New name and and new engine for Mina: an e30 for the GF
    Originally posted by Andy.B View Post
    I've got a rebuilt 885 head with less than 1k miles on it, sporting all new gaskets, rebuilt injectors, and an adjustable cam gear, as well as a 2.7 bottom end, if anyone out there wants to make a 2.7i. I need to recoup some funds, and clear or some space!
    Oh gad, I been looking for a damn 2.7 bottom for months. Time for me to say the most repeated line on r3v: "I wish you were closer...".
    On a related note, I've been really wanting to drive up to Nova Scotia and drive the Cabot Trail. Hold it till the summer, hear me out, then we take the m30 swaps up and run the Cabot trail, then I get the 2.7 bottom from you on the way back home to TN? Yeah? You like?
    I was born on 3/25…
      Originally posted by E30NJ View Post
      How are you able to work? Didn't you guys get like 6ft of snow the other day? Good work!
      I live about 3 miles north of the the border of what for absolutely hammered with snow, and what just got some snow. I work another half hour east, away from the snowpacalypse. I was lucky to be only minorly inconvenienced by the snow.
        Haha... I'll keep it in mind.
        I never thought a 2.7 bottom end had any value.
          Well, they don't usually, unless you have a crazy mystery noise in your current bottom and want a low compression m20 for boosted situations, which I do...
          I was born on 3/25…
            Haha. Crazy mystery noises are why I'm jamming an m30 into this car to begin with.
            It's amazing how things can escalate like that... My engine needs a few bearings replaced to be reliable... I'd better swap in an entirely different engine! That seems easier!
            Once this is done I'm going to follow you as my spirit animal and start planning out a supercharged build for my e30's 2.7i motor. I know nothing about diy supercharger builds, but your thread inspired me to take a stab at it. My car has enough of a flat spot until I get over 3k rpm and it gets on cam that adding turbo lag to that would make the lower rpm range seem useless.
            But I've got to get my GF's car back on the road first. I will try to have the m30 at least bolted in place by next weekend. Then I've got to figure out stiffer springs to keep the tires from rubbing and the shocks from bottoming out. It was already bottoming out with just an m20 in there. The m30 is definitely going to be too much weight for the ST m3 springs that are in there now.
            I'm actually thinking about going diy, and buying el cheap ebay coilovers for the adjusters, and getting 9 inch springs aimed at circle track racers to cut in half to end up with my desired heights and spring rates. I priced it out at costing about $150 to end up with a set comparable to the GE coils I'm running in my car.
              You'll love it. It's really not all that difficult. The pulley stuff took some time, but I'll gladly share anything about it. The MS2 was the most challenging thing for me. But you'd have to do that with a turbo as well.
              I was born on 3/25…
                If you're serious about getting that bottom end i might be of service. Trying to get down to visit my brother in Lebanon and might be able to drag that down with me.
                Swanny!
                SUCKERS.
                  gahhhh early model sedan with cardinal interior..
                  get this baby running man!
                  2003.5 Imolarot M3: daily
                  1995 Alpinweiß M3: hpde
                    Oh I'm serious. It is on the short list. I'm sure one will turn up down here right about the time we work it out, but I'd love to help Ando.B with some monetary compensation, for I believe he is a good dude.
                    Edit: Also, Chicken wings, nuff said.
                    I was born on 3/25…
                      Mina has an m30! There is still a lot to do to get it running, but the engine is in place, finally!
                      Getting it in position was a much bigger challenge than I expected. It went in and came out 3 times before I had the firewall massaged enough to get the m30 back far enough to line up with the engine mounts. And even then, it was a challenge. The only way I was able to get it on the engine mounts was to take the exhaust side mount off so I could get the engine all the way back in the tunnel, then clock it to slip the intake side rubber mount in place. After that, I was able to rotate it back 'upright', and then wedge the arm down over the rubber mount and thread the bolts into the block. It was quite an ordeal.
                        Awesome! Mine was the same way I think it came in and out 5 or 6 times before the firewall was pushed back far enough. Then I couldnt get it on the mounts so I had to use a pry bar to wedge the motor back and forth until it went over the mounts. Cant wait to see more progress!
                        1991 318i 4dr slick top
                        Mtech 2 turbo restoration
                          Progress:
                          I decided to go a slightly different route with the wiring harness. It's the stock m20b25 harness (Production date 7/87). I cut the sheathing off, and was able to reach all the necessary connectors without actually cutting or extending any wires. I then tucked the harness into the position I want it to be in. Some wires were too long after this, so they are doubled back on themselves in the harness. The only wire I'm going to have to cut is the small gauge 12v to the alternator, and that's only because its too wound up in the other wires in the harness to get it where I need it. Once I get everything tidy, I will re wrap all the wires into bundles again, and viola, instant m30b34 motronic 1.3 harness without any real wiring modifications.
                            Just me thinking outloud but I noticed the motor has no belts wouldnt you want those on before adding the rad and what not just to make your life easier?
                              Fair point. The radiator is just sitting in place to check fitment. I still have to re install the power steering pump and slip the belts on before I bolt the radiator in place.
                                I see just had to ask is all
