E30 325i Vert
  • cWalk3r
    • Jun 2014
    • 178
    E30 325i Vert
    Right after I bought it!
    My E30 and my friends E39
    Decided to do some rust repair. Both quarter panels were starting to show some signs of rust.
    Then I wanted to start doing some mods after I got the important things like timing, cooling and braking sorted out. So I bought some ST shocks and springs with E90 drop hats. The inserts didn't fit at all so I needed to machine down the tubing so the collar would fit over. Got some new control arms and offset poly bushings and some new transmission mounts. I'll probably upgrade to poly motor mounts, trailing arm bushings and oem subframe bushings next year.
    As you can see ST has a different shaped strut insert.
    Heres how she sits now
    And this is my other baby when she was in her prime lol
    More pics to come!
  • jeenyus
    • Aug 2011
    • 2064
    So did you paint it black?
    • cWalk3r
      • Jun 2014
      • 178
      I think it'll go black next year after the winter. I'm still debating but it will be getting a respray be it oem or black
      • N2MYE30
        • Oct 2007
        • 5536
        Another black cabrio or a more rare Glacier blue? hmmm.
        COTM
        • cWalk3r
          • Jun 2014
          • 178
          Lol the blue has been growing on me along with the navy top. I might just get the rear quarter panels respayed and save some money! I've always liked the look of black cars though, eg. My Jetta lol but the blue is nice
          Haven't really gotten any good photos yet and the snow has just started so I'll get it out and get some pictures soon along with getting it ready for winter storage unfortunately it's going to be outside.
          • rcsoundn1
            • Nov 2012
            • 3361
            what happened to the daily? since that was a pic of its prime
            • cWalk3r
              • Jun 2014
              • 178
              I've taken a lot off the Jetta cause it was annoying to daily a car like that and the coilovers blew and I didn't feel like sinking more money into the car. With the money I saved I bought sometime 10x more fun lol I think I'll take the e30 to te occasional auto cross event next year!
              Don't laugh at my car it's unique lol I fixed the rust in the quarter panels and didn't really care what colour I used as I am going to get it redone. I chose blue and added a little flair to it... Kinda shows my personality in the car lol This is the stance it currently has. For wheel size I'm thinking about 15x7 and I haven't had a chance to look at offsets yet. I really like how it looks with the ST kit and E90 hats. Could be slightly lower in the front though.
              I have the trim pieces, just need to buy some clips for the front and forgot to put the back on lol I need a front lip for the car and it looks like something is missing from the rear end?! Anything else I need to complete the look?
              • TimeMachinE30
                • Jun 2014
                • 3749
                Please keep the OEM blue.
                ACS S3 Build / Dinan 5 E34
                • KIRIEIW
                  • Dec 2012
                  • 3385
                  1992 e34 Touring- S50 Swap
                  1992 325i-S50 Swap (SOLD)
                  1991
                  • cWalk3r
                    • Jun 2014
                    • 178
                    It's almost time to take the cover off and get her ready for spring!!!
                    What's the best way to deal with this... My speakers aren't working well only one is and I want to get it taken care of. Should I just replace the amp or what's the best/cost effective/easiest and is there a diy on this.
                    Also my antenna doesn't power up or down and what would be the way to figure out what's wrong with it? I'm kinda thinking I should just put a stubby antenna or a long antenna on it and do away with the power one...
                    • UlrichFennec
                      • Dec 2014
                      • 1268
                      So your tonneau cover doesn't wanna close completely either, huh? Same problem. Digging the glacier blue. Getting a little facelift for mine and getting all hyped up for spring!
                      "Leafeon" '92 Lagunengrun 325i Vert (Daily Driver/Project)
                      http://www.r3vlimited.com/board/showthread.php?t=366044
                      The stickers make it go faster. :nice:
                      • cWalk3r
                        • Jun 2014
                        • 178
                        It was closing when I bought it. The first night I had it I couldn't get the top back up for I forced it a bit and probably bent the rod that connects the motor to the top or could have put it out of alignment. I removed that rod and now use it as a manual and closes a lot better but I can't remember. I'll find out in spring. My problem is that the top doesn't sit low enough in the storage space
                        • Bearmw
                          • 1323
                          For now I would just bypass the factory amp and run a newer HU. The details are outlined in the audio section. Cheap, easy, and effective. Later you might want to consider a Lukebox and bigger amp setup.
                          • Das Delfin
                            • Sep 2014
                            • 2293
                            I took out my antenna and threw in a $10 advance mast antenna. Some guy wanted 50 bucks for a mechanical antenna that will probably break anyway so I said screw him
                            • Das Delfin
                              • Sep 2014
                              • 2293
                              You have to do the thing where you fold the support bar back and tuck in the straps.. dunno if the electric mechanical tops do this. I figured it out after a couple months of wondering why it didn't fit right
