Dmanb2b's Alpine 318is - S52 is ALIVE
  • dmanb2b
    • May 2018
    • 367
    #91
    Originally posted by ZekeTheSneak
    Damnit, making me want to pull my motor and rering it... Awesome progress
    Thank you...thankfully it made all the difference in the world. Motor just purs...
    1991 318is
    2004 330ci
    2011 335d
    • dmanb2b
      • May 2018
      • 367
      #92
      Well it's been a while since my last post. All things said, the car has been running great. I have put approximately 2K miles on since the swap and it's finally feeling broken in. Here are a few pics since pulling her out of storage. Next on the list is some over due rust repair and I guess the catch can set-up is working well...lol. Mostly water...can't imagine all that going back into sump.
      Yuck!!!
      1991 318is
      2004 330ci
      2011 335d
      • mike.bmw
        • Dec 2015
        • 1770
        #93
        Looking good! Do you have a shop lined up for the rust repair?
        • dmanb2b
          • May 2018
          • 367
          #94
          Shopping around. I was considering tackling on my own, but with current economic situation, I may throw my local body shop some work.
          1991 318is
          2004 330ci
          2011 335d
          • TeXJ
            • 1914
            #95
            Originally posted by dmanb2b
            Question for you on the front(blue in pic) coolant temp sensor. That one looks like the obd2 sensor? I have a m52 converted to obd1 and my front sensor I have to re-thread the sensor to fit that first hole. The sensor I have to use is for an obd1 m50.
            Just wanted to see if there was a better way of doing this so I dont have to re-thread a sensor every time I may need to replace it.
            1990 325is
            m52b28
            3.73lsd
            g260 (1987 325is 5spd tranny)
            • dmanb2b
              • May 2018
              • 367
              #96
              It's been a while, but I'm I'm pretty sure we ordered a obd1 blue sensor, and i only re-threaded the brown e30 temp sensor. but this depends on the cylinder head you have. some have two ports some have three. re-threading the sensor is a PITA but with a new sharp die helps a lot.
              1991 318is
              2004 330ci
              2011 335d
              • TeXJ
                • 1914
                #97
                Thanks, Yeah i was trying to find a way that I wouldn't have to rethread the temp sensor. Thank you!
                1990 325is
                m52b28
                3.73lsd
                • dmanb2b
                  • May 2018
                  • 367
                  #98
                  Took some time last night to replace the OBC and cracked HVAC panel and install a spare radio I had laying around in the garage. I don't like that it has blue background, but I do like that it was "free"..lol
                  1991 318is
                  2004 330ci
                  2011 335d
                  • dmanb2b
                    • May 2018
                    • 367
                    #99
                    Hope everyone has been staying safe! Thankfully, work has been busy. Finally sneaked in a few minutes this weekend and last to start cleaning up the engine bay. Replaced the hood insulation, found a s52 vanity cover that didn't cost more than the motor, and finally decided on a intake setup (Thanks castros !)
                    And then snuck in a drive before dark...lol
                    1991 318is
                    2004 330ci
                    2011 335d
                    • dmanb2b
                      • May 2018
                      • 367
                      #100
                      Well I am finally getting the rust addressed. Rear valance & passenger rocker rust has been cut out, patch welded, bondo'd and primed...ready for block sanding and reapplication of chip guard.
                      Found a small hole in passenger wheel well, which caused the rocker rust. Prior to welding in a patch, cavity was sprayed with rust converter and cavity wax to prevent future issues
                      Also going to get the front valance and IS lip repainted...stay tuned!
                      1991 318is
                      2004 330ci
                      2011 335d
                      • mike.bmw
                        • Dec 2015
                        • 1770
                        #101
                        Very nice! It must feel good to have that addressed.
                        • dmanb2b
                          • May 2018
                          • 367
                          #102
                          Thank you Mike...it does! I just knew the longer I waited, the more expensive it would get.
                          Also scored a set of Condor solid control arm mounts in OEM geometry...my current Condor mounts are the m3 geometry and the negative caster is a wee bit excessive. Hoping these will clear my headers. I tried a set of AKG mounts, but couldn't get the clearance needed. Side note, Condor should really look into revising the coating they use. Both my new set I purchased last year and this used set I just obtained have started flaking and allow water ingress and unnecessary rusting of a relatively new part. Nothing a grinder and cheap rattle can can't fix though, but annoying for an "upgraded" mount.
                          1991 318is
                          2004 330ci
                          2011 335d
                          • 2mAn
                            SeƱior Mod
                            • 20961
                            #103
                            When you're bored, Im pretty sure that the Pioneer decks let you change the colors and one is quite close to the OEM red/amber
                            Simon
                            Current Cars:
                            -1966 Blue Boat
                            -1969 Red VW
                            -1986 White BMW
                            -2006 Green Thing
                            Make R3V Great Again -2020
                            • dmanb2b
                              • May 2018
                              • 367
                              #104
                              Definitely something I need to look into. I made a half assed attempt to find it in the menu, but to no avail!!
                              1991 318is
                              2004 330ci
                              2011 335d
                              • dmanb2b
                                • May 2018
                                • 367
                                #105
                                Valance repair is moving along...for those wondering SEM is my body guys preference on rust converter and was sprayed inside the rocker, before applying cavity wax. Also using transtar product to replicate chipguard
                                Rust Mort is an acidic compound that converts existing rust to an insoluble black coating prior to applying body filler, primer or top coat.
                                https://www.tat-co.com/Products/Repa...oat-Chip-Guard
                                1991 318is
                                2004 330ci
                                2011 335d
