you can order one in any size, shape, and color you want. shoot them a message. if you don't have facebook:
SLC: 1989 Zinno coupe. Superlight, Super Functional *6spd swap inside*
IG: @mitchlikesbikes -
test fitted the cobra today. i was planning on going with massive's side and floor mounts, but it turns out that the cobra rails will work with spacers on one side. easy $150 saved there. i had to enlarge the floor mount holes on the rails that were included with the seat, but it looks like i should be able to mount it in the perfect position with these rails. with the spacer setup i want to run the seat is almost dead on centered to the wheel, which from what i understand is one of the biggest issues when running a side mount setup in an e30.
IG: @mitchlikesbikesComment
Looks perfect man. Great score.
Sent from my SCH-I605 using TapatalkComment
thank you!
got some late night work done on the car. i picked up my seat spacers from alacrity today and snagged some long hardware for the spaced out side as well. everything fits perfectly at this point. i got the seat distance and angle pretty much dialed in. it's a real pain in the ass to get in and out of the car with my setup but i'm used to driving my jeep too so i think i'll just have to adjust to it. i'm also lowering my column by 1/2" at the mounting point, which translates to the wheel itself being lowered about an inch. this helps with the wheel angle and keeps the wheel at a reasonable height for vision, but makes it harder to squeeze in and out with the big bolsters on the seat. not sure why the e30 never came with a tilt wheel in the first place. oh well.
anyway, on to some pictures
this is the column in the position i want it. as you can see there is no spacer. since i wasnt sure what drop i wanted i didn't make one yet.
left side seat mounts with spacers
seat brackets are using all 4 factory mount points. makes it pretty easy for me. i need to trim the brackets and then refinish them before things will really be "finished" here
decided to give my flocking kit a try today. i just did the glovebox to get a little practice before i take on the dash. turned out okay, but it's just a messy process overall.
dash is next :shock:
pulled my shifter today as well for a rebuild. major pain in the ass and EXTREMELY messy. i dunno if the underside of this car has ever been cleaned in 25 years:(
shit, it's been almost a week since my last update. the iffy weather has been killing my motivation but today was 60+ so i got to get some work done. first things first, my rollbar is finally here :mrgreen:
my old man is a welder/pipe fitter by trade so he is going to come spend a weekend with me and burn it in, along with my floor patches.
i also bought a $10 air chisel from harbor freight to get the rest of the sound deadening out of the trunk. literally the best $10 i've spent on this build. i was done in probably 15 minutes or less vs the hour+ it would have taken with dry ice and a putty knife.
today i did some sandblasting/scuffing of the seams and interior to prep for coating. i blasted what i could without making an enormous mess, then scuffed the rest with scotchbrite pads.
after that it was time for some of the good stuff:
por15 is drying right now. hopefully sometime after work this week i will be able to scuff more of the interior so i'm ready for paint once the rollbar and patches are welded in.
Sent from my SGH-M919 using TapatalkComment
definitely not universal. they made the main hoop into the perfect shape to fit into my car without the sunroof cassette. the rear down bars are somewhat "universal" but they come pre notched. i'll just need to make the angled cut where they meet the floor in the trunk and also cut the floor plates to size.
realistically in my case i really only should have bought a main hoop all bent up and ready to go. the floor plates and down bars they include will need the most work to fit, and since they don't require bending i could have taken care of it myself
the rollbar itself was like 220ish. thats the best 4 point you can get from them. 1.75 dia .120 wall DOM tubing (beefy shit).
however, RCC is in virginia and shipping here was like 120 bucks. so it was around 350 to my front door. which really isn't bad overall when you consider the price of thin, weak sauce "bolt in" bars.
yeah for sure. RCC makes full spec legal cages for the e30 for like 650. but a full cage is more expensive, harder to install, heavier, and dangerous for a daily. so with all that added on i realized that a basic roll bar is fine for me. i can always add door bars too if i feel like i want a little extra support.
Sub'd. Looks kool! Eager to see how the roll bar install goes. :popcorn:
I'd kinda like one for mine but am somewhat unsure of how "Joe racecar" I want to go with it...I've used my back seat twice in almost a year so it wouldn't matter terribly...
-Christian
'37 Chevy pickup, the über projectOriginally posted by roguetoasterBe sure to remind them that the M42 is one of the best engines ever made, but be sure to not mention where it actually falls on that list.Comment
