R1dd1ck913's 91 318is M50tu swap
  • RedReplicant
    • Oct 2009
    • 270
    Very cool :)
    91 318is - Gone
    16 VW GTI
    07 Aprilia Tuono
    • 2mAn
      SeƱior Mod
      • 21057
      This will be a fun swap. As for using the G240, do some searching in the M50 24v subforum. I know it can be used, I cant remember which parts you'll need. I know you will need a different trans brace, I just bought the one from GunMetalGrey. I used the G260 and the only thing I had to change was the m20b23 throwbout bearing IIRC. Keep it up!
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      Make R3V Great Again -2020
      • R1dd1ck913
        • Jul 2014
        • 382
        I have been talking to the member Nick S. Since his swap is the same as mine almost. As far as I know right now a different tranny cross member is not needed since the mounting spot is sloted. I do however need to change or modify my shifter. I'm still not sure witch ones I can use.
        Current
        99 328i (Sold)
        91 318is M50B25TU
        89 325ix (Parted out)
        87 325is (Parted out)
        95 525i (Parted Motor for 91 318is)
        • R1dd1ck913
          • Jul 2014
          • 382
          Ok well I have not been updating this as much as I should. I went to the junk yard today and got a set of e36 engine mounts since my motor came from a e34. I also picked up about 12 e36 switch bezels and 2 blue bottomed e36 switches. Also while there I found a replacement dome light and a rear defrost switch. I also have a question since I'm swapping a 6 cyc motor in to a 4 cyc car do I need to pick up the chip for the tach from a 6 cyc car?
          Current
          99 328i (Sold)
          91 318is M50B25TU
          • R1dd1ck913
            • Jul 2014
            • 382
            To day I ordered Condor solid motor and tranny mounts. I also ordered a power steering delete kit from them.
            Current
            99 328i (Sold)
            91 318is M50B25TU
            • R1dd1ck913
              • Jul 2014
              • 382
              Wow didn't realize I have not updated this in almost a year. Here is a few updates on the car. I have replaced the Headlights, Tail Light, Turn signals and wheels. Here is a few pics.
              Current
              99 328i (Sold)
              91 318is M50B25TU
              • R1dd1ck913
                • Jul 2014
                • 382
                I ordered some Camaro shocks and got some inserts from the home depot for the bushings. I hope to get them on tonight.
                Current
                99 328i (Sold)
                91 318is M50B25TU
                • R1dd1ck913
                  • Jul 2014
                  • 382
                  Today I received my UUC BBK can't wait to get it on the car tomorrow.
                  Current
                  99 328i (Sold)
                  91 318is M50B25TU
                  • R1dd1ck913
                    • Jul 2014
                    • 382
                    So I got the UUC BBK installed. Here is a before and after.
                    Current
                    99 328i (Sold)
                    91 318is M50B25TU
                    • R1dd1ck913
                      • Jul 2014
                      • 382
                      Well got a few more parts in.
                      Before
                      After
                      Also did some body work and filled the holes.
                      Current
                      99 328i (Sold)
                      91 318is M50B25TU
                      • R1dd1ck913
                        • Jul 2014
                        • 382
                        Got some new rotors, pads and calipers for the rear today.
                        Current
                        99 328i (Sold)
                        91 318is M50B25TU
                        • R1dd1ck913
                          • Jul 2014
                          • 382
                          Today my Garagistic Sturt Bar showed up. Thing fits perfect. There was no need to jack up the car as it fit right over the studs.
                          Current
                          99 328i (Sold)
                          91 318is M50B25TU
                          • R1dd1ck913
                            • Jul 2014
                            • 382
                            Car got some more love last night. I installed some new gears in the cluster and replaced a few bulbs while I was in there.
                            Current
                            99 328i (Sold)
                            91 318is M50B25TU
                            • R1dd1ck913
                              • Jul 2014
                              • 382
                              Here is and update on my Catuned order.
                              Current
                              99 328i (Sold)
                              91 318is M50B25TU
                              • R1dd1ck913
                                • Jul 2014
                                • 382
                                Few small repairs done today. New blower motor resistor. Blower only worked on high. Also replaced a clip on the passengers seat so it can slide forwards and backwards. I have a few more parts on the way for some other repairs. Will updated on them soon.
                                Current
                                99 328i (Sold)
                                91 318is M50B25TU
