Plain ol' '88 325i sedan...or should I say 333i
    ...that I adopted from Bob (chadthestampede)
    Before...
    A bit better
    oooh look
    My yard is getting ridiculous.
    E30 buildy things
    http://www.r3vlimited.com/board/showthread.php?t=195286
    E30 buildy things
      I miss this old fuck already
      Originally posted by LJ851
      Feedback
        thats a real 333i?
        swap car?
        or have u been spending time in South africa?
        1989 325i SETA stroker [delphin] R3V'd 8/31/2011
        1989 325ix [zinnoberrot] $OLD
        1970 2002 [Nevada]
        Originally posted by Herr Faust Schinken
        guy must have slid into something that doesn't look like a car vs car hit
        Originally posted by ak-
        Must of slid into Rob
          ^ LOL. Great starting point! I WANT that rear seat!!
          -Erik
          Originally posted by 87e30
              Haha GOD DAMMIT! Why would you have to show me that?? I'm trying to SAVE money! lol Fuuuuu!
              -Erik
                You shouldn't. She dumped some coolant yesterday (not sure where it came from), drips oil from everywhere, and today, she wouldn't start but then she did and was running really rich with plenty of smoke coming from the exhaust all while doing some soft consistent popping (sort of a chug) at idle.
                But...she's still fucking awesome.
                E30 buildy things
                  Originally posted by Robotin View Post
                  thats a real 333i?
                  swap car?
                  I drove it back to NY from South Africa, it was a ton of fun.
                  E30 buildy things
                    loool. Did you change out that fuel pump relay yet? I think that might be part of it. The fuel pump could be on it's way out too for all I know. I have an extra one if you need it. The coolant temp sensors on these things are moody, and if there's air in the system like I think there is that could be part of the problem. Which brings us to our next topic...
                    Make sure the bleeder screw is tight, I think I just hand tightened it when I was bleeding it. Chances are there's still air in the cooling system and it might be dumping coolant out the overflow. It holds something outrageous like 15 quarts of coolant so I'm almost completely sure there is still air in there.
                    It never dripped a whole lot of oil when I had it, I hope I didn't pinch the o-ring when I put the filter housing back on. I'll give you the b35 housing soon which will make it a ton easier.
                    Also as far as I know this is the only b32 swapped e30 around. I had that on japandrew, at least my 333i was really 3.3 liters (well 3.2 anyway).
                    Feedback
                      I havent changed the relay yet. I will soon.
                      I will check the bleeder screw. The coolant drips from the passenger side frame rail about 4 inches behind the CAB.
                      Also, after idling for anly about 5 minutes (after cold start), the temp gauge suddenly pegged max heat. But, I'm pretty sure the temp was actually fine.
                      Also, I think you mentioned that there is an engine block (m20?) in a basement somewhere in Buffalo. Let me know the details if you can, because I'm thinking of making an engine block coffee table.
                      E30 buildy things
                        131 Richmond. Probably still there unless they cleaned the place out which I don't think they did. Who knows who lives there though.
                        Feedback
                          hmm, maybe I will check it out.
                          E30 buildy things
                            Front struts dropped.
                            Blah blah.
                            E30 buildy things
                              Bilsteins installed all around
                              E30 buildy things
