Engine Mounts, Drive belts, and Oil Pan Investigation
It's been a rough week at my house. I won't get into details, but thankfully everyone is OK. I needed a bit of an outlet, so before picking up the kids from school I knocked out a few things: drive belts and engine mounts. After they went to bed I dropped the lower oil pan (M42s have upper and lower pans) to check on some things and changed the oil.
My drive belts were in decent shape, but the alternator belt always seemed a tad loose, even with the tensioner fully extended. It turns out the previous owner had put the wrong size belt on the alternator (1030 vs 1025). So now I have 3 new and correctly sized belts.
The M42 doesn't have any aftermarket engine mounts available. You can get E36 M42 mounts and file off a locator nub for about half the price, but I read conflicting things on that, so I went with OEM. I also ordered all new hardware.
I'm fairly certain the old engine mounts were original. They were about an inch shorter than the new ones (due to age/collapsing/etc). After raising the charcoal canister, I was able to access the top nuts using some extension and a swivel socket.
Old left vs new right:
Installed:
Lastly, the oil pan. I wanted to ensure there weren't any loose bolts. During some extensive engine seal work a couple years ago I had new timing guides installed, so I wasn't expecting to find any of those. Prior to that I had done the lower oil pan gasket myself to fix a leak and ended up heli-coiling 6 of the holes in the upper pan. When I opened it up everything looked great. We'll see if I introduced any new leaks when I installed the pan (new gasket + gasket sealer).
Prior to last week, I managed to get out for some photos of the improved ride height. Usual spots, so nothing exciting. I did find a new photo spot and I'm hoping to get there soon.
I've hit up a few Cars and Coffee events with the kids. I was able to check out fresh_TD's minty '91 318i again as well at Katie's Cars and Coffee in Great Falls, VA.
Installed:
