I have replaced every fuel injection sensor or control valve with new or known good pieces, and re sealed the entire head and intake. I am at a loss for what the cause might be.
New name and and new engine for Mina: an e30 for the GF
Introducing: Black Betty, an e30 for the GF
Just thought I'd weigh in again here... I have done 2 valve adjustments since my last post about this topic and my rough idle seems to have resolved entirely. In fact, I tried to feel it yesterday while in traffic and couldn't. I'd say any current roughness can be attributed to a 24 year old engine/car in general. But the acute, intermittent rough idle that we were referring to has subsided. Maybe it's time for a valve adjustment for you?Comment
Thanks for the input. The head had a fresh valve job, and I adjusted the valves right before installation, using the spring tool on the eccentrics, but I will do it again, just to be certain. I certainly hope that resolves it, as my eta with twice the mileage feels silky smooth in comparison.Just thought I'd weigh in again here... I have done 2 valve adjustments since my last post about this topic and my rough idle seems to have resolved entirely. In fact, I tried to feel it yesterday while in traffic and couldn't. I'd say any current roughness can be attributed to a 24 year old engine/car in general. But the acute, intermittent rough idle that we were referring to has subsided. Maybe it's time for a valve adjustment for you?Comment
So Mina has pretty serious rod knock, and a trashed diff that whines loudly as soon as it is warm. It got parked in the corner of the driveway while my gf drove our Miata for the remainder of the summer, while I wrapped up my 2.7i build. Now that my car is complete, I started weighing my options for getting Mina back on the road. I have another 2.7 eta engine in a garage I thought about using to slap together a 2.7i with the current head and motronic 1.1 system to replace the knocking 2.5i thats in the car currently. Having driven a 2.7e, a 2.7i, and a 2.5i throughout the summer, I can honestly say that my 274 cam'd 2.7i is my favorite engine, but I didn't love the idea of 'downgrading' a 325i with a low compression 2.7i build. I dragged my feet on doing anything with the car, so it just sat, neglected.
And I am now glad I did. I pulled home a derelict 86 535i a few week ago that my brother wanted for its minty black interior to replace the worn and weathered tan interior in his car, while I had my eye on the m30 under the hood.
After taking stock of the car and stripping out the interior and usable parts for my brother, I finally got around to checking over the engine before I made my decision on how to proceed...
Would it be a 2.7i or a 3.4i for mina?
The compression checked out ok. My compression tester is a bit wonky, with a needle that likes to stick, and a release valve that likes to leak, it took a few tries to get an accurate reading on each cylinder, but everything checked out consistently. I then pulled the valve cover and inspected the cam for damage or excessive wear, and here too, everything checked out ok.
I wanted to make the engine as easy as possible to remove, so took out the core support. (ok, the truth is that the car was so rusty I was able to bang off the core support with a hammer after I removed the bumper. It practically disintegrated in my hands.
I've got a complete m30b34 engine/transmission, along with the motronic 1.0 harness and dme, radiator, and all the associated lines, hoses, cables, etc. I disconnected everything on the engine, and pulled the exhaust and driveshaft. The only thing left holding the engine in the car is the engine mounts and gravity.
The transmission is a Getrag 265/6:
I'm not sure if that is a good or bad thing yet, as I have yet to find a clear answer as to what my driveshaft options are. Mina's transmission is from an eta, so it already has a large guibo driveshaft. I'm not sure if I can position the engine/transmission far enough forwards to use the g265 without getting the driveshaft shortened.
For the exhaust, I am planning on maintaining the stock m30 manifolds and cutting/splicing the downpipes to the stock e30 exhaust. I have an extra e30 exhaust as well to scavenge for extra pipe.
So my goal is going to be to do this swap for as little money as possible. I know there are more gains to be had by picking and choose certain parts, but I am going to work with what I've got everywhere I can. I'm hoping to actually pull off an m30 swap for the mythical sub-$1000 budget.Last edited by Andy.B; 09-15-2014, 03:23 PM.Comment
Taking stock of my parts, I have:
m30b34
g265/6 with stamped steel shift carrier and large guibo output flange
e28 535i radiator
Motronic 1.0 harness/dme
which is all going into an 87 325i with a large flange driveshaft and motronic 1.1
I am planning on using the e30 engine harness to convert the b34 to motronic 1.3 by extending wires as needed and getting an e34 crank pulley/damper and dme. That should let me simplify the wiring/vacuum lines on the b34 and clean things up a little bit under the hood.
I'll re-use the e28 radiator with a pusher fan.
I'm not sure about engine mounts yet, as I can't seem to find anybody currently selling m30b34->e30 mounts in the US, but want to avoid the hassle of ordering from europe and dealing with international shipping if I can void it. I'm also unsure about which engine position I want, since I am hoping to bolt in the large guibo eta driveshaft already in the car, but am unsure if it will fit behind the g265 at any position.
The parts needed list is:
electric pusher fan
e34 oil pan/pickup
e34 crank pulley
179 dme
m30b34 > e30 engine mountsComment
I started a new thread here to discuss the engine mount situation. I know there where some b35 blocks with dual mount provisions, but I have found no proof of b34 blocks with both provisions, yet it looks like my block has both. However, since qbang is still making b34 mounts domestically I will just be ordering his.
I'll have to send a pm to f34r to ask him some questions, since he is the closest m30 e30 I know of. Maybe I could find time to go check his out at some point.Comment
Loved looking through the build man!
Side note, I've been trying to post more on here, but you should join our group on Facebook for WNY e30's.WNY e30 Group on FB, feel free to join if you're from the area!
@mriterphoto on instagram
"Being airborne in an e30 is one of the worst ideas that I've done more than a couple dozen times"
me-"I've got one of those rare 7cyl low-comp S62's"
MattAvino- "Those aren't rare"Comment
Ashley (my girlfriend, the cars owner) and I freed the m30/g265 from the car this evening. I didn't have an engine crane handy, so I jacked up the car, and lowered it back down with the engine resting on some blocks, unbolted the engine mounts, then lowered the car the rest of the way, so we now had the engine sitting free of the car, but still surrounded by the car. We then pushed the car back away from the engine until the subframe hit the blocks under the tail end of the transmission, at which point we lifted up the transmission, and moved the blocks ahead of the subframe, and rolled the car the rest of the way away from the engine. Now the engine is sitting on jack stands and blocks in the driveway, completely free from the car:
I ordered a 179 dme today, and contacted qbang about getting a set of his mounts. The only pieces I need still are the e34 oil pan and pickup, and the motronic 1.3 cps bracket. I should do much more prep work on the engine and transmission than I am planning on doing, since we mostly need to get Mina running again, and I am trying to pull this off for as cheaply as possible.
So far, I am in
$200 for the donor e28 (split with my brother)
$225 for the engine mounts
$50 for the 179 dme
= $475
Which means I still have $525 for the oil pan and cps bracket, new plugs and belts, tranny fluid, and oil and filter. I am going to try my luck with the current clutch, and see what happens. I am going to take my chances and hope the car will make it through winter without having to separate the engine and transmission.Comment
