1968 Florida 1600 Restoration Project
  • phreshkid
    • 4655
    #376
    Got the rear window seals in, and the quarter windows themselves.
    I also redid the door stops, window regulators, regreased all moving parts, new vapor barriers,new door cards (not oem), including new felt strips, and a bunch of new little things that typically break over time.
    Prepping more parts:
    I can't wait to drive this thing. I'm getting hot and bothered just thinking about it.
    Prepping more parts and picking the very best sets.
    New windshields and gaskets go in soon.
    Older photo, but this was right after I threw the wheels on. I will lower the car another 1.5" front and rear. The wheels fit great, no poke front or rear which I was concerned about. Lighting is off but you get the jist.
    • tak7
      • 856
      #377
      I like your style.
      • bangn
        • Sep 2011
        • 760
        #378
        such a neat little car
        Boris - 89 E30 325i
        84- E30 323i
        • thestein1016
          • Feb 2014
          • 186
          #379
          What are you using on your window crank assembly? I have 2 sticky rear windows on my bav and it's starting to bother me.
          Also, what are you using for moisture barrier material?
          Track Car Build:http://www.r3vlimited.com/board/showthread.php?t=365614
          • johnnysrx
            • Mar 2014
            • 5
            #380
            looks like its gonna be to nice to drive???
            • phreshkid
              • 4655
              #381
              I use white lithium grease for the window crank assembly. I grease all tracks, rails, and moving parts. I also grease up the locks with white lithium and graphite oil. Both can be found in aerosol cans.
              • phreshkid
                • 4655
                #382
                basically, yeah.
                • thestein1016
                  • Feb 2014
                  • 186
                  #383
                  Already coated all mine in white lithium. Maybe I'll buy the can stuff. I must be missing a spot
                  • phreshkid
                    • 4655
                    #384
                    Make sure all the roller bearings are spinning freely as you turn the window lever
                    • phreshkid
                      • 4655
                      #385
                      • rzerob
                        • Jun 2013
                        • 2315
                        #386
                        It is looking great. Also is Judge Judy gone.
                        • phreshkid
                          • 4655
                          #387
                          Thanks. The Judge is still around. I have been doing stuff to her but I've been devoting my time to the 1600 and the 318iS for right now. The tii will go out for paint soon.
                          • phreshkid
                            • 4655
                            #388
                            Glass is in, all seals are new, things are moving.
                            I finished up a few more interior things but I failed to photograph them. Just believe that they happened.
                            • DEV0 E30
                              • Oct 2004
                              • 8896
                              #389
                              I love what you've done with the place.
                              • kronus
                                • Apr 2008
                                • 13032
                                #390
                                That looks instantly so much more complete. What's left?
                                cars beep boop
