all of this makes me very happy.
Some Teaser Pics...
me too....it was an on-going project that took a while, but I think the results are brilliant. The power curve is very strange though. The car just sort of putters along until around 3000-3500rpm, then it's "all-cleared for lift-off". When I rode in it last friday, it seemed to me like first gear was pretty useless. In my humble opinion, it's a full-boost tune and a paint-job away from being a PERFECT CAR.Originally posted by accidentI have achieved the title of Douche of the month.
Discuss.1990 300ZX TT 5spd ($6,000)Originally posted by kronusIt was probably pissed off because it didn't want to pay taxes for poor people's healthcare.
1991 318i 4dr 5spd (DD)Comment
Oil pan was tapped. edit- Just reread this and sorry about that. I believe it was the oil filter housing, but I will check and see.
Also a small update, but no pictures. The car is now running an Aquamist Water/Methanol Injection system. The tuner (Tony @ EPL) is a big fan of them since they keep Intake temps down so much, which increases the longevity of the motor, as well as preventing detonation.
There are also three boost options that can be switched at any time inside the cockpit;
11lbs. = Water Injection gauge turned off
14lbs. = Water Injection gauge on / Smiley button off
16.5lbs. = Water Injection gauge on / Smiley button on
I should post some pictures to explain about the "smiley" button in the cockpit. Also, the car made 308WHP @15psi on a Mustang Dyno just yesterday, and I seem to be smelling the clutch more often. :)
Going to bed now for a HPDE tomorrow, but thanks for all the comments on the car, and it is nowhere near completion.
-Ben1991 318i Alpine II - S50/5-lug swapped - track carOriginally posted by BillBraskyE36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
1989 325i Cirrusblau - Daily
1970 2500 - Malaga over Grey Cloth
2012 F350 6.7PSDComment
308 wheel HP Im sure you can find a conversion on google
[/url]
Team USA Wrestling 67KG
Team USA Wrestling Strength And Conditioning CoachComment
It's been a while since an update, but here is the deal right now.
The engine was yanked back in mid April due to coolant mixing with the oil. Proceeded to do a compression test which yielded 135, 140, 140, 105. So we figured the headgasket was blown. Funny thing is, the car still pulled like crazy, no overheating or anything else unusual besides the compression test and oil/coolant mixing.
Ended up shipping the engine back to Metric Mechanic and have them do the work, but just received an update on what appears to be the problem. Apparently, the headgasket was in fine shape (stock M44, since the M42 is overbored), but one of the intake valves had some gunk in it. Thinking it may be the methanol/water injection causing this.
Motor should be getting shipped out by the end of the week and everything will hopefully be back together by the end of the month.
Looking good!
I was in the same boat this weekend, I needed to do my brakes, but I had to tune my space shuttle for my upcoming trip to Mars.;)Yours truly,
Rich
Originally posted by Rigmasteryou kids get off my lawn.....Comment
Another update. My dad had a lengthy conversion with Jim Rowe of MM a few days ago and the motor should be shipped back to us in 3-4 weeks. There were some other issues as well.
One of the other reasons that one of the valves burned up was the hydraulic lifters. Apparently the lifters bled out from sustained high RPMs, which was funny because the car usually only saw 6800rpm max on the track. One of the cams was also worn in a strange way, apparently another tell for the lifters not delivering enough oil. There is a fix for this though.
Jim will be installing solid lifters, a new cam, and some sort of swedish exhaust valves. I won't say for certain, but 8500rpm should be obtainable if need be. :)
Thanks for the positive responses and no it hasn't seen a body shop yet. Still deciding if we should start over with a better shell and transfer everything over.
Also forgot to add, the car made 347whp @ 18psi on pump gas w/ meth.Last edited by BenM; 06-19-2009, 06:27 AM.1991 318i Alpine II - S50/5-lug swapped - track carOriginally posted by BillBraskyE36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
