Another 5.0 build: #projectmerica
  • ballski
    • Jun 2012
    • 345
    #241
    cut the stock flares out and that was sad and scary. primed the new flares twice, ready for color and clear.
    ordered my tires: 215/40 and 265/40 out back :)
    driveshaft is in and fits perfect. I had to use a couple washers on each mounting point of the diff to the subframe since the DS hit at the top a tad
    Current Moneypits: e36 m3/4/5 Turbo Techno
    1961 Cadillac deVille bagged -
    IG @bryang513
    • eurotrash
      • May 2007
      • 768
      #242
      Do you have the jackstands under the subframe? Noticed my ds hit when lifted from the subframe (dif also) but not when on the tires. My bushings are shot though i guess so that could be why but take a look when its on the ground just in case.
      Also if you cut the rear flairs out remember its unibody and u'll need to weld ghat juction back up.
      • ballski
        • Jun 2012
        • 345
        #243
        I have the jackstands on the pinch rails so hopefully it won't move much once it gets on the ground.
        And yes, I noticed that there's a hole now, shit. O well
        IG @bryang513
        • eurotrash
          • May 2007
          • 768
          #244
          You have to weld it back up. Basicly you can fan out the inner fender and weld it to the outer then fill it with expanding foam and weld the slits in the inner fender.
          • IronFreak
            • Dec 2012
            • 3702
            #245
            I think you need some aluminum heads......I have a GREAT deal on a pair or very newish Edelbrock RPM's
            Instagram @rebellionforge
            • ballski
              • Jun 2012
              • 345
              #246
              why are you getting rid of em? What kind of deal? lol
              IG @bryang513
              • ballski
                • Jun 2012
                • 345
                #247
                I didn't take pics, but I got a lot done last week.
                I ran the water lines and filler, got a new belt on, alternator on, radiator in, some wiring ran, brake lines made and ran, super blue fluid and bled the brakes, Wilwood slave installed, fuel lines ran and holley FPR installed, wheels finished, tires came and installed....
                265 on a 10" out back
                IG @bryang513
                • Exodus_2pt0
                  • 5943
                  #248
                  True salesman right there!
                  No E30 Club
                  • IronFreak
                    • Dec 2012
                    • 3702
                    #249
                    MMMMMMMM Buddy, that just looks right!! Great job this is coming together nicely!!
                    That's how I roll, This cat ^^^ needs the complete package, don't skimp on the heads, the do the engine good!
                    • IronFreak
                      • Dec 2012
                      • 3702
                      #250
                      Btw............
                      Flares flares flares flares flares flares flares flares flares flares flares flares flares flares flares flares flares flares flares flares flares flares flares flares flares flares flares flares flares flares flares flares flares flares flares flares flares flares flares flares flares flares flares flares !! :hitler:
                      • ballski
                        • Jun 2012
                        • 345
                        #251
                        i know i know lol
                        can you see my side exit exhaust too??? lol 2.5" off headers into a 3" Y, then Magnaflow muffler
                        IG @bryang513
                        • IronFreak
                          • Dec 2012
                          • 3702
                          #252
                          Ha! yeah now that I look again I do!! That's awesome, mine will be similar.....but not...
                          • FunfGan
                            • Jan 2011
                            • 4958
                            #253
                            lol exhausts
                            Looks awesome man! Coming together.
                            Go here be happy!
                            Ratchet Garage e30 V8 build.
                            • dmoney(AB)
                              • 1372
                              #254
                              this looks great!
                              American muscle meets euro style
                              I like it!
                              running adapters for the wheels?
                              mtech1/2jzgte/r154/275tire
                              function>form
                              • ballski
                                • Jun 2012
                                • 345
                                #255
                                Originally posted by dmoney(AB)
                                this looks great!
                                I like it!
                                thanks and yes sir
                                IG @bryang513
