My 1988 e30 325ix - Garage'd
  • litu
    • 848
    #196
    sub
    https://www.facebook.com/Cry_77_IX-110483784967661
    https://www.instagram.com/cry_77_ix/
    • jeenyus
      • Aug 2011
      • 2064
      #197
      Tiny update. I had a window switch that was rattling with a burnt out light. So I got a new one.
      Old:
      New:
      I also saw this car. Looked great.
      • driftxsequence
        • Apr 2015
        • 203
        #198
        I got my wife onboard with the idea of a F30 335i xdrive....Now to convince her to sell her TDI instead of the 325ix or RX7s...LOL
        325IX Build Thread
        RX7 Build Thread
        • jeenyus
          • Aug 2011
          • 2064
          #199
          I'm starting to think my distributor cap and rotor need to be replaced. I think that's a place to start with me poor cold starts. Sometimes I'm starting it 5 or so times in the morning to get it to go. Once it goes, or I rev it real high, it keeps driving, but initially I'll fee what seems just like a missed spark. Tonight I'll pull off the cap and see how bad it is. It hasn't been replaced yet, so either way I'll get the maintenance out of the way.
          • jeenyus
            • Aug 2011
            • 2064
            #200
            Ok, did some work on my car since the weather was inviting and conducive to it.
            I fixed a little bit of rust under my door. I have some on the other side of my car too, but this will have to do. Makes the car look so much better getting rid of little things like that.
            Here it was before.
            Here is was during.
            Here's how it turned out. (Not perfect but much better)
            I also got the IX transfer case mount replaced. What a pain in the ass that was.
            After cutting out the bushing.
            After cutting out the bushing I used a hacksaw to cut through the metal sleeve. Once I was through that, got a chisel and smacked it out.
            It was a much needed change. I didn't realize it was so easy to get my car to shift gears till after replacing the bushing! Car is feeling so smooth.
            The distributor and rotor are waiting for me at home and I might do that tonight since it's not the most difficult job.
            • driftxsequence
              • Apr 2015
              • 203
              #201
              Is this why 2nd and 4th are hard(er) to get into gear?
              325IX Build Thread
              RX7 Build Thread
              • jeenyus
                • Aug 2011
                • 2064
                #202
                It's made shifting much easier for me. 2nd has always been a. It delayed when I shift and replacing the mount made it much smoother and quicker. I don't for certain if that's why I'm your case, but it's apparent that drivetrain movement makes shifting accurately and quickly much harder.
                • ThatM20Guy
                  • Aug 2014
                  • 600
                  #203
                  Did you go with a poly bushings or just a new OEM one? Going to be replacing mine this weekend hopefully.
                  89' 325ix Diamantschwarz/Black rattle can...
                  Insta: r_moose_w
                  Originally posted by flyboyx
                  I imagine her smelling like spoiled milk and having a half inch crust of doodoo circumnavigating her butthole.
                  • jeenyus
                    • Aug 2011
                    • 2064
                    #204
                    I went with the OEM mount. I wanted a poly one, but the one from Condor isn't finished being developed in my opinion. You have to purchase a longer bolt, the bolt isn't snug in the sleeve for the mount and it's just a weird design that doesn't seem to improve on the OEM mount. Almost like they just decided to make it poly and that's about it, but it didn't turn out right.
                    The OEM mount has a threaded portion in it that allows the bolt to snug up the transfer case to the little subframe thing. It also has considerable play, which I think is necessary for the transfer case to function correctly.
                    I'll tell you right now that getting the new bushing in is a huge pain in the ass. getting it out, not the worst. pressing the mount in is impossible with the rubber bushing in the middle as you'll just end up stretching that rubber so you're limited to pretty much hitting it in there, OR what i should have done, freezing it and trying to push it in.
                    • jeenyus
                      • Aug 2011
                      • 2064
                      #205
                      Got the new distributor cap and rotor installed last night. Made a huge difference! Car isn't stalling anymore! It's a LOT quieter than it was too, I'm guessing because the cylinders weren't firing on full and that added to exhaust resonance.
                      The old cap and rotor was so incredible corroded. Not worn as much as I expected, but corroded a lot.
                      Old cap
                      Old rotor (right) vs New rotor (left)
                      • ThatM20Guy
                        • Aug 2014
                        • 600
                        #206
                        Yeah getting my subframe bushings out were a pain...burn them then sawsall the sleeve and chisel out, I can agree that it ain't fun. Not looking forward to getting the tcase one out. I got a poly bushing so hopefully that wont be to hard to get in.
                        I was thinking of asking Condor if they could make me a poly one but went with Garagistic instead.
                        I'm assuming you left the tcase in the car?
                        Insta: r_moose_w
                        • jeenyus
                          • Aug 2011
                          • 2064
                          #207
                          Yea surprisingly. Might help to lower the exhaust down though. Otherwise the access isn't the worst.
                          • jeenyus
                            • Aug 2011
                            • 2064
                            #208
                            Received the same misfiring symptoms this morning. I was scratching my head for a second, but remember the CPS being mentioned. I ordered on as I'm pretty certain it's the only thing I haven't replaced at this point. Sigh* found one on fleebay.
                            • jeenyus
                              • Aug 2011
                              • 2064
                              #209
                              Alright...
                              I replaced the CPS. The car seemed to be running just fine, I turned the car on the next morning and as soon as I pressed the gas pedal, the car cut out. This is becoming quite a nuisance. I've replaced so much shit! The car still isn't 100% which makes me so bummed out. If I disconnect the battery the car seems to run fine. Then the symptoms return maybe the next time I start the car.
                              After what seems like a wild goose chase the last thing I can think of (and haven't replaced yet) is the ignition coil.
                              Does anyone have any idea what this could be?! Any help before I buy more parts for this...?
                              • rzerob
                                • Jun 2013
                                • 2315
                                #210
                                Sounds like the afm to me.
