Zwaylo's First e30
  • Zwaylo
    • Mar 2014
    • 34
    Wow been a long time since I have posted on here. I still have the 325es and am working on it slowly. Most of my attention though has been on the 1988 DS M3 I picked up this last summer. The Italvolanti made it's way onto it.
    • theDELO
      • Nov 2014
      • 37
      solid upgrade - car looks sick!
      • rcsoundn1
        • Nov 2012
        • 3361
        whats that box in the console
        • Zwaylo
          • Mar 2014
          • 34
          That is the accelerometer for the AIM Mychron 3, which is on the passenger floor on the photo
          • Zwaylo
            • Mar 2014
            • 34
            Here is a list of recent mods/upgrades on the M3
            Engine
            2.5 liter Metric Mechanic rally motor
            H beam rods
            Rally cams
            Ported polished heads
            Oil pan baffle
            RC engineering flow tested and cleaned injectors
            New spark plugs
            New rotor cap and cap
            Engine Bay
            Aluminum radiator
            Samco silicon hoses (Blue) with heater hose recall fix
            Stainless steel hose clamps
            Polyurethane alternator bushings
            New BMW thermostat
            Korman heavy duty Plunem bushing
            Setrab oil cooler
            Braided nylon hose oil cooler lines with AN fittings
            Magnecor ignition wires
            GSP low cross fire ignition wire bracket
            New BMW motor mounts
            New heat shield
            New crank sensors
            Subframe reinforcements performed
            Front shock tower bar
            Drive Train
            Rogue engineering shifter
            Rogue carbon fiber shift knob
            Rogue weighted selector rod
            JB racing light weight flywheel
            Street clutch with un-sprung hub
            Rebuilt drive shaft (Driveline of Atlanta)
            Front Suspension
            Treehouse Racing control arm brackets/ bushings
            New steel control arms
            New tie rods
            Stock struts assemblies blasted and powder coated (gloss black)
            Sway bar reinforcements performed
            New upper strut bearings
            New upper plates
            New spring pads upper and lower
            New wheel bearings with ABS rings
            New cup, collar nut, and cap
            New dust covers
            Tie rod arms blasted and powdered coated to match struts
            Koni - TC Kline valved externally adjustable (12mm shafts) inserts
            Ireland Engineering race springs
            Ireland Engineering fixed camber plates
            Rear Suspension
            Koni - TC Kline valved externally adjustable (12mm shafts) shocks
            New spring pads
            TC Kline rear shock mounts
            Interior
            AIM MyCron3 XG Log data acquisition system (wired to ignition, professional install)
            Ram mounted display to windshield
            Italvolanti Formel steering wheel
            New leather shift boot
            • ttrousdell
              • Nov 2009
              • 1770
              Nice cars you have there
              The Build:
