Sport Steering Wheel Install - 4th time's a charm
Wow. A steering wheel finally worked out. After buying a leather airbag wheel that had major issues, and buying a nicely wrapped Mtech 2 wheel that had crash damage, and buying a vinyl airbag wheel that had sheered airbag wiring, I have installed a steering wheel that I like (and didn't have major issues)! Props to fresh_TD , the enabler, for sending me a link to this wheel.
Story time. Almost exactly a year ago this wheel was sold by Adrenaline Junkie to another R3V member that lives in North Carolina (not sure of their username). That R3V member never installed it and recently listed it for sale on FB Marketplace. fresh_TD saw it and shared it with me. It's a standard "sport wheel" from what I've gathered. It was available on E30s (mostly verts) and E28s. Whoever did the wrap did a great job. Thumb pads were added. I really like the mix of perforated leather, non-perforated leather, and the colored stitching. It's all very solid. Best of all this was CHEAP. Shipped to my door it was cheaper than what it would cost to have the wrap done by itself. Likely because it's just a "sport wheel". Regardless, it's 100 times better than the crappy airbag wheel that was in the car. I like it a lot.
Tech tip time. There are plenty of DIYs detailing how to install a non-airbag wheel in an airbag-equipped E30, so I won't go into all that. I will say that I have confirmed if you remove the lower knee pad under the steering wheel and disconnect the 3 connectors going to the orange box (the SRS module), you will not have a blinking SRS light. Also, this method prevents any faults from being stored in the SRS (because it's unplugged). If I reinstall the airbag wheel at some point I'll just need to reconnect the whole system before hooking up the battery again. Yes, there's an SRS reset procedure (referenced earlier in this thread in fact) that can also be used to clear the SRS fault codes.
Picture time.
DSC_0492 copy by mike.bevels, on Flickr
DSC_0496 copy 1 by mike.bevels, on Flickr
DSC_0499 copy by mike.bevels, on Flickr
DSC_0508 copy by mike.bevels, on Flickr
DSC_0503 copy by mike.bevels, on Flickr
Picture time.
