; making it sit lower.
                    1991 325iS turbo
                    • Dj Buttchug
                      • Jun 2010
                      • 7683
                      #55
                      how else would they go on? Did the threaded sleeve sit lower on the strut than mine pictured?
                      I dont think its wrong. shit. maybe it is but i cant see how else it would go on
                      Ig:ryno_pzk
                      • ak-
                        • 12422
                        #56
                        Yeah. The sleeve sat lower. They put it on like that, then it looked awkward to me so I took a whack at it then fixed it so it sat lower on the weld/cut perch.
                        1991 325iS turbo
                        • Dj Buttchug
                          • Jun 2010
                          • 7683
                          #57
                          how can it sit lower. the threaded sleeve threads into the insert piece that holds the shock in the actual strut...
                          FUUU im confused now. i need pics ak!
                          Ig:ryno_pzk
                          • ak-
                            • 12422
                            #58
                            He sold the car last week ]:
                            I can explain it in person D:
                            1991 325iS turbo
                            • Dj Buttchug
                              • Jun 2010
                              • 7683
                              #59
                              fuck it. engine out just to clean it. like a boss
                              timing case overhaul tomorrow.
                              Ig:ryno_pzk
                              • timofeylbelarus
                                • Dec 2010
                                • 326
                                #60
                                Likd a boss, pull every engine u get and least clean it and make it look good
                                1985 325e - wrecked :( (being fixed and full paint job)
                                http://www.r3vlimited.com/board/showthread.php?t=197989
                                the horrible day
                                http://www.r3vlimited.com/board/showthread.php?t=210850
                                1991 318i - in process of being made a DD
                                http://www.r3vlimited.com/board/showthread.php?t=219793
