''La Quiche'' E30 S54 - Alpha N - BBS E50
  • Jim Lepage
    • Jul 2008
    • 1138
    #256
    Originally posted by LJ851
    That Really sucks, Jim.
    Is that igor from Catuned ?
    Nope from Korch Motorsports in Ontario.
    Don't send your car to be serviced there, lol.
    E30S54 - Scale Suspension / Unix Performance Coilovers - 17x8 and 17x9 BBS E50
    • Jim Lepage
      • Jul 2008
      • 1138
      #257
      I forgot to update my thread. It finally runs like a champ ! ! ;D
      I had multiple misfires and it was running like crap, stalled randomly and wobbly idle. I tested the fuel pressure and it was fine. Then I checked the coil packs. 4 of them were discontinued in 2005, 1 was from 2009 and the other wasn't listed for the S54.
      One more time, nice servicing seller of crap.
      I put 6 new Bosch coil packs and the 2nd TPS (actuator one, itb's one was new) since I had some self test fail codes.
      It's already winter here since mid November but I had a chance to try it last week and OMFG, that's so much power and throttle response ! :devil:
      The Garagistic 2nd diff support is a really good upgrade. I feel how tight the rear end is now. It really makes a difference !
      I worked all summer and spends a shit load of money but it worth it, I can't compare it to the chipped M50 I had. It's too much of an upgrade, the sound, response, rpm range, power gain, etc
      Here's some pictures I found in my iPhone.
      • 2mAn
        Señior Mod
        • 20975
        #258
        Is it tucked away for the winter?
        Simon
        Current Cars:
        -1966 Blue Boat
        -1969 Red VW
        -1986 White BMW
        -2006 Green Thing
        Make R3V Great Again -2020
        • spiDmang
          • 3941
          #259
          Congrats on getting her complete!
          God's engine is the S54. Welcome to heaven
          91' 318iS - S54/6MT Swapped
          08' E90 M3 6MT - Daily
          Originally posted by IronJoe
          Originally posted by 2mAn
          • Jim Lepage
            • Jul 2008
            • 1138
            #260
            Yes.
            You'll have to wait till 2018 for a Cotm feature. ;)
            • Echo30V
              • Sep 2017
              • 301
              #261
              Yes, that S54 engine is super special. I was extreme melancholy when I sold my E46 ZCP M3 and watched that S54 drive off.
              • FredK
                • 14762
                #262
                Congrats!
                You must be antsy waiting until next Spring to really rip on it! Any plans over the winter?
                • Jean
                  • 18228
                  #263
                  Hi,
                  Amazing build, as many have already said , so just repeating ;)
                  Glad to see you were able to mend the engine issue and carry on!
                  Mine isn't s54, but similar power , and I know what you mean when you are saying you can't compare it :) it's such a huge difference that will require relearning the car !
                  Congrats again !
                  • Jim Lepage
                    • Jul 2008
                    • 1138
                    #264
                    Originally posted by FredK
                    Congrats!
                    It's stored outside on jackstand under my carport so I can't really work directly on it. By chance we have snowboard to help to pass the cold season !!
                    -catch can is not installed. Everything is gonna be clean and good looking again on that side.
                    -rpm is not working since 2016. I think I'll buy a refurbished SI board with fresh batteries. I'm pretty sure it's the cause.
                    -interior needs some work. I have to better fit the ECU and put back the glovebox. I'd like to have a black carpet. Black headliner too. Maybe a new steering wheel.
                    -I may start a custom rollbar
                    -during the winter I want to buy an AKG mono wiper conversion kit.
                    -body needs love in the battery area and lower rear valance.
                    -I had to add 3mm spacers for the front brake to fit. I want to lower this to 1.5mm if possible.
                    -I need to cut the clutch slave rod a bit. I had to use a Z3M flywheel/clutch/pp combo to keep my G260 and this combo is farter from the engine so closer to the slave. At first my tranny was making all sort of noises I never heard. It took me some time to figure out what was the cause of that. It was always a bit disengaged, very slightly. I tested by shimming the slave but I think it wasn't enough. I'll fine tune it next year.
                    There's probably many other things I forget, like taking time to enjoy it and going to car shows !!! :D
                    • getouth
                      • Jan 2010
                      • 3343
                      #265
                      Any updates 🤷🏽waffles♂️
                      FEEDBACK:
                      http://www.r3vlimited.com/board/showthread.php?t=316212
                      BMWCCA #398608
                      IG @yagayo38
                      "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
                      • 3MPowered
                        • Nov 2014
                        • 58
                        #266
                        This remains one of my favourite threads to check up on. I love everything about it. Keep up the posts!
                        Avusblau 1994 M3 - DEAD
                        Lagunagrün 1991 331iS --> Journal Here
                        • Jim Lepage
                          • Jul 2008
                          • 1138
                          #267
                          Not much, winter is at it's climax here. I must have 4-5' of snow in my backyard and snowboarding is still so fun !
                          I just sent a payment to Bavarian Restoration for a complete refresh and some add-ons to my cluster. I'm shipping it Monday after work.
                          • Jim Lepage
                            • Jul 2008
                            • 1138
                            #268
                            Thank you !
                            I'll keep the thread alive, don't worry.
                            • 2mAn
                              Señior Mod
                              • 20975
                              #269
                              Thank you !
                              You need to keep me posted when the car comes out of hibernation
                              Simon
                              Current Cars:
                              -1966 Blue Boat
                              -1969 Red VW
                              -1986 White BMW
                              -2006 Green Thing
                              • Jim Lepage
                                • Jul 2008
                                • 1138
                                #270
                                Yes ! :up:
                                I have some things to finish first. I also want a mono wiper and my rear bench need to match the black tweed and patterns of my front Recaro.
