Just Bought My First E30
  • ClayW
    • Apr 2011
    • 377
    I tackled the dash replacement this week. The wife and I found a salvage yard dash with only two small cracks for $37. That's not a bad deal, since our existing dash looked like a dried up riverbed. The previous owner's temporary fix for this was a fitted dash carpet piece, the velcro for which he apparently glued onto the dash.
    Forgive the poor lighting.
    So, I set about disassembling the interior of the car. There are slightly more electronics in an E30 as compared to the 1600.
    Removed the A-pillar trim. It's nice that these are vinyl-covered plastic that pops off easily instead of glued-on vinyl, like in the 2002s and 1600s.
    Next came the emergency brake trim piece....
    ...and the shifter surround....
    ...under which I discovered some 29 cent stamps. FYI, first class mail was 29 cents from February 1991 through January 1995. You didn't know that.
    After a lot more disassembly, the dash was out.
    Here is the old and the new(er), which was cleaned up a bit.
    I snapped the VIN tag off the old to swap to the new.
    I also painted some pop rivets for reattachment.
    And here it is bolted in.
    Note that you have to pull out the A/C diffuser and route this part of the wiring loom over the ducting.
    Stereo and HVAC panel in.
    And finally all back together. It's much better without all the cracks. It was a bit of work, but compared to the cost of a 2002 dash, this one was a steal.
    I also replace the non-operational antenna with this $45 Hirschmann 2040 replacement power antenna. It came with a bunch of parts for multiple applications.
    I just cut the wires and soldered them to the old connectors.
    Mounted in the trunk.
    1987 325e Commuter Project Blog
    1967 1600 Project Blog: www.TX02.blogspot.com
    • ClayW
      • Apr 2011
      • 377
      I have a pretty constant oil leak coming from the front passenger side of the motor, just above the head gasket, so I dove in.
      Here's where I started:
      I removed the valve cover and this little retainer bar thingy.
      Then I removed the four rocker shaft plugs.
      Here they are next to the new ones. I'm hoping that the fact that these were a little wet means that replacing them and the valve cover gasket will seal up the leak. If it turns out to be the cam seal, I'll have a lot more work in front of me.
      Retainer bar back in.
      Now it's time for a rocker adjustment. I used a bent step feeler gauge and set them dead to between .024" and .026" with the engine dead cold.
      I also used a little yellow model paint to mark the rockers that I adjusted. For those of you who haven't yet tackled this task, don't think that you can just remember which ones you've done as you adjust.
      Then, I replaced the valve cover gasket. I also painted and sanded the valve cover, because the oxidized aluminum wasn't very good-looking.
      • Ginsterman98
        • Dec 2012
        • 89
        Its like my twin almost, how did get the paint to come back? mine is faded like yours. Specifically tools and products used.
        84 318, 86 325ES, 85 325E. 89 325IS,
        89 BMW 325is Turbo - 8.02@85mph 1/8th
        90 VW Golf, 01 VW TDI Jetta
        98 VW GTI VR6 - 11.679@117.58mph Timeslip
        96 VW GTI VR6 - 7.63@97mph
        www.lugtronic.com
        • Vivek
          attention whore/retard/bitch
          • 6167
          Originally posted by GodIse30
          No, some forum members want them. I believe someone is looking for one right now. (He has a totaled black e30/mint white e30 in his sig)
          Sounds like RUFFLZ, PM him OP.
          1992 Mauritiusblau Vert
          2011 Alpinweiss 335is coupe
          2002 540i/6 Black/Black
          2003 GSX-R 750 (RIP)
          • sweet3
            • Oct 2012
            • 752
            The dome light only coming on when the door is around 1/3 open is normal. When you figure out the braking problem let me know. I replaced my disks and pads and I still have a grinding noise under light braking.
            PNP Adapter Harness Wiring for M52TU, M54, S54, M60, M62, M62TU, S62, M50, S50, M52, S52 & MORE
            • ClayW
              • Apr 2011
              • 377
              The dome light thing was a broken wire in the door harness in the hinge area and was fixed with the Red/Black wire fix.
              I replaced the brake discs and the shutter went away.
              • ClayW
                • Apr 2011
                • 377
                Cam Seal Replacement
                After determining that my constant oil leak was likely flowing from the cam seal, I ordered the parts and dove in. If you replace this seal, you'll need the O-ring also.
                Here is where I started:
                Drained the coolant:
                Removed the radiator bracket and hoses:
                .....and removed the radiator, leaving the shroud in place. Radiator first, shroud second.
                If you remove one of the water pump bolts, you can get a crescent wrench in there to remove the fan clutch and fan. Otherwise, you'll need a thin 32mm wrench. They're cheap and available at bike shops, but the one that i ordered hasn't yet arrived.
                The next trick is to use an oil filter wrench to remove the water pump pulley bolts.
                I removed the distributor cap next. I also took off the crank pulley, only to realize that doing so was unnecessary for the cam seal. If you're doing your timing belt, you'll need to remove it, so I guess that I was just practicing.
                Then I removed the upper timing belt cover. According to the PO, the timing belt was replaced less than $5K miles ago. It looked fine, so I decided not to bother with it.
                You'll need an E12 star socket to remove the cam gear.
                Here is the source of my leak:
                Be careful pulling the seal carrier out.
                The cam seal looked to be in relatively new condition, but the O-ring on the carrier was certainly older than it should be.
                Here is the new one:
                Even though it looked fine, I popped the cam seal out and pressed in a new one.
                Now to put everything back together. Replacing the belts is really easy with no radiator in the car.
                The car came with a new-in-the-box fan clutch in the trunk. The one on the car was made in China and the replacement is a German-made Sachs clutch. Note the mechanical difference.
                New fan clutch installed.
                And all back together. Hopefully I can now park without marking my territory.
                • I<3BMW
                  • Jun 2012
                  • 121
                  Originally posted by ClayW
                  The odometer logged 211K before grinding up it's gears. I ordered the gears already.
                  Where did you order the gears for your odometer??!!!
                  • ClayW
                    • Apr 2011
                    • 377
                    Garagistic is your trusted source for high-quality BMW performance parts, specializing in E30, E36, E46, and more. Discover custom-engineered components, from suspension upgrades to drivetrain solutions, designed to enhance your BMW's performance. Shop now for fast shipping, expert support, and unparalleled quality.
                    Just remember to order the right gearset for your cluster (VDO or Motometer).
                    • I<3BMW
                      • Jun 2012
                      • 121
                      www.garagistic.com
                      Awesome.. Thanks!
                      • 4drPwr
                        • 370
                        Nice choice of E30 (5spd four door) and nice to see a new owner going about work in the right way. Congrats and good luck!
                        86Zinno
                        • I<3BMW
                          • Jun 2012
                          • 121
                          www.garagistic.com
                          Maybe this is a dumb question.. but how do i tell the difference?
                          • I<3BMW
                            • Jun 2012
                            • 121
                            NVm
                            • getouth
                              • Jan 2010
                              • 3343
                              ^^ look at it. it will tell u . lmao!
                              FEEDBACK:
                              http://www.r3vlimited.com/board/showthread.php?t=316212
                              BMWCCA #398608
                              IG @yagayo38
                              "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
                              • I<3BMW
                                • Jun 2012
                                • 121
                                yeah... I figured that one out haha
