E30 Touring Restoration
  • LeSeb
    • Dec 2014
    • 27
    Hey everyone I have been creeping the forum for a while now and now have some time to upload some pictures of my progress over the year.
    Originally I found the car in Victoria Canada on craigslist as I was searching for a good shape coupe but stumbled on this Touring imported from Germany, original 5 speed manual 325i.
    After talking to the owner and some bargaining we agreed on a price and I flew out to pick it up. For an old car I found the condition to be pretty good but not exactly what I expected a BC car to be but Long story short I drove it 11 hours home through the mountains and fell in love with it.
    Originally I started off by cleaning it up making sure it was serviced and running top notch to take to the ski hill and sure enough I never stopped.
    Here are some pictures from the day I picked it up in Victoria. October 2013.
    After getting it home I started fooling around with it and added the thule wind screen and 3m to the original hella headlights to give it some character.
    Shortly after getting it home. very very shortly, I was having a lot of issues with misfires and hesitation so I ended up doing a complete ignition system on it which included
    Bosch igniter
    BMW performance wires
    Bosch Distributor and cap
    Bosch Spark plugs
    Bosch Coolant temp sensor
    Crank Sensor
    Cleaned up the engine bay with some degreaser and steam washer.
    After that was all said and done it was running great for a week, my key stopped working in the ignition which ended up being the ignition switch. So I ordered a new one and replaced it.
    While I was under the dash I found this mess with the wires and ended up fixing it up a bit along with the switch to hopefully eliminate any future problems. Further on I located more issues that I am working on resolving, which includes removing the entire keyless system and alarm and fitting it with the original door actuators.
    Slightly better.
    After that was all said and done I drove it for about 3 weeks before I had time to put it up on a lift at work. As expected I found multiple leaks that possibly date back to the original owner. For the time being I degreased the entire underside and steam washed the piss out of it so I can inspect how bad the leaks are after a few days.
    So at this point I had all the bugs and quirks worked out. Drove It for about 4 days....
    And as my luck would have it my wagon had an encounter with a truck as I was stopped at a stop sign.
    As you can see the damage was very minor with the exception of the top of the radiator support, after a long wait with the insurance company they sent out an adjuster to handle my claim. The agent was very nice and understood the situation I was in with this car as I had purchased it 2 months prior and spent a fair bit of money repairing and legalizing it.
    He was also very familiar with older bmw's so he opted that the car remain active status and be repaired.
    After a few quotes I ended up getting a decent settlement based on a quote from a repair shop and began ordering replacement parts for the front end.
    I started by removing all the damaged parts including the radiator support and making a list of everything I was replacing.
    As u can see the damage was mostly cosmetic with the exception of the top of the radiator support
    New Rad support and aluminum radiator arrived so I mounted it temporarily
    So at this point I made it drivable to move to a warmer location to work on it which ended up being my friends house outside of town where I really started to get to work.
    First I started by removing the engine and fixing all the leaks. Making it as reliable and clean as possible.
    This is when my addiction for perfection started. I went from only fixing the damaged front end to a full restoration.
    I will let the pictures do the talking for a bit.
    Pressure washed
    Input shaft seal leaking
    cleaned and replaced
    output shaft and shifter seal replaced cleaned up
    along with new transmission mount bushings
    Engine cleaned with new rear main seal
    Degreased and wire brushed
    Timing belt water pump replaced, all covers bead blasted
    Painted the block
    Cleaned with resurfaced flywheel new clutch
    Engine bay cleaned for prep all seam sealer removed, the entire bay was cleaned thoroughly with wax and grease remover before any sanding was done, as a tip to others the stuff is amazing at cleaning and can be used on factory paint carefully to remove stains or really dirty areas.
    Some rust repair in engine bay
    Engine bay prepped ready for primer
    Primed and prepped
    Custom rad support brackets making the support completely removable from the car
    Rad support and rad fitted
    Fitted with new seam sealer
    Final prep of the engine bay and support
    Hellrott red
    Engine Install
    Radiator support mounted
    Fitment, new fenders headlights grille hood valance
    Spring just arrived so I brought it home to work on
    Masked off interior
    Prepped door jams
    Prepping the doors
    Doors and door jam
    So just a rundown
    the engine and engine bay took about 3 weeks of work I was on vacation so I worked from about 12-1am every night casually to get the engine bay done from start to finish.
    As for the doors and door jams it took about roughly 3 hours to prep each door for primer and the door jams took about 8 hours a side to prep. The steps were to clean the area, wax and degrease the area thoroughly, you half ass any of these steps you will be wasting your time, then finally sanding down to 400 for the primer to mate with the car properly.
    Stripped all the texture coating off the valances
    used a wire wheel to remove it then sanded the steal to 400
    At this point I am repairing all the rust I can find on the car I didn't take very many pictures because I was dirty in awkward positions.
    Steps were too wire wheel as much off followed by sand blast the area cut away all infected spots weld new parts in, sand blast the welds self etch the metal, the rockers I used rocker guard on the inside and yadayadayada it should never come back
    I found every spec of rust and fixed all of it, including the floor pans on both driver and passenger side
    I ended up removing all the carpet and tossing it in the garbage and now searching for new replacement.
    I didn't drive the car for 3 months and the carpet was still soggy and gross. garbage it went
    this is why the car rusts, drenched carpet and a giant dirt sponge that builds up behind the fender liner
    Rear wheel well
    Should never rust again
    Re prime seam seal make sure there are no leaks
    Exterior prep
    Guide coat
    More blocking
    Final guide coat wet sanding
    Every nook and cranny
    Temporary interior
    The hatch had severe rust that was not repairable so until I can find a new one to paint I decided I would leave some rust on the car and got alittle creative on the hatch
    Starting to look like a car again
    coat the underside
    Muffler was rusted out so I didn't worry about any of the paint on it,
    eventually I cut back and replaced the piping, used stainless 2.5' to make a nice straight pipe
    After all the mess and cleaning in the garage It was pretty rough so I cleaned it up a bit for my car to sit in
    I let the car sit for about 3 weeks for the paint to gas out before I started wet sanding and polishing.
    At the beginning it was very nerve racking and took a lot of patients but I managed to get the roof done in 16 hours
    and an additional 14 to complete the drivers side. In total it took about 30 min to polish in the end. As for now it is too cold to be doing any wet sanding in my garage so it has been sitting around for the last 3 months as I take a break and replenish my bank account.
    [B]Peel Free Finish
    UPDATE!!!
    Finished wetsanding and polishing, so happy to be done with it only took 28 hours with 2 people sanding from 800-2500
    then 3 stage polish.
    After the 3 stage polish
    Thanks ECS was satisfied with my purchases and quick delivery. Will use again!
    Installed a aftermarket oil cooler and electric fan, the fitting on the side of the rad was an oddball size and I couldn't find a CTS to fit so I ended up getting a external thermal switch and relay, now I can set the fan to turn on anywhere from 160-220.
    Car would not look the right with old faded trim so I repainted everything in bumper coat which is satin black.
    Trim installed with all new hardware
    Crusty old suspension
    Front Removed and wheel arches undercoated
    Don't mind the floating parts they will be replaced
    Rear removed, didn't snap pics but I cleaned it up and undercoated those areas to match
    All parts to replace.
    Front knuckles and rear subframe with trailing arms will be powder coated with new bushings and bearings. updates later
    now to foot the bill to replace it all.
    In the mail
    koni yellow
    h&r super sport springs
    st sway bar kit 22mm front 19mm rear
    new bushings and wheel bearings
    stud conversion
    new calipers rotors pads
    front control arms
    front and rear top hats
    as for the subframe and control arms they are all being sandblasted and powder coated silver.
    spent some time on the interior
    Started off with suede in one hand and fleece liner in the other and bonded the two as wrinkle free as possible with 3m spray glue
    then glued it directly to the panel over the edges, trimmed then stapled
    Worked on matching the trunk with the rest of the car so for durability I dyed the fabric in the rear.
    For the spare tire area I am currently working on a piece of 3/4 maple that I will trim to fit and stain to give a classic wood finish in the rear.
    For carpet I ordered matching black carpet kit and will have it sometime this week, I will keep u updated on the quality and fit. To match I have oem bmw floor mats that are more of a dark grey then black for a nice contrast. Matching suede shift boot and m sport knob.
    Thanks for the feedback and I will try and update more frequently as work gets done.
    For now this is a link to a video my friend made of the wetsand and polish
    UPDATE MAY 27 2015
    So long story short my parts arrived and so did my powder coating
    along with my sway bars and parts :)
    I cant stand rust so I did some refurbishing
    strip all the rust of with wire wheel then rust proof
    My wheels showed up
    Now im still waiting for parts, also going to clean up the axels.
    some fresh rebuilt calipers by Friday then hopefully get some rubbers on it Monday and I should be cruising by next weekend, the excitement is killing me.
    UPDATE SHE IS DONE! for now
    gotta make sure the accessories go back in
    Hey so a small update, just in the process of uploading pictures, but new for 2016 I had the entire car wrapped in 3m rock guard, a new set of wheels to make it look more old school and a fresh built motor along with much much more. I'll be updating the remainder of pictures but from now on I will be documenting everything in video with other projects!
    Please follow the mod squad on Instagram and YouTube, give me some feedback and tell your friends!
    Thanks and enjoy
    So her we have my built motor, bottom end was decked honed o ringed, fitted with new pistons and rings and bearings. The cylinder head is a bimmerheads race cylinder head with dual valve springs heavy duty rockers, ported polished fitted with a dual pattern turbo cam.
    everything is sandblasted and powder coated
    Heres a video of the motor being assembled
    <iframe width="560" height="315" src="https://www.youtube.com/embed/9_cj9bM4we4" frameborder="0" allowfullscreen></iframe>
    <iframe width="560" height="315" src="https://www.youtube.com/embed/IS1KHZ1McFs" frameborder="0" allowfullscreen></iframe>
    While the engine was out I deleted the abs pump, never worked and I wanted the clean look and extra space.
    also while the motor was out I had the front subframe blasted and coated. I also didn't really like the rack in the car so bought a new z3 rack
    installed the motor as I wanted to break it in without a turbo, so I also put in my msd wasted spark ignition and meagasquirt management.
    Put some more classic looking wheels.
    Took the car for alittle road trip
    I didn't like the amount of engine and road noise as this new carpet didn't come with nearly as much insulation so I did the firewall and transmission tunnel in dynamat.
    along with those I did the lower half of the door cards.
    New vapor barrier
    After lots and lots of waiting and searching I finally found a rust free hatch.
    Which I had repainted
    finally the day came to install my turbo which I have been looking forward too a long time.
    really wanted to keep my oil cooler so I got creative and made a bracket for the intercooler that also holds the oil cooler in a v format. also gave me lots of space for my oil filter relocation and easy non kinked lines
    lots of welds to keep it ridged
    mounted the radiator back to fit my electric fan between the intercooler and radiator with an adjustable temp range
    Spent a lot of time rwrapping the manifold tightly and tied it all with stainless wire all fancy
    Time to fabricate a downpipe
    minimal trimming required to fit it all behind the valance
    finished product
    VIDEO OF THE CAR ON DYNO!!! CHECK IT OUT!!
    AND ANOTHER OF IT SPOOLING UP ON A MODDED EVO
    thanks for looking everyone!!
  • TimeMachinE30
    • Jun 2014
    • 3749
    Nice color.
    ACS S3 Build / Dinan 5 E34
    • ThatOneEuroE30
      • Dec 2013
      • 8626
      Not bad. Me like
      1991 318i 4dr slick top
      Mtech 2 turbo restoration
        • 37827
        Well that's quite the first post!
        Nice work and awesome color choice with the Hellrot! 8)
        Classic BMW Specialists
        Santa Clarita, CA
        www.BimmerHeads.com
        • Nats88M3
          • Sep 2013
          • 209
          Very nice!!! Car looks great!
          • Beau B
            • Mar 2004
            • 734
            Very Nice!
            1988 BMW 325iS
            • YAN-3
              • Jan 2004
              • 6018
              patience, dedication and love there. very nice
              • abit
                • Jul 2011
                • 416
                always loved this colour and awesome work done there, nice! :up:
                http://instagram.com/mundieriss
                my 88' m20b30 HERE!
                • getouth
                  • Jan 2010
                  • 3343
                  People the bar has been set.
                  FEEDBACK:
                  http://www.r3vlimited.com/board/showthread.php?t=316212
                  BMWCCA #398608
                  IG @yagayo38
                  "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
                  • LeSeb
                    • Dec 2014
                    • 27
                    Glad you guys like it should have some new updates in the following weeks.
                    • aintnothang
                      • 743
                      Damn. I need a repaint.
                      • MC Hammered
                        • Jul 2008
                        • 2076
                        The work you have put in is amazing!
                        Did you weld shut the drain holes in the floor? Or did you just replace with new bung plugs?
                        My 1989 e30 s52 Touring... this is Betty
                        My 1989 325i vert (sold)...this is Nina
                        My 1991 M5 (sold)... this is Veronica
                        Photo comparison: OEM vs aftermarket windscreen for a convertible
                        • LeSeb
                          • Dec 2014
                          • 27
                          Newplugs. It prolly has its purpose and I don't plan on driving it in the winter so it shouldent ever be that wet again,
                          • euroshark
                            • Apr 2006
                            • 3491
                            Beautiful work! I love how you started small and it snowballed into a proper paint job.
                            • kway
                              • 1084
                              Wow! Just wow. Very nice work.
                              '84 318i - Lapisblau/Schwarz (in cryosleep)
                              '06 330i - Titansilber/Schwarz
