I tackled the dash replacement this week. The wife and I found a salvage yard dash with only two small cracks for $37. That's not a bad deal, since our existing dash looked like a dried up riverbed. The previous owner's temporary fix for this was a fitted dash carpet piece, the velcro for which he apparently glued onto the dash.
Forgive the poor lighting.
So, I set about disassembling the interior of the car. There are slightly more electronics in an E30 as compared to the 1600.
Removed the A-pillar trim. It's nice that these are vinyl-covered plastic that pops off easily instead of glued-on vinyl, like in the 2002s and 1600s.
Next came the emergency brake trim piece....
...and the shifter surround....
...under which I discovered some 29 cent stamps. FYI, first class mail was 29 cents from February 1991 through January 1995. You didn't know that.
After a lot more disassembly, the dash was out.
Here is the old and the new(er), which was cleaned up a bit.
I snapped the VIN tag off the old to swap to the new.
I also painted some pop rivets for reattachment.
And here it is bolted in.
Note that you have to pull out the A/C diffuser and route this part of the wiring loom over the ducting.
Stereo and HVAC panel in.
And finally all back together. It's much better without all the cracks. It was a bit of work, but compared to the cost of a 2002 dash, this one was a steal.
I also replace the non-operational antenna with this $45 Hirschmann 2040 replacement power antenna. It came with a bunch of parts for multiple applications.
I just cut the wires and soldered them to the old connectors.
Mounted in the trunk.
