here's a major thread bump!
I did alot of work on the E30 yesterday.
I trimmed and epoxy'd the CF sunroof plug into the car. I was going to black silicone the inside and outside for good measure, but it's raining today, so that will have to wait.
then i started on my 5 lug conversion. I've got the front half almost done.
things installed
H&R nurburgring spec coil overs
IE hollow sway bars with links
new OE steel A arms
new OE tie rods
THR eyeballs
custom adjustable camber plates (will be replaced)
13 inch willwood rotors
willwood SL6R calipers.
things still left to do on the front
- I need an adapter to change my Bimmerworld SS brake lines to the thread of the willwood calipers. seams like one is american thread pitch and the other is european
- install new OEM 25mm master cylinder
- install SS clutch line from one of the board members
- install bimmerworld SS brake lines and bleed brakes
- install solid motor mounts
- install sparco/ie strut bar
so here are some pics...
sunroof plug
front suspension
temp wheels
M5 wheels, off to be refinished today!
the initial stance. notice the M5 wheel is running 235/45/17. i think with my 215/40/17 azenis i won't need to run the IE fender flares!
things installed
new OE steel A arms
new OE tie rods
THR eyeballs
sunroof plug
front suspension
temp wheels
