my 1986 4-door delphin
    so many ramz
    miss u bby
    '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
      Originally posted by AbsorbantNut View Post
      so many ramz
      miss u bby
      And soon to have another set ;) come up to h2o wit da crew
        Figure I'd update this post
        After attempting to do the head gasket I found a bunch of welding wire in the cooling jackets of the head and block.. It looked as if the PO stripped the trans bolt and attempted to drill it out, and drilled all the way into the block, then tried to weld the hole.. In the process it burned up the headgasket and clogged a cooling jacket with welding wire..
        So after no luck with find a spare motor the car sat and sat until I started getting hounded by my landlord that the car needed to be gone or towed...
        Then the part out began.. Suspension, wheels, mtech wing, valence, euro grilles, headlights.. All the goods...
        Sat for about 6 months like this
        Even offered it to a friend for FREE if they towed it away.. No luck
        So after awhile of selling parts, saving money, waiting for a decent car to come up to buy.. My landlord told me it needed to be gone.. After some sleight negotiations I got a time limit to get the car running and driving.. I found a BMW guy in VA selling an m50 vanos, emailed him and he called me two days later, I put a deposit on the motor and picked it up with my work truck the following week.
        Also found a craigslist deal on some headlights and floor mats
        In the mean time my friend Jason aka AbsorbantNut helped with sourcing some suspension bits in Florida. He found me a pair of strut housings and offered to weld collars on the housings.
        Suspension ended up as billy sports with shortened bump stops up front, eBay adjusters, and 4" 2.5id 400ld landrum springs, turner Motorsport fixed camber plates
        And KYB adjustable camaro shocks, shortened eBay adjusters and 4" 2.5id 600lb springs for the rear
        Car got brand new FAG hub assemblies, Febi tie Rod assemblies, new rotors all around
        I had the idea of what I wanted the car to look like, I missed my 16x9s and the way the car sat at this time
        I came across the D240s and saw they started making them in 16's and offering 4x100.. I placed an order with CCW with brushed clear faces 16x9 et10 all around... And the anticipation began..
        With all the suspension in place and waiting for wheels to arrive I began pulling the old motor out and replacing all necessary seals on the m50. Vanos oil line, oil filter housing gasket, valve cover gasket, rear main seal, air intake gaskets etc.
        Swapped the oil pan, pickup, dipstick. All clutch accessories and starter. Technique I found online to get the pilot bearing out, stuffing wet paper and packing it in until it presses it self out... Takes about 10minutes and works great
        Connected all the sensors and hoses, Bolted up the headers and the trans already had fresh fluid in from the last swap.. And prepared to drop it in the car
        Motor went in fairly easy with a couple swear words and the help of CondorSpeedShops 24v swap motor mounts
        Connected the harness adapter I had made from a guy on eBay from the first swap. Works excellent no issues. Everything came labeled with instructions on hooking up the speed sensors inside the car and back of the cluster.
        Came home from work the next day to this...
        Had to test fit them immediately lol
        Also I forgot I took advantage of $100 coupon from discount tire direct(I think?)
        With the motor running, focused on getting the drive shaft back together, and noticed my csb is in two pieces. I ordered a new one from Autozone and got it the next morning.
        Wired up a cheap aux fan with a switch to the inside to control temps manually..
        Bled the radiator and got a KN cone filter from Autozone car is running great, noticed a small drippage from the water pump so that be replaced along with the housing when the thermostat sensor is put in for cluster temp
        Got the tires mounted
        And on the car
        Still needs a bit of tidying up. But it's looking like a car again
        Sorry, we couldn’t find that page
          Damn back at it again. Hitting that snooze button on Jurt & Koe potstir
            From the brink and back! Nice work.
            AWD > RWD
              Anti_Snooze
                Thanks man!
                  Updates! When are you scooping the parts car
                    Hopefully soon. Just installed the thermostat for cluster temp and currently in the middle of rebuilding the cluster with 7k tach to match with the swap. Photos to come..
                      Ran into a dilemma with the cluster turns out I ordered the wrong 7k tach I assumed all VDO tachs would be the same but I should've read up more because there's a late model 12/87 and early model 12/85 and they aren't interchangeable AT ALL unless you want to attempt some kind of wire snipping and soldering wizardry... So I contacted Bav Rest to try and get the right one, and also looking at replacing the erratic temp gauge. That seems to only want to work at its own convenience...
                      Anyways..
                      Got skid plate on.. Since this RaceSkidz plate was intentionally built for an m20 car I manage to make it work Using two m10x120 bolts and a stack of washers to clear the pan for the steering rack side and one m8x120 with a few washers and a copper pipe sandwich to space it off the core support for pan clearance.
                      Did a quick DIY alignment and took it for the first official test drive.
                      Don't wanna jinx anything.. But it ran almost too good..
                        That skid plate isn't going to do squat mounted like that... those washers stacked like that... no beuno. One hit and you could easily shear off the bolts holding them. You should really re-think that! The one in the front is also not going to work. Need to cut out that rust and weld something up there to reinforce it!
                        But those wheels... works of art dude!
                          That's what I was thinking and all that work gone if it gets stuck and rips it off disconnecting your steering rack. I'd try to get the proper skid plate.
                            Beautiful, have seen your car on Instagram a few times with the Style 5 setup (which was my favorite). Congrats on getting her back on the road!
                              Originally posted by florida_dirt View Post
                              Anti_Snooze
                              Anti-snooze boy Fr!
                              Car looks great! loving the wheels :up:
                                I totally agree with you dude.. When I bought the skid plate from a forum member on here, it wasn't described as a modified m20 one, so I just made it work for the time being. Thank you!
