My second e30 build/resto. (S52)
  • cbouchez
    • May 2007
    • 2789
    #106
    Very nice!
    Follow my IG @bouchezphotography
    • e30de89
      • Sep 2006
      • 197
      #107
      Here are a few more pics of what I did
      Shade headliner
      Green 89 325 s52 build: http://www.r3vlimited.com/board/showthread.php?t=280902
      • e30patalohas
        • Mar 2012
        • 44
        #108
        Really glad you are finding the time to work on this project. It will feel great to actually get this back on the road to be dialed in! Life happens and projects are really never "completed" are they. Looking forward to future updates and an action shot or two. ;D
        • Den_k321
          • 1248
          #109
          i like the color, where in Seattle area are you?
          1988 325is S50 in-progress.
          http://www.facebook.com/E30LocalCrew
          Few pictures:
          http://www.r3vlimited.com/board/showthread.php?t=255061
          • e30de89
            • Sep 2006
            • 197
            #110
            I'm in lynnwood. I was wondering if there were ppl with swapped cars near by to see how their cars runs. My fuel pump or fuel pump relay seems to be acting up. Sometimes it works great. And sometimes it like goes on and off. Or it will just constantly run. This is all before I actually start the car. When it sits for a while it does this and it takes a while to get it fired up.
            • 2mAn
              Señior Mod
              • 21005
              #111
              Originally posted by e30de89
              Had to have the back of the air box so it clears the alternator
              E36 Maf sensor on e30 air box.
              Im halfway through doing this myself, what did you use to adapt the MAF to the airbox? Thats the last piece Im hung up on.
              also, what did you use to glue the box back together on the bottom?
              Simon
              Current Cars:
              -1966 Blue Boat
              -1969 Red VW
              -1986 White BMW
              -2006 Green Thing
              Make R3V Great Again -2020
              • e30de89
                • Sep 2006
                • 197
                #112
                I used a soldering iron. And it's all basically plastic welding. The maf is installed into original tube that was cut off of e36 intake box and welded on to e30 box. I also used epoxy putty from pep boys to glue it on the inside
                • e30de89
                  • Sep 2006
                  • 197
                  #113
                  Can someone tell me if their swapped car does fuel prime for 3 seconds when key is in on position?
                  • e30de89
                    • Sep 2006
                    • 197
                    #114
                    Installed new turn signal and wiper switch yesterday along with new ignition switch that came from euro e30 and had to be modded. Also changed spark plugs and coil boots.
                    Turn signal comes with an extra light that goes into the cluster
                    Had to take those pins from my old ignition switch and solder into the new one. And also swapped the door buzzer switch from the back of the switch.
                    Old boots
                    New stuff came in
                    Waiting on more parts. Next will replace fpr and rebuild the injectors. Hopefully that helps my rough start problems
                    • NYCDelphin
                      • Aug 2016
                      • 223
                      #115
                      wow... the skill... the confidence.. the thoroughness.... i am impressed.
                      • ThatOneEuroE30
                        • Dec 2013
                        • 8626
                        #116
                        Great build! Good work man
                        1991 318i 4dr slick top
                        Mtech 2 turbo restoration
                        • Mr. Wolfe
                          • Jul 2014
                          • 540
                          #117
                          I will be starting my journal soon. It will share many similarities to this one. Total repaint in a unique color is the big one along with an engine swap. My color is a little lighter than yours and a little more blue. Great color by the way and look forward to seeing this to completion.
                          Mr. Wolfe
                          • e30de89
                            • Sep 2006
                            • 197
                            #118
                            Installed 8k rpm sticker from bavrest. And a coder chip from e28 m5
                            • e30de89
                              • Sep 2006
                              • 197
                              #119
                              Mr. Wolfe
                              That's nice , good luck to you with your project. It's definitely a money pit ! I started with 5k budget for mods and now over 20k.
                              • Mr. Wolfe
                                • Jul 2014
                                • 540
                                #120
                                You are definitely correct, it is not cheap. I am doing a full Mtech 1 conversion as well. Excited to get started. The M62 swap is complete and the engine bay is painted - that's it.
                                Mr. Wolfe
