Making a track toy - E30 M3
  • Holland
    • Nov 2008
    • 7204
    #316
    I wish I could afford a S14, lol.
    Originally posted by DEV0 E30
    • bimmer
      • Feb 2007
      • 249
      #317
      Originally posted by jahnaboi
      All this jitterjabber for every thread. Great car and motor/everything choice. If I had your wallet size I'd do that to every M I could get a hold of. Seems like you're already on your way going down the list. M5 (check). M3 (check). Kudos.
      I´m done with ///M swaps :D
      Thordur
      1999 E39 M5 Twin Supercharged
      1989 E30 M3 with S85
      • Wh33lhop
        • 11705
        #318
        Originally posted by kristov
        Looks fast!
        Do you need to pump the brake pedal once to get brakes to grab high up?
        I have a similar setup to you and need to pump the brake pedal once before it grabs as normal. The first time i brake the pedal is very low.
        I know this is a 9 month old post, but this is called pad knockback and it is basically a function of how much runout (axial play) there is in your wheel bearings (and how much grip you have, more cornering Gs means more wheel bearing stress). The disc shifts axes when you corner hard (no wheel bearing is perfect, they will all have end play), which winds up pushing the pads back into the calipers. That is partially why floating rotors are so prized, because they can shift axes relative to the wheel bearing, which lets them keep the same axis even if the wheels haven't, and they won't force the pads back into the calipers every time you take a hard corner.
        I'd imagine that if you replace your wheel bearings, or if you have a 4-lug E30, do a 5-lug conversion as they tend to have bigger, more robust (and precise) bearings, that will help this problem. Or the aforementioned floating rotors.
        There is an excellent stoptech article on this should you want to read more.
        paint sucks
        • Wh33lhop
          • 11705
          #319
          And to the OP, this is an incredible car, I loved watching you chase down that GT2. :D
          paint sucks
          • bimmer
            • Feb 2007
            • 249
            #320
            That was fun but I am not sure he was 100% on it ;)
            I´m on par with GT3RS's and need to find the missing power,
            should be faster.
            Anyways, here is a video where I follow a friend in his
            S38B38 powered E30 cabrio:
            Thordur
            • kishg
              • Sep 2006
              • 2624
              #321
              nice vid thor.
              '12 F30 328i Sport Line
              '91 SpecE30 #523
              '00 Ford F-350 Dually Tow Vehicle
              BMWCCA #360858 NASA #
              128290
              • bimmer
                • Feb 2007
                • 249
                #322
                Here is another one from Spa where I´m making slicks out of R888's :D
                Thordur
                • chucko
                  • Mar 2004
                  • 509
                  #323
                  You were spotted at the ring recently. Any new vid footage?
                  • ak-
                    • 12422
                    #324
                    Hey are you retired or something, what is or was your job if u mind asking?
                    1991 325iS turbo
                    • bimmer
                      • Feb 2007
                      • 249
                      #325
                      http://www.s14.net/forums/showpost.p...9&postcount=23
                      I´ll post a trip report soon - until then here is my fastest lap in this trip:
                      Hehe, no not retired - a bit too young for that at 39.
                      I run a company that does 3d visualization.
                      Thordur
                      • bimmer
                        • Feb 2007
                        • 249
                        #326
                        Car now back in Iceland because of the bloody recession
                        Had some fun last weekend at our local drift track :up:
                        Here is a video and a pic:
                        Thordur
                        • vivalegreg
                          • Apr 2006
                          • 1313
                          #327
                          wow epic pic
                          e30s r kool
                          • bimmer
                            • Feb 2007
                            • 249
                            #328
                            Fixed the video link :oops:
                            Thordur
                            • e30damen
                              • May 2007
                              • 945
                              #329
                              Nice video!
                              PNW E30 Crew : 1991 E30 S50, 2000 E39 M5
                              Follow my S50 build
                              : MY S50 E30
                              Follow me on instagram : @damendesign
                              E30 T-Shirts | M3 T-Shirts /Prints
                              • 325ix
                                • Aug 2009
                                • 7783
                                #330
                                this thing looks great. Good luck with the project. The s50 will be sweet
