Their camel hump heads, they were also on the 327's and have the larger 2.02 valve intake valves and IIRC 1.65 exhaust valves. Those are the power pack heads. I'd check out this book.http://www.amazon.com/Small-Block-Ch...4889690&sr=8-2 It's got all the stuff on building up those motors for all different types of purposes not just race and has all the part numbers.
My V8 swap..(putting flame suit on)56k maybe?
You need more than a flame suit, you need serious help.
Take that heavy paper weight to a metal yard and get the $$ for it, then go buy yourself a beer to celebrate your return to sanity.Last edited by sumyungguy; 03-25-2007, 11:33 PM.Comment
Keep us updated on progress.Comment
5.0 Ford Because there are more of them out there to use, there are more aftermarket products for that motor vs the 305, and they produce more power.
Dont swap motors cause you have something laying around, thats rediculous, replace it with a motor that will make the car fast. This thing will make it th 45mph a little quicker than the ETA motor, but everything aside from that will be about the same or less than the performance of the BMW motor.
But hey, goodluck with the engine swap.
Originally posted by vladDo you know anybody else who built that many bad ass E30s?Comment
302 Ford also has the distributor in front so you might be able to push the engine back towards the firewall more.
WillRIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
Welcome e30 (brilliantrot '90 325is) 12/23/06
DaveCN = Old Man
My signature picture was taken by ME! Not by anyone else!
Originally posted by george gravesIf people keep quoting me in their sig, I'm going to burn this motherfucker down.Comment
This is why i like this site, no one holds back what they think. I'm still going to put the 305 in it, with work they do make good power. SchnellerVert is right about the cars this motor came in. They was heavy, under geared, and had a crappy cam, that's why they was slow. This is the same argument about these motors on the GM/f-body forums, The people who never had them say that they are weak. And the people who had them or has got one now are woundering why people are making a big fus about the no power where all you have to do is a simple cam swap . And as far as aftermarket parts go, it's a sbc the stroke is the same as a 350 but the 305 has a smaller bore. Every thing on a 350 will bolt to this motor. I just can't go overboard on the valve size cause of the small bore on the 305.
1992 BMW 325iC
1978 Chevrolet Monte Carlo1965 Chevrolet Corvair Monza 140hpComment
dude good for you. yes thats a piece of shit motor but you are doing a v8 swap on the cheap and gaining shitloads of fabrication skill you can then use to build a fucking monster when funds permit and you have the right shit. fuck all these guysComment
At least you are modifying a early eta and not a late 325is..:: PNW Crew ::
'87 325 4dr, '74 2002Comment
I'm not that big on the handling of a car. I learned to drive with cars from the 60's and 70's and you know how they handled. I'm wondering about the extra weight on the front and the springs that i have on it now. It may sit too low and i may have to put stock springs on it. And thanks blunt, I will gain some more fabrication skills on this project. But i am building a monster for the street/ strip. 72 Vega with a 383 stroker, .600 solid lift roller cam, 1.5 harland sharp roller rockers, world product heads with 2.05 1.95 valves, fully ported and polished and have been flowed on a bench i can't remember the number's off hand right now, 850cfm carb, milidon gear drive, 5300stall torq converter, 350turbo trans, 4.56 gears. And this is going in a car that weighs less then an e30. If this was a "i" or "is" i would proboply leave it alone. And not do a motor swap.
1992 BMW 325iC
