formyhealth - 1991 318is Build Thread - now with 1000% more 1JZ-GTE
Yes from my understanding I will need the 2.3l pan regardless as it has the proper bolt spacing for the bottom side of the transmission bell housing. Now I need to figure out if I can also use the 2.3l flywheel, clutch, throwout bearing and starter.Comment
It seems like, even though more expensive, that a tremec t56 may be a better choice due to size as well as durability. I am not liking the things I am reading about the getrag mt-82 when you throw power or high rpm shifts at them.Comment
glad to see progress being made on this. Wish I knew more about this swap/motorComment
Picked up a Spec stage 2+ aluminum flywheel/clutch combo, and pilot bearing. When the engine stand shows up I'll get the engine up and swap out the 2.3l oil pan. Then mate the trans to the engine and make some time to pull the m42.Comment
this should certainly be a fun combo. This is an aluminum block right? How much do you think it weighs in full trim?Comment
I will try to figure out a way to weigh it accurately, but from anecdotal evidence:
M42 with all accesories: 345#
2.0 EcoBoost with all accessories: 328#
Getrag 260: ~95#
MT-82: ~123#
e30 318is dry weight with m42/getrag 260:2602#
e30 318is dry weight with swap theoretical: 2613#Comment
Great work! The bell housing on the mustang gearbox sure looks deep, so will be interesting to see some pics on how it fits in the e30 tunnel & how far back you can get the engine.
In Australia we got a 240hp version of the 2.0 ecoboost in the RWD Ford Falcon, so I will certainly follow with interest.Comment
Lucky!Great work! The bell housing on the mustang gearbox sure looks deep, so will be interesting to see some pics on how it fits in the e30 tunnel & how far back you can get the engine.
I wonder what transmission that uses? Methinks the MT-82 probably (EDIT: it's a TR-6060). Luckily the E30 transmission tunnel opening is fairly wide and my rough (very rough) measurements says that it will fit. If not, I have a bfh and some time so not an issue for me. I'm more concerned with the engine height, at 30" it's definitely not going to fit with the hood closed, but I am not opposed to taking and angle grinder to the hood to fix that problem.Comment
Another big box from Ford Performance showed up today. This time it's the 2.0l engine orientation kit that supplies the correct 2.3l pan, intake manifold, coolant outlet neck to send hose to the front of engine and a few other related bits.
Also got a flocking kit for the dash, I went with "Goose Grey" Suede-Tex.
So tonight I got the engine up on the stand and am slowly putting on the parts for the rwd conversion, pictured is the 2.3l intake manifold. I won't be able to run the throttle body like that as it's in the way of the tensioner. Ford said slight modification is required so I'll need to inquire further as to what I need to do to make it fit.
Todays project included installing the new coolant outlet neck and associated tube and I also started to dress out the wiring harness. I have to unwrap a lot of the tape to allow some of the wires to stretch out to different locations.
New coolant tube and neck
Start of the wiring harness install
