2.8L M20 9.8:1 stroker build: my 323i reincarnated
  • Kedge
    • Jan 2005
    • 44
    #46
    Your engine build sounds very similar to the spec of mine,
    M52 crank, early higher CR 325i pistons, M20B20 rods, 885 head, schrick 272 cam, M50 injectors, Porsche 944 S2 FPR, AEM fuel pump, big bore throttle body and a BTB 6 branch manifold. CR is 11.3:1, had to get the valve reliefs machined so the wasn't valve to piston contact to get that CR.
    It was live mapped a couple of weeks ago, still running Bosch M1.3 and made 202bhp. I was hoping for more, but it's so fun to drive, revs quickly and pulls well throughout the rev range, with a nice kick when the cam comes alive. The remapping has made a big difference.
    The main trouble I had was getting enough fuel in, the original Bosch pump just wasn't up to it, especially after upping the fuel pressure. I also have to run it on 97.
    My head is standard, but I've heard good gains can be had from those 3 angled valve seats, wish I'd got the head fettled a bit before it was all bolted together.
    Also, I don't run an oil cooler. Modern oils are so much better, but then I do live in the UK, so our temps aren't as high.
    Twitter/Instagram - Kedge85
    • TC Baur MD
      • 145
      #47
      It looks like you have the stamped timing sprocket, not the cast one. The stamped steel sprockets are a known failure item and it should have been replaced. My timing belt came off but didn't brake but the timing belt sprocket got destroyed, see attached photo. It's now in three pieces. This caused the 4 rocker arms to brake off.
      • betz
        • May 2016
        • 317
        #48
        Oh shit. Thanks for the heads up. Is the timing sprocket that attaches to the cam also prone to failure? I'm assuming the one that goes at the end of the crank is okay, it looks super beefy.
        I will def be buying a new IMS sprocket, at $35 its a no brainer.
        '86 Burgundrot 325 2.8 stroker.
        Other cars:
        2000 Porsche Boxster
        2006 Subaru Outback XT 5MT
        1972 Porsche 914
        • betz
          • May 2016
          • 317
          #49
          Dang, that CR is crazy high. I have to go to a race track to get octane higher than 91.
          Have you considered moving to a standalone EMS?
          Probably not going to run an oil cooler to start. Trying to keep it simple since it's my first build. Speaking of which, what oil should I run? Would 5W-30 be to thin even on a basically new motor?
          Other cars:
          1972 Porsche 914
          • bavarianbeast-khalil
            • May 2016
            • 3
            #50
            Yeah that is crazy high, I believe you can run E85 with that compression ratio and a proper tune. E85 is all over California.
            BavarianBeast.com
            • potatomash
              • Nov 2014
              • 203
              #51
              Looks like you didn't use gasket goo on the sump gasket, is it a magical kind that doesn't need it I don't know about??
              T U R B O - M 2 0 - B U I L D
              M U S C C O O
              • digger
                • Nov 2005
                • 5964
                #52
                Get the cam gear and int gear sintered versions
                • Kedge
                  • Jan 2005
                  • 44
                  #53
                  I don't see any need to move to an EMS now it is mapped correctly, everything is work as it was designed to.
                  I'm using 10W-40 oil at the moment, may try a 5W-40 as that's recommended nowadays here in the UK. One thing I was told was for the first 100 miles just chuck in some cheap, thin mineral oil for the initial bedding in. Then put in the oil you plan on running with.
                  I'd also recommend getting an adjustable cam pulley to make sure the timing is spot on after you've given the head a skim and decked the block.
                  • betz
                    • May 2016
                    • 317
                    #54
                    By "gasket goo" I'm assuming you mean gasket maker. I'm using a paper gasket.
                    I'm not trying to double up the gaskets. The bare surface of the sump and the block are clean.
                    Other cars:
                    1972 Porsche 914
                    • betz
                      • May 2016
                      • 317
                      #55
                      The machinist / engine builder I'm working with wants be to use Joe Gibbs 5W-30 break in oil for the first 400 miles. He also mentioned using another oil for the first 15-20 mins so I don't circulate any metal.
                      Probably going stock to start. If my timing is a little retarded, in theory I should get more top end power, which might balance out my torquey motor. Either way the motor will run well and I'll think about messing with it later. I don't think the gear is worth it unless I get it professionally tuned.
                      Already bought both the sintered pulleys.
                      Other cars:
                      1972 Porsche 914
                      • betz
                        • May 2016
                        • 317
                        #56
                        Head is finished
                        Other cars:
                        1972 Porsche 914
                        • betz
                          • May 2016
                          • 317
                          #57
                          Shipment just arrived
                          +1 Dramatic effect
                          Other cars:
                          1972 Porsche 914
                          • betz
                            • May 2016
                            • 317
                            #58
                            I felt like I needed to do something with the valve cover and intake manifold. Since the black has been done so many times (and my block is silver), I decided to just polish the stripes and lettering. Probably one of the more subtle things I could of done, but I like how it turned out.
                            Other cars:
                            1972 Porsche 914
                            • Kedge
                              • Jan 2005
                              • 44
                              #59
                              Coming along nicely, just make sure that the top of the head and rocker cover are skimmed. I'm having problems with blowing out rocker cover gaskets, the presumption being one of them isn't flat. Fingers crossed it's my rocker cover.
                              • clarkson
                                • 231
                                #60
                                Just came across your build. Nice work. Done a similar build myself. M52b28 crank, 130mm rods, b25 pistons, 885 head. Dbilas 276 cam. Adj can gear. Jb racing flywheel. Raceland headers. Miller war chip. BBTB. It was a fun street engine, lost power over 5800rpm on the dyno due to intake manifold. Made 179hp atw. Torquey AF. Sold the car but still going strong. Would build another. Actually just bought a m52b28 whole engine for $200 so might do so. I would not be expecting a huge power increase from this build but a really nice fun motor all the same. Say add 30% to a stock m20 b25 and that's what you should expect. It doesn't seem like much, and it isn't for all the work and money you put in, but you end up with a really nice motor that will go for ever, and feels brand new. Also it's a total sleeper, the engine bay could look almost stock.
                                Pulling my hair out with all these friggin BMW's:
                                2000 M5 Winter beater
                                1984 318i Coupe 2.5 S14 going in the car below.
                                1988 M3 Lachssilber: I'm the second owner, currently recommissioning.
