My White girl
Whenever I have electrical problems, the first thing I do is remove anything ADDED the car. So if BMW didn't install it, remove it. That alarm you mentioned and any aftermarket stereo need to be checked closely or removed. IIRC the tach and the stereo share one of the same fuses.
If windows are the problem, start by changing the switches from side to side, the switches are known to gum up, so press them hard and don't give up easily... check the door harness (located between the door hinges) the wiring plug that can get corroded, pull that apart and inspect. If both of those seem OK, it probably the motor itself.
Hard starting....Check crank position sensor, the wire is routed near the water pump pulley and if it's not secured properly it will get cut by the pulley.
To diagnose fuel issues, pull the supply line and crank, If no fuel, you need to check the fuel pump relay. I use a jumper wire to bypass the relay just to see if I can get the pump running.
Vaccum leaks are common as well, check the large intake boot very close and any other vaccum hoses, since the car came with an intake manifold in the trunk, it's guaranteed that someone has been taking stuff apart before you.
G/LComment
and welcome to r3v! like everyone said, it'll be expensive and stressful. but a blast in the end.
but mostly expensive and stressfull..sigpic
@joshua.j.rizo
Originally posted by SpasticDwarfJust remember next time you hear "late night when you need my love" I'm gonna be sitting somewhere way more bitchin' than you, driving or not.
BUY MY BUGATTI WHEELS:
http://www.r3vlimited.com/board/showthread.php?t=377693
WRITEUP TO MY RHD SWAP:
http://www.r3vlimited.com/board/showthread.php?t=371904Comment
The alarm is gonna be removed once i get the car to work again. Im going to get a cps today and see what happens.Comment
I think I've seen this car in East Brunswick by the Acura dealer on rt18 when it was still for sale. If it's the same car, how much did you buy it for if you don't mind me asking?Comment
the body is basically the only good thing about the car. as soon as the car is capable of doing a burnout... im doing one on his lawn. [jk, i cant be that rude]Comment
so.. im looking for a CPS. are there two? one in the bay and one on the bell housing? or am i crazyComment
garage queen 91 bmw 325is / 1972 Chevy El Camino 355 sbc 450hpComment
uhh it was for sale behind seville diner on rt 18. the acura dealer is a little farther up 18. i paid a grand for it.
Cheap BMW's are the low hanging fruit and ultimately more expensive than just buying a nice one. The sense of accomplishment is such a huge payoff when its all done. Bringing a car with a foot in the grave back to its former glory and allowing it to live another 20 years is awesome.
This car reminds me of the Early model Alpine on cardinal I bought for $800 with no compression from a kid who had single-handedly taken a 1 owner e30 and turned it into a pile of shit over a two year period. His stereo install was the worst I have ever seen, limo tint on all windows, chrome stick on trim on every fender arch and window, honda offset 17" wheels that rubbed the inboard section of the fender as they must have been et50, thank god he never ever decided to pop the hood and go to town. When the fuel pump finally died he was driving on 3 cylinders with a horrificly bad wheel bearing, cracked brake rotors, and totally waffled center support bearing. He said "yea dude just change the fuel pump and it will smog fine" as he lied through his teeth. I sent him a picture of the finished product with a waffles waffles you for all the ish you lied to me about. I'll share some before and after over the 3 month period I restored it.
Work commences:
Redying the seats with $150 in dye and leatherique and about 20 hours of labor
3 Months and $3800 later
The original single stage alpine paint can be cut an polished to perfection no matter how bad it is:
I will strongly urge you to keep your Cardinal interior with this photo of the finished product:
I sincerely hope this inspires you. After the restoration the car was sold to my friend who has never had to do more than an oil change and basic maintenance for over two years now, rock solid reliable and timeless looks.Last edited by Wild Ride; 09-28-2013, 11:59 PM.Comment
