pulled my m20 and getrag this weekend so i can sell them.. will upload some pics of stuff when i get a new account set up elsewhere. still want to go set the servers on fire at photobucket
SLC: 1989 Zinno coupe. Superlight, Super Functional *6spd swap inside*
IG: @mitchlikesbikes
motoring along...
Untitled by mitch allen, on Flickr
more progress recently. reinforced my subframe with the tabs from garagistic. also added a piece of steel to the bottom of it because it was a little beat up from the floor jack. also got my throwout bearing from ECS so i was able to stick the engine and trans together for a test fit. got the engine/trans set in the car on the motor mounts to figure out what i needed to do as far as a trans mount. i determined that with the e90 trans bracket bolted to the trans i just needed to extend the crossmember to make up for the extra length of the 6spd (garagistic makes a kit of laser cut brackets to do this but i made my own because im a hillbilly on a budget). i also had to fill the original holes for the trans mounts and drill new ones about 1/2" inward on either side to line up with the trans bracket. i am currently waiting on two orders of parts. one from FCP euro with my clutch slave cylinder, and 2 t studs for the trans bracket (i'm adding extra mounting points to ensure the extended trans mount holds up). the second order from ECS tuning has all of the components for the shifter and my e34 throttle cable. here are some photos along the way:
Originally posted by mitchlikesbikes View Postmore progress recently. reinforced my subframe with the tabs from garagistic. also added a piece of steel to the bottom of it because it was a little beat up from the floor jack. also got my throwout bearing from ECS so i was able to stick the engine and trans together for a test fit. got the engine/trans set in the car on the motor mounts to figure out what i needed to do as far as a trans mount. i determined that with the e90 trans bracket bolted to the trans i just needed to extend the crossmember to make up for the extra length of the 6spd (garagistic makes a kit of laser cut brackets to do this but i made my own because im a hillbilly on a budget). i also had to fill the original holes for the trans mounts and drill new ones about 1/2" inward on either side to line up with the trans bracket. i am currently waiting on two orders of parts. one from FCP euro with my clutch slave cylinder, and 2 t studs for the trans bracket (i'm adding extra mounting points to ensure the extended trans mount holds up). the second order from ECS tuning has all of the components for the shifter and my e34 throttle cable. here are some photos along the way:
got my ultra dope ebay chip in. this is also good because it bypasses ews and my ecu is a silver label 413.
ordered ground controls during their black friday sale, got those earlier this week but they forgot my o rings for the front adjuster sleeves so i'm still waiting for those before i can get going with the coilover install.
i test fitted the shift carrier for the 6 speed that needs to be shortened and determined i needed to section out about 1" to line the shifter up in the hole in the tunnel. i did the cutting then had my friend brad (edutechnic) weld it up since i don't have the skills or equipment to weld aluminum yet.
Originally posted by wworm View Postlookin good! those subframe reinforcements seem like a super good idea
Originally posted by jeenyus View PostGonna be cool!
ordered an oil pressure adapter for the m50 so i can install my senders for my oil temp and pressure gauges.
also acquired some motul 5w40 to lube up the m50 from a local surplus store. got 5L jugs for only $22 each. i bought all the had haha
and i welded my GC perches on my struts.
next up is test fitting my selector rod and modifying as necessary to fit this trans setup. after finishing the shifter fabrication and testing, i will remove the engine and trans again. i need to fit the front suspension and roll the car out into the driveway so i can degrease and pressure was the engine bay and trans tunnel. then i will finish the removable core support and paint all of the exposed metal in the bay. at the same time i will send out the subframe, struts, and transmission brace to be powdercoated.
ordered an oil pressure adapter from ebay to accommodate my oil temp and pressure gauge senders. this one is similar to the one bimmerworld sells but i scored it for $27 versus the $100+ pricetag on the bimmerworld piece.
i ordered intake parts this week as well, they should be here soon.
i also laid out my harness on the living room floor and gave it an overhaul over the past two days. the engine and harness came from an auto 325i so i removed all auto trans related wiring, as well as all of the ugly rubber loom and giant plastic thing that covers all of the splices and wiring. the junkyard that pulled the engine also cut the o2 sensor pigtail off so i removed one from my spare harness and spliced it into this one. after everything was trimmed/depinned/labeled to my satisfaction i used self fusing silicone tape to wrap the harness. this tape is strange but works much better than loom or ugly shiny electrical tape. it also seals very well and should last some time. i also have every plug and pigtail labeled so install should be pretty easy when i get to it.
oil pressure adapter:
harness before (with bonus doggo):
harness after:
also, anyone reading this who has done a 24v swap, how did you mount your diagnostic port and engine harness relays? i tried to find mounting brackets on realoem but couldn't find anything. i sold my m20 relay bracket with the engine so i no longer have that and i'd like to mount them somewhere on the passenger side near the firewall. maybe i'll have to hit the junkyard this weekend and see if i can find brackets of some sort.
Originally posted by mitchlikesbikes View Postalso, anyone reading this who has done a 24v swap, how did you mount your diagnostic port and engine harness relays? i tried to find mounting brackets on realoem but couldn't find anything. i sold my m20 relay bracket with the engine so i no longer have that and i'd like to mount them somewhere on the passenger side near the firewall. maybe i'll have to hit the junkyard this weekend and see if i can find brackets of some sort.
Didn't browse your thread, if your using m3 covers, has provisions for the relays to sit there, if not, try the fuse box where the auxiliary fuse box is?
yesterday was what will probably be the last 40*+ sunny day here until february, so i took advantage as much as i could. i mocked up a prototype selector rod for the 6 speed trans. i am going to send the mockup to garagistic so they can use it to make me a custom stainless one for the swap. i was planning on modifying my UUC one but i couldn't make myself chop up such a nice piece of hardware.
after finishing the shifter mockup i pulled the engine and trans back out. subframe, strut housings, and trans mount will all be going to get powdercoated soon.
once the engine and trans were back out, i used my roller rear wheels and engine hoist to roll the car out into the driveway. once out there i raised it up and soaked the undercarriage and trans tunnel with degreaser and pressure washed it off. the old engine and trans leaked a fair amount and the sludge and grease underneath was horrible so i'm glad i got it cleaned up. it will be much more pleasant now to clean up the bay, do the final engine and trans install, etc etc.
also i am selling my 325i UUC DSSR. it is posted in the classified section, shoot me a pm if you are interested!
