Sterling 318iS, less than sterling condition
  • KIRIEIW
    • Dec 2012
    • 3385
    Oh god, well if your heatercores leaking I think there's some recall that BMW still fixs if I'm not mistaken. If its not been done you can go over to your local dealer and they'll fix it free of charge. Take pics of the reactions the people at the dealer give you and post them up.
    1992 e34 Touring- S50 Swap
    1992 325i-S50 Swap (SOLD)
    1991
    • Aufbau Principle
      • Jan 2013
      • 121
      So I found this under the intake:
      E302 (1 of 3) by AP Photomatic, on Flickr
      Replaced that, buttoned everything up, temp still climbs up into the red at idle, but no steam. Is the overheating just because there's too much air in the system?
      Also, some friends visited:
      E302 (2 of 3) by AP Photomatic, on Flickr
      E302 (3 of 3) by AP Photomatic, on Flickr
      • N2MYE30
        • Oct 2007
        • 5536
        Ill give it to ya, at least your diving right in. :up: I wouldn't even mess with the body, light sand the rust, clear, done! I could only imagine what the undercarriage looks like. Safety looks to be first to address, other than your coolant leak, and maybe a check on your tetanus vaccine. Have fun with it!
        COTM
        • Aufbau Principle
          • Jan 2013
          • 121
          Posted this in the M42 section as well:
          Temp gauge went into the red on the way home, stopped to let it cool down a bit, kept driving. Blew the upper heater hose that goes from the firewall to the engine block.
          Replaced that, but the car still overheats within about 15 minutes of idling, less when driving it slowly around the block.
          There's no heat out of the vents with the heat knob turned all the way up. Fan doesn't seem to blow either when turned all the way up, all vents open, all sliders to the right.
          Upper and lower radiator hoses don't feel like there's any pressure in them. Doesn't seem to be leaking anywhere else.
          Checked the oil cap and dipstick for milkshake, oil's dirty but otherwise fine. No white smoke out the exhaust.
          Car starts up, idles, and drives just fine, I shut it off when the temp gauge climbs past the 3/4 mark.
          What are the possible culprits? Busted water pump, busted thermostat, clogged hose somewhere, clogged heater core/valve/radiator? Shitty bleed job?
          Lower radiator hose on the driver side also appears to be leaking now.
          Car also smells rich on startup.
          • Eddie Lives On
            • May 2011
            • 208
            If anything, just get yourself a mig and learn a new skill?
            • econti
              • May 2014
              • 1147
              Are 318is rare over there?
              • LivingLegend06
                • Dec 2006
                • 1604
                If you have not properly bled the system I would statrt there. Get the front end high in the air and crack the upper radiator hose and fill from there. Check the thermostat in some hot water to make sure it opens up.
                • TimKninja
                  • 2131
                  Saw this car on craigslist, $1500 was too much. jesus. I paid $1500 for my 318is Slicktop from boston, that had a low mileage engine and not nearly as much rust.
                  Pull the carpet, post pics of what ensues. Before you even Diag the overheating.
                  1985 325e M50TU(Sold)
                  1991 318is Slicktop (Sold)
                  1990 325is Brilliantrot S50/5 Lug Swapped.
                  1992 525i Manual shitbox Winter Beater
                  • mkcman17
                    • Jul 2010
                    • 8240
                    Originally posted by Aufbau Principle
                    As far as parting the car goes, I'm using a reference of a reasonably $4200 325i I test drove that had a mostly solid body, with the exception of a bent door and crunched rear valance. Sold to someone else the day after, unfortunately. This car was $1500, with new front control arms, new brake rotors and pads all around.
                    As we say at my job, 'one comp doesn't make a market.' I've sold several near-perfect body cars out here for around $3k within the past couple years. You would have been best served by flying out here and driving one back.
                    1989 LN106 Hilux / 3.0TD SFA
                    1974 2002tii / stock
                    2002 IS300 / 5spd LSD
                    • e30austin
                      • 15382
                      I've parted way nicer cars than this. Take it from someone who's dumped a fuck ton of money in a POS - start with a clean shell. I would part it and move on.
                      • ClausE30
                        • Sep 2011
                        • 981
                        "Patina"
                        91 Alpinweiss2 318is OBD2 S52
                        • Ray Smoodiver
                          • Jun 2004
                          • 8809
                          Yikes
                          • e30vert
                            • Jan 2005
                            • 1789
                            It should be a g240. not a g260. they use different fluids so make sure u know for sure what you have.
                            means you have a popped heater core.
                            im hoping this car was free. bc you will spend 6k to make it safe to drive. if i were u. id part it and get something not from under the sea and driven by a 16 year old girl.
                            "Under the Sea"
                            • M42Power
                              • Dec 2009
                              • 519
                              Jesus man.
                              Good luck with that
                              Originally posted by kendogg
                              Don't know, but the E90 wasn't designed from the ground-up intending to be a racecar like the E30 was.
                              OG RACECAR
                              • KIRIEIW
                                • Dec 2012
                                • 3385
                                More common then a 318i if you ask me
                                1991
