2.8L M20 9.8:1 stroker build: my 323i reincarnated
  • betz
    • May 2016
    • 317
    #286
    Originally posted by Aufbau Principle
    The one you have is the 85 and below lip. It would let you run the 'Pfeba' lip. I had one before I found the Jimmy Hill. It's also a nice look:
    Hmmm... I don't see the fog light mounts on that valence like mine has. But I think you're right. I was trying to get the valence that my 323i had (but got mangled) so I suppose it makes sense it was the 84-85 valence since my 323i was an '85. My 325 is production date 03/86. You sure that the lips aren't compatible for all early valences?
    '86 Burgundrot 325 2.8 stroker.
    Other cars:
    2000 Porsche Boxster
    2006 Subaru Outback XT 5MT
    1972 Porsche 914
    • Aufbau Principle
      • Jan 2013
      • 121
      #287
      The valance in that picture is just the US one, the difference b/w them is that the Euro one has cutouts for fog lights and doesn't have the cutouts for some of the diving board one. I'm pretty sure the lips aren't going to interchange nicely without some hackery. I took off the pfeba lip and put the Jimmy Hill in front of the car when I got it, it's like a quarter inch or so longer on the sides because the later valence is more squared off compared to the early one that slopes inward. The early lip with the brake ducts also follows the slope of the valance whereas the later ones stick out out kind of like how the M3 has it.
      Compare the two versions here:
      Early early
      Late early
      • betz
        • May 2016
        • 317
        #288
        Final few tweaks at the body shop! Perfect
        Whopedy scoop poop
        Other cars:
        1972 Porsche 914
        • wworm
          • Dec 2016
          • 1719
          #289
          Whopedy scoop poop
          whoopdeedeescooppoop
          looks good man.
          1984 Delphin 318i 2 door
          • 2mAn
            Señior Mod
            • 21065
            #290
            spottieottiedopilcious
            throw the lip on it and go do a burnout
            Simon
            Current Cars:
            -1966 Blue Boat
            -1969 Red VW
            -1986 White BMW
            -2006 Green Thing
            Make R3V Great Again -2020
            • betz
              • May 2016
              • 317
              #291
              Just got the second valve adjustment in. Most exhaust valves actually seemed slighty loose.. it was pretty consistent. I think only one or two intake valves were out of spec. And only one exhaust in spec. Still looks really nice under the valve cover though.
              Pick n pulled some parts off an E34 525i and just got around to installing. I've decided to update to the late model valve cover and finally got a late model fuel rail so my supply and return lines are on the same side. Did the same with this valve cover that I did with the previous one, though the big blocky BMW letters seem to take the sanding and polishing better than the early model one.
              Up next... The smileys
              Other cars:
              1972 Porsche 914
              • BUDNUNTA
                • Apr 2005
                • 996
                #292
                Just got my crank last week
                Can't wait to build up one if these
                We're out there in here.
                • betz
                  • May 2016
                  • 317
                  #293
                  Nice! You going for the same 2.8 build? You figure out all the other stuff yet? (EMS, cam, injectors, etc)
                  Other cars:
                  1972 Porsche 914
                  • 2mAn
                    Señior Mod
                    • 21065
                    #294
                    I have the spacer now... and a leaky M20. I better get moving
                    Simon
                    Current Cars:
                    -1966 Blue Boat
                    -1969 Red VW
                    -1986 White BMW
                    -2006 Green Thing
                    • BUDNUNTA
                      • Apr 2005
                      • 996
                      #295
                      Mine will be M52 crank, m20b23 rods, m20b25 pistons, m52 pinktop injectors , motronic 1.3(custom chip), Cam will be a Schrick 272
                      Nothing wild just a replacement engine for my wifes 1983 318 which has a clacky 350,000Km b25 in it now
                      • betz
                        • May 2016
                        • 317
                        #296
                        That's still an E30 right? Nice setup though. Pretty much exactly like mine haha. Except I have the bimmerheads 274 cam.
                        Good luck! It seems my influence is spreading ;)
                        Other cars:
                        1972 Porsche 914
                        • betz
                          • May 2016
                          • 317
                          #297
                          Other cars:
                          1972 Porsche 914
                          • wworm
                            • Dec 2016
                            • 1719
                            #298
                            looks good man! Might want to throw a front plate on there just to avoid tickets if at all possible.
                            • betz
                              • May 2016
                              • 317
                              #299
                              I don't have one :(
                              The smileys are so so so so sooo much better than the sealed beams though. Who knew lights at night could actually help you see??
                              Other cars:
                              1972 Porsche 914
                              • wworm
                                • Dec 2016
                                • 1719
                                #300
                                did you keep them stock?
