AlphaTeam Presents: Chocolate Thunder and the 24v expedition!
  • hankolerd
    • Oct 2012
    • 280
    Would love to hear your thoughts on the UUC Evo 3 + DSSR when you get it installed. I have been considering it for a few months, but that is a spendy piece of kit. Trying to decide between just an OEM bushing rebuild, an OEM rebuild + DSSR, or the full Evo 3 SSK + DSSR.
    Daniel
    1990 M3 - http://www.r3vlimited.com/board/showthread.php?t=376104
    2011 328i Sport Wagon - 6sp Manual, RWD, Sport
    • spiDmang
      • 3941
      Hey Dan!
      Thanks again for the ZHP shift knob. Can't wait to put it to use!
      As for the Evo 3+ DSSR, it really is a killer setup. I've driven a 318iS and 325iS E30 with this setup, and its very tight, and precise. Aaron (the guy shown in the pics) has had first hand experience with the UUC stuff in an E30 M3, and he states that the shifter just sits too high for his preference. It might be ok for others, but when comparing it to the Getrag 260 UUC stuff, the shifter sits lower. Just an FYI.
      I personally got all the UUC stuff for a deal, so i cant complain. I've noticed though that the biggest difference in my shifter rebuild were these items...
      -new foam behind the selector joint
      -garagistic Delrin front and rear bushing inserts (they are sooooooo tight and precise, that the shift carrier (the part that holds the shifter in place) has ZERO wiggle room and if you lifted the carrier (without the dssr attached to the shifter) up vertically, it'll literally suspend there!
      - $5.50 shifter bushing cup (if you're using an OEM shift lever)
      -DSSR (i like the idea of a dual sheer selector rod. and it really kills the wiggle room.
      91' 318iS - S54/6MT Swapped
      08' E90 M3 6MT - Daily
      Originally posted by IronJoe
      Originally posted by 2mAn
      • hankolerd
        • Oct 2012
        • 280
        Are the garagistic delrin bushings something that only applies to the stock carrier? Or do you recommend then on an Evo 3 as well?
        UUC through the end of day tomorrow has a deal, buy an Evo 3 and get the DSSR for free. Now that I saw that deal I am thinking of buying it.
        Daniel
        • spiDmang
          • 3941
          The stock carrier (the aluminum arm) has a bushing at the front of the carrier (where the bitch clip attaches) and one in the rear carrier that you must burn out, and then press in/hammer in the new one.
          for a better idea:
          Garagistic Aluminum/Delrin Front Carrier Bushing (ROUND) - K0274 Please Note: One bushing might fit different the other bushing. Click here to learn why.     Product Overview If you're into overkill, you will love our aluminum round shifter carrier bushings. They are basically just like our Garagistic Delrin carrier un
          If youre going to go thru all of the trouble of swapping out shifters/selector rods, I highly recommend those bushings. And thats a solid deal on the UUC stuff. I say pull the trigger and enjoy :up:
          • hankolerd
            • Oct 2012
            • 280
            I see, I didn't think about the fact that the Evo 3 does not come with its own carrier, I will check out those delrin bushings. Thanks for the recommendations!
            Daniel
            • spiDmang
              • 3941
              Update Time!;D
              So in the previous update, I had visited AAA325iS's epic man cave, and he was able to fab up some awesome stuff for me.
              Since then, I have received a plethora of parts and began assembling...
              Getrag 260 with Garagistic Delrin bushings. Shits TIGHT.
              The fitment is so tight, that you could literally have the shifter carrier suspend itself! ALSO IMPORTANT NOTE!!! If you are utilizing an Early model Getrag 260, but you opt to use the late model provisions like shown below, MAKE SURE that when you thread the carrier bolt in back into the transmission (You need to seal the the driver side carrier hole where the sheet metal carrier attaches to because oil will leak out of there if you DONT!) MAKE SURE THE BOLT IS SHORTENED! I CAN NOT stress that enough. I didn't do that, and it locked my early model getrag in gear. I now have to tear it apart and fix the detents and possibly repair a bent shifter fork...Luckily i have great friends. AAA325iS came to my aid YET AGAIN and had a spare late model getrag 260 for me. So I picked that up, tore off the old getrag and installed the new one with no issues!
              motor finally made its way in. I had Robert @ Kadunza make my harness! made it sooooo simple for install, and it looks beautiful!
              Almost there!
              and Finally back on the ground after a long 2 months!
              Interior shot with the new carpet, and converted 5 speed!
              After getting everything somewhat dialed in, I had an appointment with the exhaust shop. The route i took was this ...
              OBD2 maniolds > Custom Made downpipes to clear subframe/swaybar (each downpipe was 2inches in diameter) > Y-pipe > 2.5inch straight piping > Vibrant ultra quiet resonator > Vibrant 1040 street muffler.
              I'll post videos soon as well. The sound is great! Vibrant makes killer stuff and would totally recommend this setup for anyone that wants something louder than a catback exhaust but nothing tooo obnoxious. To fellow car enthusiasts, it has a great mellow idle. Around town, its very tolerable and passes the girlfriend test. And at WOT....:devil:
              I'll snap pictures of the finished goods later. I didnt want to get in the way of my buddy haha!
              and the finished product!
              More updates to come as i get everything else dialed in!
              • ak-
                • 12422
                Yeah, I'd be proud of that. Nice work!
                1991 325iS turbo
                • 2mAn
                  Señior Mod
                  • 20991
                  Looking real nice Brad!
                  Simon
                  Current Cars:
                  -1966 Blue Boat
                  -1969 Red VW
                  -1986 White BMW
                  -2006 Green Thing
                  Make R3V Great Again -2020
                  • e30de89
                    • Sep 2006
                    • 197
                    Looking good man! I think I bought some parts from you like a year ago. You live like 2 minutes from me. Would love to check it out!
                    Green 89 325 s52 build: http://www.r3vlimited.com/board/showthread.php?t=280902
                    • spiDmang
                      • 3941
                      Thanks fellas! I appreciate the kind words. Now, to just get this damn thing to bleed properly :hitler:
                      Oh really?? Nice haha. Yeah, you're more than welcome to swing by anytime! Bring one of your M3's though, so i can gawk at it
                      • Sh3rpak!ng
                        • Jan 2014
                        • 2667
                        Nice build! In for updates!
                        Shadetree30
                        • CorvallisBMW
                          Long Schlong Longhammer
                          • 13039
                          Looks great!
                          • Brad Sindoni
                            • Nov 2014
                            • 178
                            this thing is sweet, I learned a lot just reading your thread lol. looking forward to more updates!
                            _keepitgutter
                            88 Alpine white Super Eta
                            • hankolerd
                              • Oct 2012
                              • 280
                              Very nice Brad, such a clean build.
                              Daniel
                              • e30_world
                                • Aug 2014
                                • 586
                                Install looks awesome. I really want to hear that vibrant. I have a craptastic set up and its way way too loud. You gunna make it out to dicks drive in anytime soon?
                                F80 M3 Alpine
                                E10 Fjord Blue 2002
                                E28 Blackish 535i
                                E21 Silver 320i
                                Disco1 98 4.6
                                E30 Cirrus coupe S50 SOLD
                                E30 325i SOLD
                                E30 Alpine 325i vert Euro spec SOLD
                                E30 Alpine coupe 325is SOLD
