My 1988 e30 325ix - Garage'd
  • E30Bastard
    Shimmy Shimmy Ya
    • Nov 2018
    • 245
    #421
    Just got off the phone with IE and I guess this is good info for all - oem and their adjustable fpr don't have backflow prevention.
    Sent from my Pixel 2 XL using Tapatalk
    "It wouldn't be there if it wasn't..." - Milton Berle
    1988 325iS - M20
    • jeenyus
      • Aug 2011
      • 2064
      #422
      That's good to know. I wanna know someone who's fuel pump actually primes. I've never heard mine do it.
      Sent from my Pixel 2 using Tapatalk
        • 34839
        #423
        M20 fuel pumps don't prime. Only the M42 does that. That's controlled by the DME anyway, not the pump.
        • E30Bastard
          Shimmy Shimmy Ya
          • Nov 2018
          • 245
          #424
          My fuel pump kicks only while the engine is cranking. Confirmed. I believe this is correct operation!
          Fuel rail to stay pressurized for quick start. If pump primes and engine runs great it must be air leak in fuel system!
          1988 325iS - M20
          • jeenyus
            • Aug 2011
            • 2064
            #425
            I got some freshy fresh front bumper struts for the front plastic bumper coversion.
            My only question is, how does everyone does with settling the bumper lining with the wheel arch? I can't push the bumper cover deep enough against the car to get this to line up.
            Thanks.
            • rzerob
              • Jun 2013
              • 2315
              #426
              So. You are not going to do anything about that rust?
              • jeenyus
                • Aug 2011
                • 2064
                #427
                [emoji23] of course, just not right now. Spring I'll be tackling a handful of rust spots that need to be POR15'd. It's been in the 20s for at least the whole year.
                • DrJosh
                  • 2011
                  #428
                  You need some euroweaves
                  Originally posted by Sonny
                  I am a meme for our community.
                  • jeenyus
                    • Aug 2011
                    • 2064
                    #429
                    Dude there is so much need. LoL
                      • 34839
                      #430
                      I would go with ix weaves if you can find them. Euroweaves just rub too much. I use a 15mm spacer with mine (mostly just to clear my wheel studs), and it's pretty nice.
                      • D.Martijn
                        • Sep 2016
                        • 1023
                        #431
                        My summer wheels are Euroweaves, they don't rub at all with 205/55 r15 tires..
                        1990 325iX Touring - November 2018 R3V Car Of The Month
                        1980 Volkswagen Golf mk1 1.1
                        1974 BMW 2002 Touring
                        Instagram
                        • jeenyus
                          • Aug 2011
                          • 2064
                          #432
                          I'll be doing suspension before I go down the route of new wheels. A good segway to my question though... when it comes to rear subframe bushing, i've read that if i lower the car i don't need to worry about the subframe differences. Is this true? what rear subframe bushing do you have in there? Is your rear differential still offset?
                            • 34839
                            #433
                            If you lower the car I would switch to a RWD bushing. it's good for about 1/2 degree of camber. I have a centered bushing IIRC, with the Z3M diff cover, but I think the ix bushing is centered too. Instead, I spaced down my diff a bit with some washers, but that's probably not really necessary.
                            • jeenyus
                              • Aug 2011
                              • 2064
                              #434
                              The stock ix bushing is maybe 10mm offset. I'm sure that's to compensate for the increase to the subframe and match up the geometry. So if I were to lower the car, that would shift that geometry and I suppose more with different bushings on the subframe.
                              So I guess the conclusion is regular RWD rear subframe bushings are completely fine assuming you'd be lowering the car anyway, right? I honestly think it affects the angle of the rear diff most of all.
                                • 34839
                                #435
                                maybe at stock ride height, but even slightly lowered, they rub like mad.
                                Source: I ran euro weaves on my ix for years and years, starting in like 2004. I sold them because I got tired of them rubbing all the time.
